6 Jul 2004, 04:35 PM
![]() J's Garage ![]() Posts: 4,429 Joined: 26th November, 2003 From: Kingston , QLD Car(s): RB26 Onevia, Legacy wagon Real Name: Jason Trader Rating : 2 |
I'm going to make a complete "How to" series in this thread from mods/ repairs to these models, so if anyone has done anything to, or owned a C210/C211 please post info here and I will collate and make a decent info thread.
I have been looking for agaes and I can't find any online info on these apart from Japanese enthuiast sites which dont seem to offer much if any tech info. Thanks Jason aka V8skylineMAN -------------------- SAUQLD Member 42
![]() Successful Trades: Yardbird, Predator, Ska, Ed G, 666DAN, Stephen22 |
6 Jul 2004, 04:42 PM
So far here's what I have got
M/D/H R 30 front struts and brakes are a straight bolt on affair Providing you have the cv joint rear end in your C210/C211 R30 rear swing arms and disc brakes are a straight bolt on. L20et turbo gear(manifolds/turbo/plumbing/ECU) is a bolt on upgrade. L26/L28 eingines bolt stright in and will also accept turbo set up from L20et Ld28 crank in an L28 with a 60 thou over bore will create an L30. -------------------- SAUQLD Member 42
6 Jul 2004, 05:09 PM
The C210/C211 classification of skyline came out in japan with the obligatory stovetop tail lights. But in the UK and Australia we got ugly rectangle tailights.
They came as a 2 door pillarless coupe , stationwagon(called estate) and sedan. They also came out with varying models including : 280D GT 2000GT ES 2000 Ti ES 1600 Ti (L16 100 PS / 6000 rpm) 1800Ti EX (L18E 115 PS / 6200 rpm) 1800Ti EL Ti 2000GT (L20 115 PS / 5600 rpm) 2000GT EX (L20ET 145 PS / 5600 rpm ) 2000GT EL NAPS 2000 TURBO 240K GT -------------------- SAUQLD Member 42
7 Jul 2004, 05:47 AM
The C210/C211 range came with a few different lighting setups.
Headlights Tail Lights In Japan, the four cyl models all came with the rectangle lights, and all six cyl models came with the stovetops.....In the UK and here we got the rectangle ones on everything -------------------- SAUQLD Member 42
7 Jul 2004, 10:12 AM
![]() Rank: RB25DET ![]() Posts: 812 Joined: 3rd May, 2002 From: Sydney Car(s): C110 Real Name: Kent Trader Rating : 14 |
I have the workshop manual and getting a haynes manual for the C110, if you need anything, i am sure the models arn't too different..
-------------------- Platinum
7 Jul 2004, 05:53 PM
Drive train is only the same in the non-turbo six cylinder variants. The C210/211 came with a few four cylinder arrangements also. I think your manual would be of limited use, although some of it will definately be the same.....ie front suspension. Rear suspension is of a similar design in that it is a semi-trailing arm, but shock and spring placement is different, for example the c110 will have the spring in between the body and the swing arm, a la Datsun 1600, whereas the c210 has it atop the shock as per r30...
Is the manual you already have, for the 210 or 110? -------------------- SAUQLD Member 42
7 Jul 2004, 08:07 PM
#7
well, if your interested i may know somebody selling a C210 nissan workmanual for around $40, i bought mine off him so he is legit (i was originally going to buy the C210 one, but decided on a c110 car instead
9 Jul 2004, 04:40 PM
#8
Rank: RB20E ![]() Posts: 9 Joined: 9th July, 2004 Trader Rating : 0 |
hi there.
Great to see a forum topic dedicated to C110/210 Skylines !!!! I have a C210 4 Door rally car.... L24 with L28 Crank and Pistons Autronics injection Close ration 5 Speed 4.8:1 LSD R30 Rear End etc... Cheers Tim G |
10 Jul 2004, 02:26 AM
#9
tim (sorry to sidetrack the conversation), how easy was it to fit the R30 rear end? just bolt up? or did you have to drill new mounting holes? what sort of diff is in the r30 anyway? i am looking at putting an R200 in ours, would the R30 be a better choice?
10 Jul 2004, 08:59 AM
#10
R30 diff is an R180(So is the C210's) but they are tuff as anyways...only reason to put an R200 would be for the lsd that is harder to get for R180's and for that lil extra strength if you are doing a LOT of clutch dumping with big rubber.....
Rear struts are straight bolt up....tailshaft is bolt up.the only thing MAY be the width of the rear subframe....but that shouldn't be a problem either..... I have a complete rear clip for the r30 sitting in my shed ready for my C210 coupe.....havent measured it but cant see a problem( hang on,, im not tim.....I'll shut up now) -------------------- SAUQLD Member 42
10 Jul 2004, 06:18 PM
#11
The C211 heralded a significant change in the Skyline philosophy. There was no more GT-R , the highest performing Skyline was now the GT-ES(KGC211), which came out in April 1980 and was powered by the L20ET, a 140hp, OHC 2.0 litre turbo straight six, in reality a sleeved down version of the venerable L-series six, as found in the 240Z to the 280ZX, making this possibly the physically biggest ever 2.0 litre engine! The basic versions were called 1600TI and 1800TI now and featured L16 and L18 engines respectively, instead of the preceding "G" engines.
By June 1980 a 2.8L diesel version was offered. Moving away from the swoopy lines of the C110, the C211 had a boxy and somewhat staid bodyshell. Not to mention heavier. The wheelarch extensions and spoilers were now gone, replaced by chrome trim and typical late 70's style "personal luxury", with a lot of fake wood. The Skyline was certainly not alone in following this trend, Mazda releasing the RX-5, the 260Z replaced by the 280ZX, and all sorts of good cars at the time like the Dodge Charger and Ford Mustang becoming chrome laden, velour-lined gin palaces for the disco generation. The change in mood was echoed in the engine bay, the L20ET's lack of top end zing and its reluctance to rev marking it out as a touring car, rather than a sports machine. Certainly the awkwardly wide gear ratios don't help, with a very low first three gears, then a long gap to the relatively tall fourth and fifth. People who have driven one mention how effortless it is on the freeway, but a fast car it is not, cutting the quarter in perhaps 17 seconds. It may be easy to poke fun at the C211 for losing the sporty looks and spirit of the GT-R's before it, but nonetheless it holds a considerable historical significance. It is, after all, Nissan's (and Japan's) first effort at turbocharging, spawning the long line of turbocharged performance Skylines, Zeds, Silvias, Cefiros, Glorias and 180SXs we've enjoyed since. The older S20 engined GT-Rs would never have survived the fuel crisis of the seventies, nor the tightening emissions regulations later on, so the C211 can hardly be blamed for changing with the times for survival. Honda has VTEC, Mitsubishi has MIVECs, Toyota has its distinguished 4AG and 3SG twin cam engines, and Nissan bolts on a turbo whenever the need for speed arises. And all this started with the car you see above. To my knowledge it was never raced seriously by the factory. Rather than devalue the marque, Nissan showed an admirable lack of oppotunism, by stashing the GT-R badge away, to fight another day. I wonder if the guys at Nissan knew how long it would actually be before a car would leave the factory wearing the famous red "R". -------------------- SAUQLD Member 42
11 Jul 2004, 07:57 AM
#12
here you go...
11 Jul 2004, 08:00 AM
#13
One more....
12 Jul 2004, 10:59 AM
#14
R30 rear end was a straight up BOLT IN job !!! I actually busted a rear trailing arm and could not source any C210 parts, I tried bolting the R30 Arm onto the C210 Cross member but the toe and Camber was Waaaaaay out so in went the whole rear end !!!
biggest advantage for me was Discs and CV-Type driveshafts, no more broken Half shafts !!!!! These shafts are very strong !!! I still use the R180 Diff, these are quite strong and much lighter than the R200. Cheers TG |
12 Jul 2004, 09:50 PM
#15
Complete bolt in....thats good to know...i knew it would be damn close....
thanks gadsby....any more info u have on mods? -------------------- SAUQLD Member 42
21 Jul 2004, 07:31 AM
#16
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 102 Joined: 7th June, 2004 Trader Rating : 0 |
I saw this C210 near my house and he's selling the whole car but its not running, I'm only interested on parts that I can use for my C110, I heard I can use the electronic dizzy? straight bolt-on right?
Anything else I should take? |
21 Jul 2004, 02:56 PM
#17
I dont remember if mine had an electronic dizzy....the R30 does. If the c210 does have an elec dizzy then grab it cos yes it will fit straight in.
Depends what you need......is yours 5speed? if not his might be...basically the whole drivetrain will bolt right in....suspension probably wont, but i know that the front control arms are a fair bit longer and will fit....that will give you HEAPS of camber in the front....ask the guys on the "project 240k" thread....they should be able to tell you how much camber it was as they had c210 arms in theirs(they took them out tho) Not sure on front strut lengths so you should measure yours against his....his might be a bit shorter and thefore lower your car slightly. As far as i know the brakes are all the same. Was the c210 a coupe? -------------------- SAUQLD Member 42
