25 Sep 2007, 10:19 AM
![]() Rank: RB26DE ![]() Posts: 15,639 Joined: 27th June, 2002 Trader Rating : 11 |
Ok I recently became a victim of the dreaded cracked DBA 4000 rotor club. Wasn’t overly impressed as they were near new. But with the rotors on the bench and inspecting the rotors with DBA it appears as though there could be a fault with the caliper and the use of the rotor…combined with the fact they were used for a hard stop from over 200km/h when cold at an airport run. So looking at the rotor the outside face (the side that cracked) has obviously run hotter then the inside face. This is evident by the blue hue in the rotor face as well as the paint markings on the outside of the rotor where two of the three thermal paint stripes have been completely burnt off. All whilst the inside face is only on the middle temp paint with all three stripes still being visible and a shiny silver as you would expect. So, differential expansion as a result of a big temperature gradient hasn’t helped these rotors. Combined with the big hit of heat when cold. The rotors are off for some more testing and inspection. Will post up the feedback when I get it. But some things we all may want to check. Make sure your pistons are not dragging the pads on the rotor. This is a possibility in my application even though the calipers have been rebuilt. Perhaps where was a bit if run out (doubt it) or the design of thw wheel limits airflow to the outer face (doubt it) Most likely pistons rubbing the pad on the rotor a little, or when I jump on the brakes the outer pad works a lot harder then the inner pistons. Now finally, especially since its been a buzz topic lately. Be careful if you are going to be running brake ducts. I trialled some ages ago but took them off because I was not happy with them, and decided I would wait and do it properly when i get my new Brembos on. But if you are running DIY ducting ensure that the ducting is directed the centre of the rotor and the air then travels up through the vanes of the rotor. Simply ducting it towards the inner edge could lead to one side of the rotor (inner) running cooler then the outer face. This gives rise to differential expansion which is a known problem for stressing steel components. The main reason I removed my ducts was that I wasn’t satisfied that in the wet they woudlnt be guiding water/mist onto the inner edge causing massive temperature differentials and thermal shock to the rotor. I had not really considered that air itself could have resulted in a 200degC temperature differential across the rotor. -------------------- Minister of RB20 propaganda A Lifetime's Achievements Winton Lap Time: Blah, blah, blah Sandown Lap Time: Blah, blah, blah Phillip Island Lap Time: Blah, blah, blah Calder Lap Time: Faster then Scotchfinger |
25 Sep 2007, 12:47 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 224 Joined: 6th November, 2004 Trader Rating : 0 |
Yeh at the QR sprints very few seem to warm their brakes up at the start of the first lap, gives the transmission a chance to warm up a bit too if you take it easy for the first half lap or so.
-------------------- Richard..............
25 Sep 2007, 12:54 PM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,884 Joined: 14th July, 2003 Trader Rating : 11 |
I would be curious to see whther anyone has had their DBA4000 rotor crack from anywhere other than the small slots on the outside of the rotor.
25 Sep 2007, 02:04 PM
I would be curious to see whther anyone has had their DBA4000 rotor crack from anywhere other than the small slots on the outside of the rotor. Thats exactly what i told the guy when speaking to him . They are introducing a point of failure by running the slot to the outer edge. I dont see Alcon/AP/Brembp/Performance Friction etc etc doing that sort of slot arrangment on their street or competition rotors. My old set of DBA 4000 which lasted an eternity had the old slot design as well, (ie no little slot on outer edge) -------------------- Minister of RB20 propaganda A Lifetime's Achievements Winton Lap Time: Blah, blah, blah Sandown Lap Time: Blah, blah, blah Phillip Island Lap Time: Blah, blah, blah Calder Lap Time: Faster then Scotchfinger |
25 Sep 2007, 03:41 PM
Here are a couple I prepared earlier.
I was not running any ducting & the stone guards were in place. Rotors cracked on the outside. Note the rear failed completely & if you have a look at the front you can see the start of a crack propogating from the small slot. I don't think you need look any further than those slots to see what kills these rotors. Note that there was minimal wear on all of them, pads were RB74's & they got a bit warm as you can tell by the surface of the rotor. I have another dead one at home (a front) that is cracked through from the return slot.....If you have the ear of anyone at DBA tell them to bin the return slots. |
26 Sep 2007, 05:06 PM
I will dig up my crack....far, far , far worse then those. And it took no time at all to propogate into the hub.
Makes me wonder why DBA are only doing a limited run of these, curved vane with Alcon style slots. ![]() ![]() UAS have some for sale at the moment. If i didnt have the Brembos then i would grab some -------------------- Minister of RB20 propaganda A Lifetime's Achievements Winton Lap Time: Blah, blah, blah Sandown Lap Time: Blah, blah, blah Phillip Island Lap Time: Blah, blah, blah Calder Lap Time: Faster then Scotchfinger |
26 Sep 2007, 05:31 PM
#7
![]() doridori ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,756 Joined: 28th May, 2005 From: syd!! Car(s): ar furty for Trader Rating : 30 Garage: Skyline R34 GTX |
how much do are UAS doing a pair of front rotors for atm?
-------------------- WTB: pair 18x9/9.5" +15 to +25 offset, 5 stud Blitz Technospeed Z1
26 Sep 2007, 07:34 PM
#8
![]() DAVE-Teh-Mechanic ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 7,633 Joined: 1st May, 2005 Car(s): LAGMASTER Real Name: DAVE Trader Rating : 4 |
yes they are shit. there is to much chrome in the iron. we crack them every 2 race meeting. (v8 utes) they seriously are shit. end of story. they lasted longer with no ducting. no point blowing air on the inside when theres no flow on the outside. this creates unevan expansion and pop. they crack at the slots. usualy all of them. bloody rules...
-------------------- GET A V8 WTB: R32GTR ROLLING SHELL. REGISTERABLE. :) !!WTB: 38MM WATEGATE X2!! |
#9
as for the alcon slots? marketing.
26 Sep 2007, 09:57 PM
#10
![]() I dont know what i'm doing all i know is i dont want to stop ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 756 Joined: 29th November, 2004 From: Sydney Inner West Car(s): R32 GTR Real Name: Adam Trader Rating : 1 |
Environment: DBA4000s, DS2500s, MBF600, backing plates, UAS 324mm kit
Roy, i have the same problem with cooking the outside face of the rotor only. I also assumed it was stuck/dragging pistons and rebuilt the front calipers last weekend. I hope that wasn't a waste of time! Anyway, i'm going to Wakefield on the 8th for some 'testing'. I also noticed that it was a bit patchy and appeared worse between the 'vanes'. Perhaps the inside face of the rotor is pulling heat across from the outside face, thus cooling the area at the vanes better that the air in the between the vanes does. I should have taken a photo before sanding it off.... QUOTE or when I jump on the brakes the outer pad works a lot harder then the inner pistons Its hard to see how this could happen unless the inner pistons are stuck. Force = fluid pressure x area, which is the same on both sides. -------------------- I'm on the edge, shrinking back from the ledge Looking out my window, down upon my heritage Strip malls, thin walls, people paralysed beneath the sun Why me, why now? I see the dirty millions and I try to survive somehow......Rollins Band 238kw@13psi, exhaust, maybe cams, NISTune by GuiltT. 1.14.8 @ Wakefield (RaceChrono timed, Falken RT-615) 2.05.3 @ Eastern Creek (only got 9 laps in, then split an oil line and cracked a rotor....RaceChrono timed, Falken RT-615) |
26 Sep 2007, 10:16 PM
#11
QUOTE Makes me wonder why DBA are only doing a limited run of these, curved vane with Alcon style slots. I would guess the curved vanes provide more surface area and better fluid flow, so better cooling. Maybe the limited run is a beta test? as for the alcon slots? marketing. They're also copying what appears to be a better design - alcon thought well about stress concentration. -------------------- I'm on the edge, shrinking back from the ledge Looking out my window, down upon my heritage Strip malls, thin walls, people paralysed beneath the sun Why me, why now? I see the dirty millions and I try to survive somehow......Rollins Band 238kw@13psi, exhaust, maybe cams, NISTune by GuiltT. 1.14.8 @ Wakefield (RaceChrono timed, Falken RT-615) 2.05.3 @ Eastern Creek (only got 9 laps in, then split an oil line and cracked a rotor....RaceChrono timed, Falken RT-615) |
26 Sep 2007, 10:25 PM
#12
![]() ビール男爵 ![]() ![]() ![]() Posts: 19,412 Joined: 9th May, 2003 From: West Shinjuku MOS Burger Car(s): 32GTR 34GTR S13 Truck RX7 Real Name: Richard Trader Rating : 147 |
I hope they give up on the bloody "wiper slot" and "kangaroo paw" bullshit and keep making those curved vane one with the alcon style slots (or even normal slots).
-------------------- Beer Baron's Japan Photo Diary. CLICK HERE!
Now with 2007 Nismo Festival Pics :) AND now with Tsukuba Hyper Rev Super Lap battle pics too. 28/12/07 added more pic. Some Tokyo pics and Garage Saurus pics. :) My Super Clean Nissan Atlas 200 Truck for sale, feel the awesome 4.2ltr diesel power whilst comfortably transporting your goods! http://www.skylinesaustralia.com/forums/Be...as-t227090.html Selling my 2001, FD Mazda RX-7 limited edition RZ model, one of only 175 units ever made and the most desirable JDM RX-7. Fitted with a brand new built 13B engine and otherwise completely factory original with all factory RZ options. Going cheap to fun new project. CLICK HERE!!! |
#13
Its hard to see how this could happen unless the inner pistons are stuck. Force = fluid pressure x area, which is the same on both sides. yeh i get that but there is that part of me that thinks that because i run teh adpator brackets for the larger rotors that perhaps the caliper is slightly offset a mm or two?!?! So when you jump on the brakes that the rotor is being distorted and compressed against an off centre caliper. -------------------- Minister of RB20 propaganda A Lifetime's Achievements Winton Lap Time: Blah, blah, blah Sandown Lap Time: Blah, blah, blah Phillip Island Lap Time: Blah, blah, blah Calder Lap Time: Faster then Scotchfinger |
26 Sep 2007, 11:09 PM
#14
![]() Second-hand Performance Tyres. T&E Tools. PM me ![]() ![]() ![]() ![]() ![]() Posts: 314 Joined: 31st August, 2004 From: Brisbane Car(s): R32 GTR Real Name: John Trader Rating : 0 |
I'm not sure if the calipers being slightly off-set would or should be a prob, as long as they are still running square to the rotor. With all pistons sharing the same fluid circuit per caliper they should "sort themselves out" for want of a better term & simply travel as far as required per side/pad to deliver equal pressure to both sides of the rotor.
Also in regards to pad drag on the rotors, my Brembo 8's actually have springs fitted behind the pistons which acts to both minimise knock-off & provide just enough contact to build & keep enough temp in the pads & rotors that initial bite & thermal shock is never an issue. This allows me to run Hawk HT-10 compound pads with a temp window of 149 C - 871 C as a street pad with no issues or "oh f**k" moments. Literally takes less than 2k's of driving from dead cold to have usable heat with NO application to help it on it's way. It's obviously a different story if only one side of the caliper is dragging though........ |
27 Sep 2007, 09:35 AM
#15
![]() Jaded ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 8,185 Joined: 27th September, 2005 From: Sydney Car(s): R33 Real Name: Jon Trader Rating : 7 |
Would there be any noticeable pad wear from this? Obviously if there is friction to build up heat then it's wearing the pad (even if just slightly, its 100% of the time!). How quickly do you go through pads?
27 Sep 2007, 09:41 AM
#16
Harden up Roy, & get yourself some single piston callipers with slides.
27 Sep 2007, 10:38 AM
#17
![]() owner since '01 ![]() ![]() ![]() ![]() ![]() Posts: 1,673 Joined: 18th June, 2003 From: Brisbane Car(s): '93 HCR32 & '93 SSS Real Name: Mick Trader Rating : 22 |
As soon as i grab the adaptor brackets ill be doing this the 324mm conversion only with rda rotors. I have 324mm slotted only fronts and standard size slotted only rears.
Hopefully all goes well -------------------- |
28 Sep 2007, 10:41 PM
#18
Would there be any noticeable pad wear from this? Obviously if there is friction to build up heat then it's wearing the pad (even if just slightly, its 100% of the time!). How quickly do you go through pads? Mate to be honest I've only done a few thousand k's on this setup & I haven't had the pads out to take a look but once I do I'll post up the info. |
29 Sep 2007, 11:15 AM
#19
thats why "propper" motorsport discs are 500-750 each. cos they can actually take being red hot more than once.
30 Sep 2007, 05:02 PM
#20
![]() Plain Old Boring Old Bob ![]() ![]() ![]() Posts: 12,914 Joined: 29th November, 2003 From: Sydney Car(s): R34 GTT Real Name: Bob Trader Rating : 28 |
I've cracked 3 of them and always from that slot thingy.
So what's the alternative? DBA5000? Something else? Carbon ones? -------------------- 12.419 @ 110.53 - WSID
1:08.5 @ Wakefield Park 1:24.379 @ Oran Park Grand Prix 1:53.8 @ Eastern Creek Official SAU NSW Club Merchandise SAU Membership Form - Memberships FAQ Thread - CAMS Licence - L2S or L2NS - application form Compare your dyno results here. |
Lo-Fi Version | Time is now: 4th July, 2009 - 10:00 AM |
