8 Oct 2005, 11:54 PM
![]() rb25 > rb20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 23,194 Joined: 18th November, 2002 From: Goldcoast Real Name: Gordon Trader Rating : 36 |
I have placed up a full tutorial on this, from start to finish.. This question gets asked regularly, so it was about time *somebody* did it and wrote up exactly how they did it..
Due to the server here always losing my images for any period of time, I've decided to put it all on my project website.. http://www.project32.net/tutorials.php Photos aren't actually up yet as I am still resizing, etc (and there are quite a few)... but for now you can read through. They will be up in a few days. cheers, Gordon -------------------- r32 for speed
ls400 - just like a politician - all torque and no action |
16 Jan 2007, 07:45 AM
4dr 32 ![]() ![]() ![]() ![]() ![]() Posts: 866 Joined: 22nd November, 2004 From: Newcastle,NSW Trader Rating : 3 |
I just used predator's guide yesterday and did my conversion. I just thought I'd post a few things that I have found.
Predator, feel free to use them in your guide if you agree. 1) Drop the coolant in the normal fashion before un-doing the water lines on the turbo (so drain from radiator) You are going to lose it all anyways, this way it's not as messy 2) I had to change water lines (89 GTST 4 door) and I can now tell you how you can work it out BEFORE you go to all the effort. Predator pointed out you need a 24mm socket for the water lines...well mine were 22mm, which obviously means it was a different size! So... you just need to get to the water lines and see what size socket it is. You still will have to remove the intake pipe, but it's only a 15 minute job to check to save you either stress or money about if you will need them. 3) I put the nipple onto the compressor housing and it is working fine. So if you are likely to change FMIC pipes it may be a better option *shrugs* up to you, apparently there is no performance difference by putting it in either spot. 4) Clean your water lines while they are out (if you take them out) Cheers Chris |
4 May 2007, 09:06 PM
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 773 Joined: 1st January, 2005 From: STIX Car(s): R32 GTS-t Real Name: Simon Trader Rating : 3 |
i went off this guide its great so helpfull good job mate. i found that to get that tricky line off close to the engine where you had to take it off the block instead. you can take that oil line off next to it the rollercoaster one like a loop d loop! and you can undo that water line off the turbo instead of taking the whole line off the car.
-------------------- MY 32 FOR SALE BUY IT!!!
http://www.skylinesaustralia.com/forums/in...howtopic=180523 |
4 May 2007, 09:18 PM
![]() 97r33gtst-typeM ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,757 Joined: 18th April, 2004 Trader Rating : 23 |
i went off this guide its great so helpfull good job mate. i found that to get that tricky line off close to the engine where you had to take it off the block instead. you can take that oil line off next to it the rollercoaster one like a loop d loop! and you can undo that water line off the turbo instead of taking the whole line off the car. BINGO! that's spot on the money. that's the way i do them too. It's easy to get the line off from under the car once you take the oil line off. you don't even have to take the oil line off - you can do it with the oil line on, but it makes it a lot easier. -------------------- For Sale:
vg turbo housings (suit highflow) $350 rb25 turbo housings (suit highflow) $150 torque wrench $20 |
5 Jul 2008, 11:56 PM
Rank: RB25DE ![]() ![]() ![]() ![]() ![]() Posts: 133 Joined: 20th October, 2007 From: Sydney Car(s): 32gtst Real Name: Scott Trader Rating : 4 |
hey just did this a couple of hours ago
few things i noticed make sure u take off the oil return first, i forgot all about that until i went to take if off the car, i left the dump pipe on the turbo and just undid the 3 bolts going to the front pipe, then when i installed it, i put the turbo back in the car with my new just jap split dump and front pipe attached to it, the stupid line at the back of the turbo i could get a spanner on, yet couldnt be stuffed turning it that many times to get it off, so i undid the turbo from the manifold, carefuly slid it forward then used a socket and ratchet to take the line off, put it back on that way to (ratchet on, then bolt turbo to manifold) i also took the actuator off the turbo while still in the car also when i undid the oil drain, i undid the 2 12 mm bolts off the turbo instead of the flexible pipe |
5 Aug 2008, 07:49 PM
Rank: RB25DE ![]() ![]() ![]() ![]() ![]() Posts: 166 Joined: 19th November, 2006 Trader Rating : 4 |
Just a quick question can you do the same upgrade with a R34 turbo onto RB20
Like do the oil / water lines fit and does the dump pipe bolt straight up? Any help would be greatly appreciated thanks in advance. |
6 Aug 2008, 02:01 AM
#7
![]() (OO\ Four Door Love /OO) ![]() ![]() ![]() ![]() Posts: 198 Joined: 28th October, 2007 From: Souh Oz Car(s): R32 4 Door Real Name: Josh Trader Rating : 6 |
Sure can mate, their the same. I had a 34 neo turbo on my 20. Great upgrade!
-------------------- Reppin' Built not Bought Motorsport
6 Aug 2008, 09:55 AM
#8
Cool so they fit,1 more quick question from what I understand the only difference between
33 n 34 turbos are the exhaust turbines are a touch bigger to make more power there 4 can I use a RB20 wastegate actuater and will it fit onto the 34 turbo? |
6 Aug 2008, 04:45 PM
#9
Yeah, use the RB 20 actuator. The RB25 actuator is set to something like 4psi.
There are a few differences with the turbos. A series 2 r33 turbo is the same as a series 1 r34 turbo. The both feture the nylon (i think thats the name for it) impeller wheel. Helps it to spool faster. A series 2 r34 turbo has the same impeller wheel but has a OP6 rear housing. The rear housing is similer to the size of a VG30 turbo. You might see a little bit more lag with the bigger rear housing on the RB20. -------------------- Reppin' Built not Bought Motorsport
Lo-Fi Version | Time is now: 7th October, 2008 - 10:38 AM |
