IPB
9 Pages V   1 2 3 > »
> Buyer's Guide - The Nissan C34 Stagea, A helpful guide for new Stagea buyers!
GoldZilla
post 22 Oct 2005, 07:01 PM
Post #1
HULK MAD - AAAAARRRRGGGGHHH!!!
Group Icon
Group Icon
Group Icon
Car(s): Stagea RS-Four manual
Real Name: Nick T.
Trader Rating : 0
Hello all,
As I've mentioned in previous threads, here is a "STICKIED" link to all your Stagea buying tips on what to look for, and most of the stuff you will find useful in making your choices!
Anyone can add to the thread, and I will make an effort to regularly add all of the most important stuff to this first post so potential buyers don't have to read the whole lot to get the information they need. Oh, and if I get something wrong, please let me know...
So, here goes:
BODYWORK AND CHASSIS
Check for:
* Rust and/or paint bubbling and peeling under the door wing mirrors;
* Rust around the strut towers, where the strut tower brace is bolted down;
* Rust and/or paint bubbling and peeling in and around the sunroof runners (if fitted with a sunroof);
* Condition of door seals and rust where the seals attach to the body;
* Rust on the door and boot hinges;
* Rust in the spare wheel cavity...
Body Dimensions:
* Exterior Dimensions (LxWxH), mm: 4800 x 1755 x 1495
* Wheel base, mm: 2720
* Track (F/R), mm: 1460 / 1515
* Ground clearance, mm: 145
* Curb vehicle weight, kg: 1620-1660
* Seating capacity, persons: 5
* Doors number: 5
* Min.turning radius, m: 5.3
* Fuel tank capacity, l: 68
ENGINE & DRIVELINE
Check for:
* Is the colour of the oil a really dark brown? (Worse still, if it's whitish, see the next point) If the oil is dark brown and really thick instead of smooth and runny, then it may indicate that it hasn't been changed in a while, or that there is excessive engine wear.
* Water in the oil (is the oil under the cap milky and white, instead of a darkish brown? This could indicate a blown head gasket, or worse);
* Bubbles in the radiator fluid (obviously, check this when the engine is still cold, usually just after you've started it);
* Is the idle smooth? This could be a minor issue with some loose/damaged vacuum hoses, but it also could be a lot worse...
Engine Specs - Series I (1996 - July 1998). This is for the 25t RS-Four, as the most commonly seen version here in Australia:
* RB25DET engine, 2.5 litres, DOHC, 24-valve, turbocharged, same basic specs as a series II R-33 Skyline GTS25t;
* 173kW @ 6400rpm, 275Nm @ 4800rpm - figures quoted are at the flywheel;
* E-AT Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter;
* ATESSA-ETS electronically-controlled four wheel drive... There was no manual option in the Series I.
Engine Specs - Series II (August 1998 - 2001). Once again, this is for the 25t RS-Four.
* RB25DET Neo engine, 2.5 litres, DOHC, 24-valve, turbocharged, same basic specs as an R-34 Skyline GTt;
* 206kW @ 6400rpm, 333Nm @ 3200rpm (or 343Nm @ 3200rpm in RS-Four S manual) - figures quoted are at the flywheel;
* E-ATx Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter; or
* M-ATx E-AT Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter and Tiptronic function; or
* 5-speed manual
FACTORY FEATURES AND OPTIONS
All Stageas have:
* Power windows;
* Power mirrors (including a fold-in feature for parking in tight spaces);
* Driver's and Passenger's SRS airbags;
* Roof rails;
* Reclinable and fold-down (by use of a nifty handle in the luggage bay) rear seats, with a centre fold-down arm rest;
* Climate control air-conditioning;
* Electronic odometer and dual trip-meters;
* Various hooks and tie-down points in the luggage bay so your cargo doesn't go flying around;
* Tilt-adjustable steering column;
* 12v lighter socket in the rear luggage area;
* Leather steering wheel;
* Front fog lamps;
* Front, variable intermittent windscreen wipers;
* Rear window wiper;
* Front spoiler;
* UV-cutting glass (front doors and windscreen) - all models;
* Dual cup-holders in the dashboard;
* Keyless entry;
Commonly fitted Optional Extras include:
* Front centre arm rest, some of which can be opened towards either the driver or passenger;
* Luggage bay roll-out cover;
* Luggage bay safety net;
* Privacy glass (rear doors and rear luggage area) - RS models and above;
* Dual sunrooves (front one is tilt and slide, rear is a slide-only);
* Electric, self-closing rear door (boot)...
Other, less common Stagea Optional Extras include:
* Leather seats and interior trims;
* Electric seats (only available with the leather option)...
* Extra 12v bayonet-style sockets on the left side of the luggage area, the inside of the luggage area door and the D-pillar for bayonet-fit accessories such as a torch, etc.;
* Limited Slip Differential (manual RS Four S models)
CHASSIS CODES
Model:......................Driveline:...............Engine:..............Chassi
Code:
RS Four S..................AWD manual..........RB25DET Neo......WGNC34
RS Four V..................AWD......................RB25DET............WGNC34
RS Four.....................AWD......................RB25DET............WGNC34
RS............................RWD......................RB25DET............WGC34
25X Four...................AWD.......................RB25DE.............WGNC34
25G Four...................AWD.......................RB25DE.............WGNC34
25X..........................RWD.......................RB25DE.............WGC34
25G..........................RWD.......................RB25DE.............WGC34
20G..........................RWD.......................RB20DE.............WHC34
So, basically, when it comes to model spec, "RS" is anything turbo, "RS Four" is turbo AWD, "Four" is any AWD, and "RS Four S" is turbo AWD with manual (series 2 only, and there were NO turbo RWDs).
As far as chassis codes, series 1 all had an "E-" prefix (such as E-WHC34), and series 2 all had the "GF-" prefix (such as GF-WGNC34).
WHC = RB20DE power (the lowest model and in one spec level and RWD only)
WGC = RB25DE or RB25DET power, and RWD only
WGNC = RB25DE or RB25DET power, AWD.
So, H = RB20 power, G = RB25 power, and GN = RB25 + AWD.
All this info was found RIGHT HERE, and I will update the first post when I have time with more specific details regarding release dates, spec levels, and options.
COLOUR AND TRIM
Exterior Colours:
* Bayside Blue (TV-2)
* Sonic Silver (KR-4)
* Black Pearl (GV-1)
* Lightning Yellow (EV-1)
* Sherwood Green Pearl (DR-2)
* Active Red (AR-2)
* White Pearl (QT-1)
Want a Skyline? Need a wagon? Get a Stagea! Spotted one? Post here!
Have you got merchandise ideas for SAU? Click here!!!
Do you WANT SAU merchandise? Click here!!!
Not an SAU-NSW member? Got questions? Want to join?
SAU-NSW Texikhana #2
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
AlexCim
post 7 Nov 2005, 08:19 AM
Post #2
Rank: RB30E
Trader Rating : 9
"* Electric, self-closing rear door (boot);"
Not true, mine doesnt have this. I took off the rear trim on the boot to check too, couldnt see any motors or anything back there...
Profile CardPM
+Quote Post
GoldZilla
post 9 Nov 2005, 01:39 AM
Post #3
Group Icon
Group Icon
Group Icon
Real Name: Nick T.
Trader Rating : 0
Really?
Edited, then...
I've split them up into "Commonly seen options."
Thanks for that, Alex.
Nick T.
Profile CardPM
+Quote Post
AlexCim
post 9 Nov 2005, 08:57 AM
Post #4
Rank: RB30E
Trader Rating : 9
Yes, i have a feeling mine is pretty base line
No electric boot
No interior options (though, i find the std stereo speakers really good compared to other cars ive listened in...could have been changed, havnt looked)
No body kit at all (at least i got the lower front lip)
Profile CardPM
+Quote Post
Terminal
post 9 Nov 2005, 09:34 AM
Post #5
Speed... I am Speed
Group Icon
Car(s): VT Commonbore Wagon
Real Name: Leshy
Trader Rating : 8
I know the Series 1 RS Four comes with 15" Wheels and the RS Four-V comes with 16" wheels.
Also, the RS Four-V comes with the double din CD/Cassette player, while the RS Four only has the Cassette/Radio
These are the 2 main ways to tell the RS Four and the RS Four-V apart
I have factory tweaters in the A-columns, which isn't a standard feature
I've also just been made aware Series 2 RS Four come standard with Xenon headlights. Does someone with an S2 want to confirm this?
Profile CardPM
+Quote Post
Tangles
post 9 Nov 2005, 09:47 AM
Post #6
Rank: RB30ET
Group Icon
Car(s): Nissan Stagea RS-Four V
Trader Rating : 11
Great info ppl's! Never knew I had a RS Four-V...... got all the standard features and all the Optional Extras.
Plus I got the rust by the mirrors on both front doors, but none elsewhere from what I can tell.
For Sale - 555cc RB25Det injectors. Brand New In Box. $480 Firm
For Sale - R34 GTT 17" Rims $300
http://www.skylinesaustralia.com/forums/Fs...91#entry4092091
For Sale - K&N Pod Filter with Z32 adapter $50
Fore Sale - Hybrid dual-stage hi/low EBC $150
http://www.skylinesaustralia.com/forums/Fs...ri-t233699.html
Profile CardPM
+Quote Post
AlexCim
post 9 Nov 2005, 10:16 AM
Post #7
Rank: RB30E
Trader Rating : 9
Well, i got the RSFour then
Stupid Vicroads put my vehicle tare mass at 1350. Annoying when there are p plater power-to-weight laws here in Victoria, when the car really weighs ~1600kg
Profile CardPM
+Quote Post
Terminal
post 9 Nov 2005, 12:02 PM
Post #8
Speed... I am Speed
Group Icon
Real Name: Leshy
Trader Rating : 8
At least you're not in NSW, you wouldn't be able to drive it at all
Profile CardPM
+Quote Post
-FUZZY-
post 9 Nov 2005, 12:32 PM
Post #9
RB25DET
Car(s): STAGEA
Trader Rating : 1
Some Stagea Reviews from magazines contained in this link.
http://www.skylinesaustralia.com/forums/in...showtopic=91842
I got the electric self closing boot option, and roll cover. But no net. Actually thinking of getting a cage like u can get for commo's and fords due to safety reasons.
Also got the rust under the mirrors ... well for another 2days then it'll be gone!! biggrin.gif
Profile CardPM
+Quote Post
Tangles
post 9 Nov 2005, 12:41 PM
Post #10
Rank: RB30ET
Group Icon
Trader Rating : 11
Cages are dangerous, ie if you or a child is in the boot and the door closes...... a child could die, due to the heat buildup in our Aussie summer.
Make sure you get an 'approved' safety cage if thats the way you want to go.
I think forum member GTR Familia was selling cargo barriers at one stage?
Profile CardPM
+Quote Post
Terminal
post 9 Nov 2005, 12:52 PM
Post #11
Speed... I am Speed
Group Icon
Real Name: Leshy
Trader Rating : 8
Yeah i bought a set of cover and netting off him. works wel, you can mount them a few different ways depending on what you're putting in the back
you can set it up a way so you can have a bit of a parcel shelf for kids to put books/pillows or whatever on. pretty useful and multi purpose
Profile CardPM
+Quote Post
AMS
post 9 Nov 2005, 02:23 PM
Post #12
Advanced Motorsports
Group Icon
Car(s): S13 Onevia RB20DET
Real Name: Chris
Trader Rating : 1
QUOTE(Terminal @ 9 Nov 2005, 12:02 PM)
Profile CardPM
+Quote Post
AlexCim
post 9 Nov 2005, 03:04 PM
Post #13
Rank: RB30E
Trader Rating : 9
That because you bought the car before the new laws came into effect?
Profile CardPM
+Quote Post
AMS
post 9 Nov 2005, 03:48 PM
Post #14
Group Icon
Real Name: Chris
Trader Rating : 1
Nope, because my parents own businesses smile.gif I have a business exemption ^_^ Its a business car...*cough*... wink.gif
Profile CardPM
+Quote Post
Terminal
post 10 Nov 2005, 11:04 AM
Post #15
Speed... I am Speed
Group Icon
Real Name: Leshy
Trader Rating : 8
hey, i tried that, and i got pinged with a $99 parking in loading zone fine, they didn't believe i was on business, which i was... lowsy parking guys
Profile CardPM
+Quote Post
Red Sky II
post 10 Nov 2005, 11:53 PM
Post #16
1998 Stagea RSFour
Car(s): 1998 Stagea RSFour SII
Real Name: Alan
Trader Rating : 0
QUOTE(Terminal @ 9 Nov 2005, 07:34 AM)
Confirm that Series 2 comes with Xenon headlights, well at least mine has and most others I have seen appear to have Xenons as well. Also got the auto boot closure thing too.
[LEFT]SAUWA Member #20[/LEFT]
Profile CardPM
+Quote Post
GoldZilla
