IPB
> In Car Computer :d, Done!
parish
post 12 Jun 2006, 06:13 PM
Post #1
orsm-ma-ma-pawa
Car(s): R33 GTS-T
Trader Rating : 1
Hey hey,
Started this project a little while ago, and now that its done thought I'd put some pictures up...
Basically I originally wanted sat nav in the car, but when having a look at the prices I kinda thought that it was a bit much just for sat nav, and I checked out what other possibilities there were… GPS usb receivers smile.gif… I then decided that I’d just get a computer in the car and that could run everything, as in sat nav, music and whatever else (if there would be anything else)… Used the MP3Car forums heaps to get a good idea of how others had done it and designed my own little PC…
Hardware:
Via EPIA Mini ITX Motherboard (1.3Ghz)
M2ATX power unit
1Gb Ram
80Gb SATA Hard Drive
USB GPS Receiver
7” Touch Screen
Software:
Windows Xp
RoadRunner
FreeDrive
Winamp
Started off with the screen… I bought another dash surround so that I wouldn’t have to drive my car around for weeks/months without a dash biggrin.gif
7" Touch Screen 1
7" Touch Screen 2
7" Touch Screen 3
Took the screen apart so I could mould the front of it to the dash and once finished I could screw the rest of the screen straight to the dash, the idea was that I wanted it to look like one piece, and that the same time there is no way you could steal unless you broke the screen…
For it to fit nicely under the climate control I had to cut part of the dash at the bottom, also has to take a couple mm off each side.
Dash 1
Dash 2
Dash 3
Dash 4
Once I got it fitting nicely in the dash I used Araldite to glue it in and the used putty to bog up the sides and sand it back to make it look like one piece.
Dash 5
Dash 6
This came out pretty good, so I put it in for painting…
Painted Dash 1
Painted Dash 2
When I got the dash back, I popped the screen back into it and with the moving/playing around with the dash over the next couple days the front of the screen that was glued to the dash cracked and eventually with a little bit of force it came apart completely. Took some advise from someone in Bunnings and got it plastic welded to the dash… this time before I puttied it all up and made it look good again a gave it some severe testing to make sure it wouldn’t crack again (sorry no pics of this part…)
While the dash was getting re-painted I started to build the case. I wanted to build it in aluminium, but cost and putting it all together (or bending it) just put me off using it… I used persplex instead smile.gif
I wasn’t too sure where I wanted to have the case, couple of options… in the boot, under the seat behind the screen (in the dash)… Decided to go with fitting it under the seat, so I made a model of the case and had it under the seat until I realised that every time I went over a bump I could feel the case, so scraped that and decided to put it in the dash… Took the dash apart and again made a model of what I wanted it to be like and made sure everything fit nicely then made the case…
Case 1
Case 2
Case 3
Case 4
Note that its actually sitting the other way around now, can see this in a later pic…
At some point in time while I was making the PC I got the dash back…
Final dash
When I was happy that everything was going to fit nicely I finished the case and installed all the software on the machine… tested everything to make sure it would work. As I had the dash back and I’d put it all together I was running it on the 7” screen to see what it would give…
Case 5
Case 6
Case 7
Case 8
7" powered off car pc
Finally got to the stage when it was all ready to go in… spent a good couple hours messing around with it all to get it to fit like I wanted… (very tight fit ) cables everywhere in the pic but was nice and neat once it was all in…
mess!
Put the dash back in and bingo…
Final setup 1
Final setup 2
Pics aren’t the greatest and the glove box still on in on the pic… once I have given the interior a good clean might take a final pic and post it…
At the moment ironing out a few little issue… the main one is sound… playing only MP3s on the hard drive (have 2 USB ports so this is how I add music etc when needed)… the prob with MP3s are the recording levels they are recorded at.. some songs sound awesome, others sound like c#@p! just trying to find some other 3rd party software that will regulate the output of the sound… but yeah… apart from that everything is working sweet… biggrin.gif
Profile CardPM
Go to the top of the page
+Quote Post
Posts in this topic
- parish   In Car Computer :d   12 Jun 2006, 06:13 PM
- - Liiger   Simply awesome mate. Look forward to seeing what e...   12 Jun 2006, 06:41 PM
|- - parish   QUOTE(Liiger @ 12 Jun 2006, 04:41 PM) Sim...   12 Jun 2006, 06:45 PM
- - AlphA   Wow.. Thats awesome. Can you throw up some links ...   12 Jun 2006, 06:49 PM
- - bogcock   u could even use a velleman usb output card to use...   12 Jun 2006, 06:57 PM
- - Liiger   Few moe Q's if you dont mind. Where did you g...   12 Jun 2006, 07:07 PM
- - parish   Thanks for the replies Here are the links to the...   12 Jun 2006, 07:27 PM
- - Michael_1882   AWESOME!~ I love it   12 Jun 2006, 07:52 PM
- - Eug   top stuff.. i love the factory look... very very c...   12 Jun 2006, 08:41 PM
|- - parish   QUOTE(Eug @ 12 Jun 2006, 06:41 PM) if you...   13 Jun 2006, 01:48 AM
- - Primordial   Alternate power is hooking up your battery to a 12...   13 Jun 2006, 08:37 AM
- - Rekin   Where is your GPS receiver located? Doesnt it need...   13 Jun 2006, 02:18 PM
|- - Primordial   QUOTE(Rekin @ 13 Jun 2006, 02:18 PM) Wher...   13 Jun 2006, 03:32 PM
- - Alien   when you turn the car on, what happens? Do you hav...   13 Jun 2006, 02:22 PM
|- - Primordial   QUOTE(Alien @ 13 Jun 2006, 02:22 PM) when...   13 Jun 2006, 03:40 PM
- - parish   Primordial, never thought of that, but thanks that...   13 Jun 2006, 02:32 PM
- - Alien   how much did it all set you back? and how long did...   13 Jun 2006, 02:38 PM
- - parish   Alien, it was pretty labour intensive coz I pretty...   13 Jun 2006, 03:37 PM
- - Pulp   Hey Parish very nice mate! I'm going to b...   13 Jun 2006, 03:40 PM
|- - Primordial   QUOTE(Pulp @ 13 Jun 2006, 03:40 PM) Hey P...   13 Jun 2006, 03:46 PM
|- - Pulp   QUOTE(Primordial @ 13 Jun 2006, 01:46 PM)...   13 Jun 2006, 03:50 PM
- - Pulp   There's a little circuit board you can get, m...   13 Jun 2006, 03:48 PM
- - parish   Pulp, that little power unit i got does that... co...   13 Jun 2006, 04:20 PM
- - Rekin   I have a GPS receiver for my pda, and it doesnt pi...   13 Jun 2006, 04:29 PM
- - Primordial   yeah depends on the gain of antenna in the unit. I...   13 Jun 2006, 04:38 PM
- - parish   Primordial, I have to agree that the configuration...   13 Jun 2006, 04:40 PM
- - Medium Dave   Nice work parish, looks like a factory option - se...   14 Jun 2006, 12:45 PM
- - syx   I noticed you have a power fc, you gotta get this ...   14 Jun 2006, 12:46 PM
|- - Primordial   QUOTE(syx @ 14 Jun 2006, 12:46 PM) I noti...   14 Jun 2006, 12:56 PM
- - Primordial   Yeah ditto on the hard drives.. I've got two o...   14 Jun 2006, 12:51 PM
- - parish   Medium Dave, Thanks for the heads up on the HDD si...   14 Jun 2006, 04:57 PM
- - SuAvE-1   top set up man. good to see a few more people gett...   14 Jun 2006, 10:34 PM
- - parish   SuAvE-1, Thanks... For power i'm using a 12V D...   15 Jun 2006, 11:09 AM
- - Beauie   Great work, Love the factory look - Anyone done an...   15 Jun 2006, 05:16 PM
- - MANWHOR3   I've had my eye on doing this for a while. I...   16 Jun 2006, 01:19 PM
- - MANWHOR3   I've been reading on mp3 car for a while now. ...   16 Jun 2006, 01:19 PM
|- - parish   MANWHOR3, I have a friend who is setting up the US...   16 Jun 2006, 02:26 PM
- - Medium Dave   You can boot from a flash drive, there is a bit of...   16 Jun 2006, 01:28 PM
- - MANWHOR3   I'd be really interested if you could help me ...   16 Jun 2006, 02:22 PM
|- - hydie   QUOTE(MANWHOR3 @ 16 Jun 2006, 02:22 PM) I...   16 Jun 2006, 02:36 PM
- - MANWHOR3   the harddrive is the only thing that is turning me...   16 Jun 2006, 02:24 PM
- - SuAvE-1   sounds like a good idea to run off a flash drive.....   16 Jun 2006, 02:42 PM
- - Primordial   Super expensive compared the HDD tho... Its still ...   16 Jun 2006, 02:48 PM
|- - MANWHOR3   QUOTE(Primordial @ 16 Jun 2006, 02:48 PM)...   16 Jun 2006, 02:58 PM
|- - Primordial   QUOTE(MANWHOR3 @ 16 Jun 2006, 02:58 PM) I...   16 Jun 2006, 03:12 PM
- - hydie   while there is so many people in here, i will ask ...   16 Jun 2006, 02:49 PM
- - MANWHOR3   no good. Too big.   16 Jun 2006, 02:52 PM
|- - hydie   QUOTE(MANWHOR3 @ 16 Jun 2006, 02:52 PM) n...   16 Jun 2006, 02:57 PM
- - MANWHOR3   the motherboard and everything is too big. If you ...   16 Jun 2006, 03:00 PM
- - hydie   oh ok then, i get you now. do you think it would b...   16 Jun 2006, 03:07 PM
- - hydie   parish, where abouts did you get your lillyput scr...   16 Jun 2006, 03:22 PM
- - parish   HP have a piece of software... dunno what its call...   16 Jun 2006, 03:29 PM
- - parish   hydie, got it from e-Bay...   16 Jun 2006, 03:29 PM
- - syx   Go the usb external harddrive option and boot from...   16 Jun 2006, 03:49 PM
|- - Primordial   QUOTE(syx @ 16 Jun 2006, 03:49 PM) Go the...   16 Jun 2006, 03:55 PM
- - hydie   k well just had a quick look on eyo. and found thi...   16 Jun 2006, 03:51 PM
- - Michael_1882   By booting a OS up of a flash disk if runnign USB2...   16 Jun 2006, 04:14 PM
|- - Primordial   QUOTE(Michael_1882 @ 16 Jun 2006, 04:14 P...   16 Jun 2006, 04:18 PM
- - parish   The motherboard you were looking at is the same th...   16 Jun 2006, 04:16 PM
|- - hydie   QUOTE(parish @ 16 Jun 2006, 04:16 PM) The...   16 Jun 2006, 04:26 PM
- - hydie   just on ebay looking at harddrive now, wats the d...   16 Jun 2006, 04:17 PM
- - parish   Michael_1882, should boot up alot faster from what...   16 Jun 2006, 04:18 PM
- - Michael_1882   hmmmmmm great conflict of oppinion HAHAHAH hmmm i...   16 Jun 2006, 04:24 PM
- - parish   LOL... it just what I've been told... will let...   16 Jun 2006, 04:26 PM
- - Michael_1882   I'm really keen on running a two screen set up...   16 Jun 2006, 04:31 PM
|- - hydie   QUOTE(Michael_1882 @ 16 Jun 2006, 04:31 P...   16 Jun 2006, 04:47 PM
- - syx   I want to know whether its faster. The flash memo...   16 Jun 2006, 06:05 PM
- - MANWHOR3   I get what you're saying RE the usb key. but, ...   16 Jun 2006, 11:04 PM
- - kentenchi   QUOTE(parish @ 12 Jun 2006, 06:13 PM) Har...   17 Jun 2006, 03:49 AM
|- - Primordial   QUOTE(kentenchi @ 17 Jun 2006, 03:49 AM) ...   17 Jun 2006, 03:57 PM
|- - hydie   QUOTE(Primordial @ 17 Jun 2006, 03:57 PM)...   17 Jun 2006, 05:42 PM
|- - Primordial   QUOTE(hydie @ 17 Jun 2006, 05:42 PM) with...   17 Jun 2006, 07:46 PM
- - mikymouse   Just run everything off a large laptop hdd. Make a...   17 Jun 2006, 01:00 PM
- - Liiger   kentenchi: Check this one out. http://cgi.ebay.co...   17 Jun 2006, 02:15 PM
|- - Primordial   QUOTE(Liiger @ 17 Jun 2006, 02:15 PM) I...   17 Jun 2006, 04:00 PM
- - Michael_1882   Hey Jon, i remeber when i was in your car and your...   17 Jun 2006, 07:51 PM
|- - Primordial   QUOTE(Michael_1882 @ 17 Jun 2006, 07:51 P...   17 Jun 2006, 08:26 PM
- - hydie   hey guys, well im also a member on NS. and found t...   17 Jun 2006, 08:32 PM
- - Michael_1882   Thanks Jon, Thats helps heeps, how sensitive are ...   17 Jun 2006, 09:10 PM
- - Primordial   well you'd be best off getting a directional m...   17 Jun 2006, 09:51 PM
- - Michael_1882   Hmm yeah i thought that would be the case, it...   17 Jun 2006, 10:04 PM
|- - Primordial   QUOTE(Michael_1882 @ 17 Jun 2006, 10:04 P...   19 Jun 2006, 09:00 AM
- - MANWHOR3   Primordial. Looks like I might have more time than...   18 Jun 2006, 10:13 AM
|- - Primordial   QUOTE(MANWHOR3 @ 18 Jun 2006, 10:13 AM) P...   19 Jun 2006, 08:38 AM
- - Crimpage   All this stuff is unreal! Almost want to sell...   18 Jun 2006, 10:26 AM
|- - Primordial   QUOTE(Crimpage @ 18 Jun 2006, 10:26 AM) A...   19 Jun 2006, 08:46 AM
- - siksII   hey guys what you have done looks awesome, i have ...   18 Jun 2006, 10:51 PM
- - Rekin   Destin*tor maps: http://rapidshare.de/files/950115...   19 Jun 2006, 12:58 PM
|- - Primordial   QUOTE(Rekin @ 19 Jun 2006, 12:58 PM) Dest...   19 Jun 2006, 01:30 PM
- - thrtytwo   wow that is awesome, you did a wikkid job mate ...   19 Jun 2006, 03:12 PM
- - Rekin   With Destinator PN for the PDA, a program installs...   19 Jun 2006, 04:58 PM
- - Primordial   OIC.. makes sense.. I though that Destinator PN ...   19 Jun 2006, 05:03 PM
- - Rekin   Im using the same Australia maps for both Destin*t...   19 Jun 2006, 05:15 PM
- - d0p3y   Hey! Nice work! Just wondering - did you ...   21 Jun 2006, 09:47 AM
- - parish   d0p3y, yeah, thought about it, but for the moment ...   21 Jun 2006, 02:36 PM
- - d0p3y   Might think about one of these as a project myself...   22 Jun 2006, 03:05 PM
- - Primordial   The system I'm running has the best of both wo...   22 Jun 2006, 03:15 PM
- - Michael_1882   Jon- thats exactly what i was thinkgin abotu doing...   22 Jun 2006, 09:22 PM
- - linxus40   for gps software for pda's i prefer tomtom. ea...   22 Jun 2006, 10:54 PM
- - syx   QUOTE(Michael_1882 @ 22 Jun 2006, 08:52 P...   23 Jun 2006, 11:37 AM
2 Pages V   1 2 >
Reply to this topicStart new topic
0 Members:
RSS Lo-Fi Version Time is now: 10th September, 2010 - 05:04 AM
