IPB
> Ecu Fault Codes - The Easy Way!, works on M35.
pixel8r
post 17 Mar 2009, 08:35 PM
Post #1
VQ25DET
Car(s): '03 Stagea M35 RS4
Real Name: Steve
Trader Rating : 0
Just thought I'd share with you some very handy info I was given tonight (by a Nissan tech).
Its easy to check the ecu fault codes - something I didn't realise.
I believe the below would also be in the manual...
(btw MIL = Malfunction Indicator Lamp - otherwise known as CEL / Check Engine Light - its orange and on the right hand side of the dash in the M35).
ACCESSING:
NOTE: To access trouble codes, accelerator pedal position (APP) sensor must be functioning correctly.
  • Ensure accelerator pedal is fully released
  • Switch ignition ON. DO NOT start engine
  • Wait 3 seconds
  • Within 5 seconds, repeat the following 5 times:
  • > Fully depress accelerator pedal.
  • > Fully release accelerator pedal.
  • Wait 7 seconds.
  • Fully depress accelerator pedal and hold.
  • After approximately 10 seconds MIL will start flashing.
  • Fully release accelerator pedal.
  • Trouble codes are now displayed by MIL.
  • Count MIL flashes.
  • Compare to trouble code table.
  • Each trouble code consists of four groups of one or more flashes.
  • Ten flashes in a group indicate '0'.
  • The first group of flashes indicate the 'thousands' of the trouble code.
  • The second group of flashes indicate the 'hundreds' of the trouble code.
  • The third group of flashes indicate the 'tens' of the trouble code.
  • The fourth group of flashes indicate the 'units' of the trouble code.
  • A short pause separates each trouble code group.
  • A long pause separates each trouble code.
  • Switch ignition OFF.
ERASING:
  • Ensure accelerator pedal is fully released.
  • Ensure ignition switched OFF for at least 10 seconds.
  • Switch ignition ON - DO NOT start engine.
  • Wait 3 seconds.
  • Wait 7 seconds.
  • Fully depress accelerator pedal for more than 10 seconds.
  • Trouble code 0000 should be displayed.
Mine showed the code 0000 (10 flashes x 4 times) so didn't solve the problem I was looking for but at least I know all the sensors are working etc. smile.gif
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
pixel8r
post 17 Mar 2009, 10:32 PM
Post #2
VQ25DET
Real Name: Steve
Trader Rating : 0
Just realised the above is all in the manual. For those who dont know, you can find all of this an much more related info in the infinit G35 service manual which you can find online - do a google search. The infiniti G35 is what we know as the skyline V35. smile.gif
There's also more diagnostics for checking fault codes on other systems in the car too.
Profile CardPM
+Quote Post
andy65b
post 17 Mar 2009, 11:04 PM
Post #3
Group Icon
Car(s): NM35 Stagea ARX
Real Name: Andy
Trader Rating : 0
I managed to get it to work eventually for me and got 0000 also.
No closed to knowing why idle is 150rpm too high but I will start looking for leaks around the throttle body and a few other areas.
Andy
Xanavi Language Conversion Now Available
For more information contact:
NSW Andy 0425 260 014 (back home again)
or Craig 0406 754 304
VIC Rianto 0413 692 318
QLD Audio Express 07-3256-7741
or
CLICK HERE
WA Nigel 0408 628 323
SA Brad 0427 999 093
New Zealand Coming Soon
Profile CardPM
+Quote Post
zei20l
post 18 Mar 2009, 10:13 AM
Post #4
Rank: RB30E
Car(s): M35 Stagea 250t RX FOUR
Real Name: Iain
Trader Rating : 1
it was weird i tried that so many times and it didnt work on mine
QUOTE (zei20l)
When I get sad, I stop being sad and be awesome instead. True story!
QUOTE (zei20l)
I'm sorry, I can't hear you over the sound of how awesome I am!
Profile CardPM
+Quote Post
pixel8r
post 18 Mar 2009, 01:04 PM
Post #5
VQ25DET
Real Name: Steve
Trader Rating : 0
QUOTE (zei20l @ 18 Mar 2009, 10:13 AM) *
Did you get it to the point where the MIL start flashing?
Read below for the plain english version...(by me)...
You may need to use a stopwatch or something to count the seconds.
Turn ignition to ON (dont start engine).
Wait 3 seconds
Then over the next 5 seconds, push the accelerator all the way to the floor and then release it fully - do this 5 times quickly within these 5 seconds.
Then wait a further 7 seconds.
Now push the accelerator all the way to the floor again and hold it for 10 seconds until the MIL starts flashing.
When you see it start to flash after 10 seconds, release the accelerator straight away
the light should then keep blinking - giving you the fault codes. it will flash up 4 codes, pausing between each. it will blink slowly for the first group, then fast for the next 3 groups. 10 flashes in a group = '0'.
ie. code 0123 would be 10 flashes, pause, 1 flash, pause, 2 flashes, pause, 3 flashes, long pause, repeat...
turn the ignition to OFF when you're done - this will exit the diagnostic mode.
next time you start the car it will be back in the normal driving mode.
Profile CardPM
+Quote Post
Bis-e Bee
post 18 Mar 2009, 01:25 PM
Post #6
Group Icon
Car(s): Stagea M35/Skyline GXE3.0
Real Name: Stephen Wanless
Trader Rating : 0
Garage: M35 RS-Four, GSX750F
I just gave it a go myself, first time I didn't get it to work.
Then I closed the driver's door incase that had anything to do with it and when I counted the seconds I used the old school method (1001, 1002, 1003 etc.)
This is a good thing I assume!
Regards
Stephen
Nissan Stagea M35 2001 / Nissan Skyline GXE3.0 1989 / Suzuki GSX750F 2006
Profile CardPM
+Quote Post
GoldZilla
post 18 Mar 2009, 05:15 PM
Post #7
HULK MAD - AAAAARRRRGGGGHHH!!!
Group Icon
Group Icon
Group Icon
Car(s): Stagea RS-Four manual
Real Name: Nick T.
Trader Rating : 1
Garage: Stagea RS-Four V
Good work on this, I've added it to the Stagea DIY section under "ECU."
STAGEA: punching Volvo-shaped holes in the horizon...
Keep an eye on the SAU-NSW Events section for upcoming events - two more Texikhanas due for 2010, and a Wakefield Park day!
Profile CardPM
+Quote Post
zei20l
post 19 Mar 2009, 06:53 PM
Post #8
Rank: RB30E
Real Name: Iain
Trader Rating : 1
shit, maybe i had the door open at the time i was trying it lol
i dunno. and nah i got nothing at all on the dash. ill try it again later when i need it i think!
QUOTE (zei20l)
QUOTE (zei20l)
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 12th March, 2010 - 06:09 AM
