IPB
8 Pages V   1 2 3 > »
Digg this topic · Save to del.icio.us · Slashdot It · Post to Technorati · Post to Furl · Submit to Reddit · Share on Facebook · Fark It · Googlize This Post · Add to ma.gnolia · Tag to Wink · Add to MyWeb · Add to Netscape Closed TopicStart new topic
> 200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension, Group Buy with SK’s settings
Sydneykid
post 25 Jan 2007, 03:19 PM
Post #1
RB31DET
Group Icon
Trader Rating : 49
I have just finished the engineering for Jamex on the 200SX S15 Bilstein and Whiteline Suspension kits. These have been extensively road and track tested over the last 4 months in three S15’s. Similar to what I did for R32/33/34’s, they will be offered on a Group Buy from Jamex for 15% to 20% less than the recommended retail prices, plus freight will be free for all orders over $500, plus there will be an additional discount of 5% for orders over $1,000.
The Group Buy kit was engineered (by me) to give a sporty, but not harsh ride, for the street and at the same time suite the sort of things that S15’s owners use their cars for (road, drag and circuit). It’s a great all round kit judging by the comments back from the people that have tried it.
Due to the strut based front end there will be a basic kit with Whiteline coil springs. Plus a full height adjustable coil over kit utilising Eibach (the best) coil springs with Noltec adjustable strut tops as an option. Extensive engineering has been carried out on a full replacement coil over front strut which features a unique Bilstein shock absorber. Plus it allows greater scope for camber adjustment combined with the use of wide wheels and tyres.
Front Bilstein inserts and rear shocks
Front fabricated strut with the Bilstein insert
Rear Bilstein shock with Whiteline spring
Picture of Bilstein/Eibach rear coil over spring/shock unit
Picture of the Noltec adjustable strut top
Rear Camber Kit
Front Caster Kit
In all cases the Bilstein damper valving has been selected (by me) to suite the spring and stabiliser bar rates used. I have spent some time engineering in an additional 20 mm (23 mm at the wheel) front suspension travel to avoid one of the major limitations of the packaging in an S15. This means I could use a lower spring rate for better handling and ride and, at the same time avoid the bottoming out issues that frequent lowered S15's The Bisltein front struts incorporate an internal bump stop which has been rated and sized to suite the rest of the kit. For better control of dynamic camber and caster, the Bilstein front inserts feature the inverted layout which results in far stronger resistence to the bending forces that struts have to endure.
The rear Bilsteins are of course full shock replacements and the Whiteline Bump Stop & Dust Cover kit has suggested trimming heights as follows;
There is a full set of suggested alignment settings (including ride heights) for both road and track use, which are designed to optimise the handling and avoid excessive tyre wear.
Table of alignment settings
Recommended Road Settings
Front
Caster = 7 degrees positive (slightly more on the LHS to counter the drift to the gutter)
Camber = 1.25 to 1.5 degrees negative
Toe = Zero
Rear
Camber = 0.75 to 1.25 degrees negative
Toe = In 2 mm each side
Recommended Circuit (grip) Settings
Front
Caster = 8 to 9 degrees positive
Camber = 2.5 to 4.0 degrees negative
Toe = Zero
Rear
Camber = 1.25 to 2.0 degrees negative
Toe = Zero
Recommended Drift Settings
Front
Toe = Zero to 1 mm toe out each side
Rear
Camber = 0.75 to 1.0 degrees negative
Toe = Out 2 mm each side
Recommended Drag Settings
Front
Toe = Zero
Rear
Camber = 0.25 positive to zero degrees (never negative)
Toe = Zero
Price Lists
The Road Kit is designed for daily sporty driving and is suitable for occasional circuit, drag and drift work. Although an upgrade to adjustable stabiliser bars would be recommended for those willing to tune the handling for their personal preferences.
The price lists reflect a saving for SAU Group Buyers of $678 (around 25%) over normal retail prices.
The Road & Track Kit is suitable for road driving, to and from the track and other weekend work. Several of the guys during the testing have commented that they could easily live with the Competition Kit as a daily driver. The stabiliser bars are, of course, adjustable, plus the springs and damper rates are not in any way excessive. The recommended alignment settings are a bt extreme for daily driving and would result in excessive tyre wear if large numbers of kilometres are driven. The Road & Track Kit is priced the same for Drag, Circuit (grip) and Drift users. The spring, shock and stabiliser bar rates being the difference. So please specify your usage patterns when ordering.
The price lists reflect a saving for SAU Group Buyers of $1,215 (around 25%) over normal retail prices.
Availability
Springs are usually in stock at Whiteline and Eibach
Bilstein takes 1-2 working days to fit the inserts
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
Recommended Fitting Workshops
Heasmans Sydenham NSW
East Coast Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Exceller Steering Bankstown NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Manta Racing Services SA
Discount Tyres Service Belconnen Act
Motsons Qld
Wilkinson Suspension WA
As per the Skyines Group Buy, you can choose individual parts or groups of parts, just keep in mind the free freight for orders over $500 and the extra 5% discount for orders over $1,000.
Any questions? Send me a PM or post it here.
PS; The S14 Group buy kits are now open, for S13 (CA & SR) owners, their kits are currently being engineered and will be released shortly
Yes, SK is back from the sabbatical.
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
PT
post 31 Jan 2007, 08:14 PM
Post #2
Car(s): S15
Trader Rating : 7
prices??
Profile CardPM
+Quote Post
Busky2k
post 2 Feb 2007, 10:54 PM
Post #3
Captain Boostin'
Car(s): S14.5 200SX
Trader Rating : 1
Ah damn SK. I wish I knew you were going to develop something for the Silvia chassis! Bah splurged a heap of cash on some Zeal coilovers only a few months ago (mainly to address the issue of lack of front suspension travel). What spring rates have you decided to go with?
PS If you have this going on ns.com it would be hot cakes... if you need assistance I'll be happy to as I am a sponsor mod.
In search for the ultimate in response and power...
Profile CardPM
+Quote Post
madgrk
post 3 Feb 2007, 07:56 AM
Post #4
Rank: RB20DET
Car(s): S14a 200SX
Real Name: Theo
Trader Rating : 0
I too am interested in this setup, as I'd rather a well setup coil and shock than all the fancy height/damper/rebound/kite flying stuff that some other designs have. I'll only want to set the height once, then leave it at that.
I've got this thread to remind me when someone replies so I can monitor it, I look forward to seeing prices etc for the S14's!!
Cheers,
Theo
Profile CardPM
+Quote Post
Sydneykid
post 5 Feb 2007, 05:40 PM
Post #5
RB31DET
Group Icon
Trader Rating : 49
Just waiting on the last of the prices to come through. They will be in the designated place in the #1 post.
Profile CardPM
+Quote Post
Paragon
post 5 Feb 2007, 06:31 PM
Post #6
Car(s): s15
Trader Rating : 0
Dude just in time was about to order some HKS Performers! How do you think ur package will compare with these (6/4 rates) on a hard driven street car with an occasional track day?
Profile CardPM
+Quote Post
Sydneykid
post 6 Feb 2007, 10:21 PM
Post #7
RB31DET
Group Icon
Trader Rating : 49
QUOTE(Paragon @ 5 Feb 2007, 07:31 PM) *
Based on the results of the guys currently using it, the kit will piss all over any Jap suspension. Road or track. Ask around and you will find that I don't exagerate.
Profile CardPM
+Quote Post
Puku
post 9 Feb 2007, 09:45 PM
Post #8
Rank: RB20DE
Car(s): S15
Real Name: Peter
Trader Rating : 0
Also registering my interest. I'm in the market for a new suspension for my s15
Profile CardPM
+Quote Post
Hans13
post 10 Feb 2007, 11:30 AM
Post #9
Rank: RB20E
Car(s): s13
Real Name: han
Trader Rating : 0
hmm waiting for s13 biggrin.gif and also est of prices ...
Profile CardPM
+Quote Post
ansch
post 13 Feb 2007, 02:23 PM
Post #10
Rank: RB20DET
Trader Rating : 0
looking forward to this.. any thought on how they will compare to the Tein superstreet tuned for australian roads?
Profile CardPM
+Quote Post
AlexCim
post 13 Feb 2007, 03:56 PM
Post #11
Rank: RB30E
Trader Rating : 9
drift?
Profile CardPM
+Quote Post
Dim1
post 15 Feb 2007, 04:51 PM
Post #12
Rank: RB20DET
Trader Rating : 0
QUOTE(AlexCim @ 13 Feb 2007, 04:56 PM) *
drift?
i also have the same question with a bit more detail behind it.
i have a s13, which i use as my daily but also drift on track. would the s13 setup be adequate for drifting ? or is it to soft/ more street based? any idea on the spring rate?
id much prefer to buy a set of these over hsd etc.
thanks
Profile CardPM
+Quote Post
Sydneykid
post 16 Feb 2007, 04:35 PM
Post #13
RB31DET
Group Icon
Trader Rating : 49
Yes, there will be a kit specifically engineered for drift. It will feature larger adjustable stabilsier bars, which means you won't have to put up with excessive oversteer when not drifting.
Yes, there will be specific recommended drfit alignment settings.
Profile CardPM
+Quote Post
Hans13
post 17 Feb 2007, 10:16 AM
Post #14
Rank: RB20E
Car(s): s13
Real Name: han
Trader Rating : 0
so a street and drift one..?
Profile CardPM
+Quote Post
Mr_G
post 17 Feb 2007, 10:54 PM
Post #15
Trader Rating : 13
Need front mount installed? Got r32/33/34? Dont want to travel? Ill come to you (Syd Only) and install @ compeititve price, with A+ Job. PM me for details, or email me: write2_jason@hotmail.com
Profile CardPM
+Quote Post
Dim1
post 18 Feb 2007, 03:31 AM
Post #16
Rank: RB20DET
Trader Rating : 0
QUOTE(Sydneykid @ 16 Feb 2007, 05:35 PM) *
i already got a set of adjustable swaybars, but id defenitly be keen on a set of shocks/springs for a s13, the sooner the better as my shagged coilovers are in desperate need of replacment.
Profile CardPM
+Quote Post
sakobato
post 20 Feb 2007, 07:16 AM
Post #17
Rank: RB20E
Car(s): S15
Trader Rating : 0
QUOTE(Busky2k @ 2 Feb 2007, 10:24 PM) *
PS If you have this going on ns.com it would be hot cakes... if you need assistance I'll be happy to as I am a sponsor mod. [/size]
^ I can confirm the interest!
I just heard about this on ns.com and am very interested, pending pricing.
Profile CardPM
+Quote Post
phunky_monkey
post 20 Feb 2007, 03:30 PM
Post #18
Rank: RB30E
Group Icon
Car(s): 180sx, MY06 STi
Trader Rating : 5
Possibly interested in an S13 track biased setup if one becomes available smile.gif
Dane
Widebody 180sx
IPB Image
Profile CardPM
+Quote Post
Sydneykid
post 21 Feb 2007, 12:42 PM
Post #19
RB31DET
Group Icon
Trader Rating : 49
Last prices due in today, so the S15 kits should be posted up late tonight.
Profile CardPM
+Quote Post
eron
post 21 Feb 2007, 04:56 PM
Post #20
Rank: RB20DET
Car(s): silvia
Trader Rating : 0
QUOTE(Sydneykid @ 21 Feb 2007, 01:42 PM) *
Good, I've been waiting for 4 months.
Detail Addiction
Simply obsessive.
Profile CardPM
+Quote Post
8 Pages V   1 2 3 > »
0 Members:
RSS Lo-Fi Version Time is now: 5th July, 2009 - 02:01 AM
