3 Jul 2005, 07:47 AM
![]() RB31DET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 11,062 Joined: 31st January, 2003 From: Sydney Car(s): R32GTST R33GTST Stagea Trader Rating : 48 |
I get asked this question all the time, so here is how to work out the spring rate using a standard Stagea rear spring;
First remove the spring, then measure the ID of the coil, in this case 88mm; ![]() If you don't have a set of verniers then you can use a ruler, yep 88mm; ![]() Always measure the other end, some coils are conical, in this case 79mm; ![]() Then measure the OD of the wire, in this case 12 mm; ![]() If you don't have a set of verniers then you can use a spanner, simply select the right size spanner, yep 12mm. ![]() Last job, count the numbers of coils, this one has 9 and a bit coils, let's call it 9.125 coils; ![]() Then post up the numbers in this thread for Sydneykid to work out the spring rate like this; Coil ID = 88/79 mm Wire OD = 12 mm # of Coils = 9.125 turns Spring rate = 181 lbs/inch (3.327 kg/mm) I will pop onto this thread every few days (sorry not every day) and calculate any spring rates that are posted. Happy spring rate checking D: cheers -------------------- I don't own or work for a workshop and I don't know everything.
3 Jul 2005, 08:13 AM
Some people want to know the spring rates without removing the coils from the car. It a little more tricky and the results are not as accurate, but here is how it is done. Yes, I know this one is on the floor, but use your imagination that it is still mounted in the car.
First measure the lower OD of the coil, this is hard to do without verniers as the shock shaft gets in the way of a ruler. You can buy cheap plastic verniers from SupaCheap, AutoOne, AutoBarn, AutoPro etc for a $few that will do this job accurately enough. In this case 112mm; ![]() Then measure the upper OD of the coil, in this case 103 mm; ![]() As usual measure the wire OD, in this case 12mm (yes, you can use the spanner trick here as well); ![]() Then count the coils, in this case 9.125; ![]() Then post up the numbers in this thread for Sydneykid to work out the spring rate like this; Coil OD = 112/103 mm Wire OD = 12 mm # of Coils = 9.125 turns Spring rate = 181 lbs/inch (3.327 kg/mm) I will pop onto this thread every few days (sorry not every day) and calculate any spring rates that are posted. Happy spring rate checking -------------------- I don't own or work for a workshop and I don't know everything.
4 Jul 2005, 04:19 PM
![]() 2 billion tonnes of depleted hamster ![]() Posts: 1,400 Joined: 30th June, 2004 From: Adelaide Car(s): R32 GTST Sedan Real Name: Ash Trader Rating : 7 |
Interesting. If you're using a formula, could you post it up as I'm curious, or is it a look-up table?
Cheers. -------------------- |
4 Jul 2005, 06:05 PM
![]() SAU Qld el Presidente. Beware the Sombrero ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 5,358 Joined: 4th September, 2003 From: Brisbane Car(s): 33GTR, GTS30tt, XR8 ute Real Name: Geoff Trader Rating : 49 |
Intellectual property
-------------------- REPORT THAT ENGINE FAILURE!
SAUQLD President 2008 president@sauqld.com official SAU QLD club website www.sauqld.com official sau qld club forums how to join For entertaining Qld Skyline related conversation, come to SAUQld.com |
4 Jul 2005, 06:35 PM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 332 Joined: 6th July, 2004 Trader Rating : 1 |
Coil ID = 90/88 mm
Wire OD = 13 mm # of Coils = 7.2 turns thanks |
4 Jul 2005, 08:23 PM
QUOTE(mokompri) Coil ID = 90/88 mm
Wire OD = 13 mm # of Coils = 7.2 turns thanks 281 lbs/inch - 5 kg/mm -------------------- I don't own or work for a workshop and I don't know everything.
4 Jul 2005, 08:24 PM
#7
QUOTE(Oosh) Interesting. If you're using a formula, could you post it up as I'm curious, or is it a look-up table?
Cheers. QUOTE(GTRgeoff) Intellectual property Yes:cheers: -------------------- I don't own or work for a workshop and I don't know everything.
4 Jul 2005, 10:33 PM
#8
![]() rb25 > rb20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 23,194 Joined: 18th November, 2002 From: Goldcoast Real Name: Gordon Trader Rating : 36 |
Curious.. well I have some rear springs sitting here.. well known brand.. they will fit r32 gts-t shocks I think, but not sure whether they are reasonable option.
ID: 76/76mm Wire O/D: 11mm Coils: 10.5mm Spring Rate = ??? All are via steel ruler, so maybe a little inaccure Want to give guessing the brand a try? -------------------- r32 for speed
ls400 - just like a politician - all torque and no action |
5 Jul 2005, 07:16 AM
#9
QUOTE(predator) Curious.. well I have some rear springs sitting here.. well known brand.. they will fit r32 gts-t shocks I think, but not sure whether they are reasonable option. ID: 76/76mm Wire O/D: 11mm Coils: 10.5mm Spring Rate = ??? All are via steel ruler, so maybe a little inaccure Want to give guessing the brand a try? Coils: 10.5mm?? If that is 10.5 turns Spring rate is 142 lbs/inch - 2.5 kg/mm -------------------- I don't own or work for a workshop and I don't know everything.
5 Jul 2005, 02:18 PM
#10
yes, sorry 10.5 turns..
approximately 142lbs/inch .. almost seem a little too soft compared to your suggested "optimal" 200lbs/inch rate for gts-t so might not use them.. although they seem quite firm compared to my stock springs (probably long dead at 15 years old They are Kings.. KDRL-10's.. I was thinking the spring rate must be the only difference between the S13 because fit wise similar I've been told between s13 rears and R32 (?). Proper R32 GTS-T springs are listed as KDRL-101's. -------------------- r32 for speed
8 Jul 2005, 08:52 PM
#11
Anyone else?
9 Jul 2005, 01:25 PM
#12
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 330 Joined: 22nd September, 2004 Trader Rating : 3 |
Pretty sure i measured ok..
Upper OD : 96mm Lower OD : 98mm Wire OD : 13mm # of coils : 7.65 (cusco's are a little weird) ...how would this spring rate be on an r33 gts-t. They are cusco adjustable coilovers Thanks SK |
9 Jul 2005, 10:52 PM
#13
![]() Rank: RB26DE ![]() Posts: 13,862 Joined: 27th June, 2002 Trader Rating : 5 |
How close is 335 pounds/inch.
Quick question though. How accurate is this method considering the different properties of steel used and forms of heat treatment etc? 5%, 10%? -------------------- Minister of RB20 propaganda RB30s are for folk who prefer roofies to romance Vic Motorsport Stock or chock full of gear. Any car can be this weekends race car...just sign up and GO!!!!! Vic SAU Motorsport Director. Contact motorsport@sauvic.com.au Growing old is mandatory; growing up is optional. |
10 Jul 2005, 10:35 AM
#14
QUOTE(Jim) Pretty sure i measured ok..
Upper OD : 96mm Lower OD : 98mm Wire OD : 13mm # of coils : 7.65 (cusco's are a little weird) Thanks SK You might wanna check that coil OD, 96/98mm top and bottom is not normal. But if it is right, they are 465 lbs/inch (8.3kg/mm). The more common is 75 mm ID (ie; 101 mm OD), that gives 400 lbs /inch (7.2 kg/mm). QUOTE ..how would this spring rate be on an r33 gts-t. Too harsh for me, hope it isn't a rear spring. QUOTE They are cusco adjustable coilovers Well, I could have guessed they would be some Japanese brand. -------------------- I don't own or work for a workshop and I don't know everything.
10 Jul 2005, 10:57 AM
#15
QUOTE(Roy) How close is 335 pounds/inch. Quick question though. How accurate is this method considering the different properties of steel used and forms of heat treatment etc? 5%, 10%? Hi Roy, I am not a metalurgist, so pardon me if this is excessively simplistic. The Japanese, German and Australian standards for automotive spring steel are basically same for the 2 types, hot wind and cold wind. The hardening and tempering requirements are obviously different, but the end result is very closely aligned. The program I work with utilises the base data from the BHP coil winding standard, so it is very accurate. If the coil spring manufacture has adhered to either of the 3 standards, then the end result is very predicatable. Garbage in, garbage out obviously applies. The simulation program is used by OE spring manufactures for HSV, Holden and Mitsubishi, Ford have their own in house program as far as I know. But I have checked hundreds of Ford springs and the simulation is still accurate. Obviously it does far more than work out the spring rate, but I am only using that part for this thread. PS; 335 lbs per inch:confused: AAAhh, you have to subtract the wire OD twice from the coil OD to get the coil ID. Yes? -------------------- I don't own or work for a workshop and I don't know everything.
