29 Apr 2004, 04:16 PM
![]() Yellow Fever ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 10,610 Joined: 6th May, 2002 Trader Rating : 4 |
Please add your experiences and tips to service our cars
for RB20E RB20DE RB25DE RB30E ...etc. How much oil does the engine take (inc. filter)? What oil filter does it use? (Z154a??) What sort of spark plugs should I use in it? What fuel filter does it use? What air filter? (stock panel type) cheers Joe -------------------- Visit My Website
or Facebook :) |
29 Apr 2004, 04:24 PM
![]() http://mishracing.com ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,564 Joined: 10th May, 2003 From: Brisbane Car(s): R33 GTS-V8, CPV35, Patrol Real Name: John Trader Rating : 1 |
RB25DE,
takes approx 5 ltrs of oil, filter is a Z145A and there is a smaller option but the bigger the filter the more filtration = GOOD Other than that if u drive the car hard use reasonably good quality oil and change it every 5000k's. I flogged my car everywhere and the oil was black after 5000, internally the engine looked like new though. I used Magnatec which was recomended using nething better is not necessary. ummm dont know much else on the engine it self. check water ever servicee it generally wont go down unless u have a leak though Power steering change every 40-50000, just use a good quality auto tranny fluid. Not sure what else, i cant remember pad numbers for it but im sure if u search they will still be on here. Plugs i wil check soon, Fuel filter i will also check Air Filter: use k n n panel same as for the turbo option for your model. -------------------- NEW PB!! 10.17 @ 132mph Saving for a Big Block Chevy!!
Read about it here....Here ![]() Blacky Evolution: 15.8 @ 88mph RB25DE 14.02@98mph RB25DE Nitrous 13.34@108mph VH45DE 12.8 @ 109mph VH45DE Nitrous 10.38 @ 132mph www.mishracing.com |
7 May 2004, 07:03 PM
![]() Car-less ![]() ![]() ![]() ![]() ![]() Posts: 1,705 Joined: 3rd August, 2002 From: Melbourne Trader Rating : 8 |
Engine power
RB25DE Power: 142 kw@6400 rpm (147kw for series II or 'Type S' variants) Torque: 231 Nm@4800 rpm This generally translates to 90-100kw @ the wheels. Oil change Engine I use genuine Nissan oil filter - $9.95 from your local dealer Engine oil capacity RB20E, RB25DE: 3.8L (not including filter) RB20E, RB25DE: 4.2L (including filter) Skyline manual recommends changing oil and oil filter every 15,000km - I change both every 7-10,000km. Gearbox I use Castrol VMX80. I'm happy with it. Redline is the best but its expensive. Gearbox capacity: RB20E: 2.0L RB25DE: 2.5L I used Shell oil for a bit - it was absolute shit, synchros crunched etc. Steer clear of shell gearbox oil. Diff I use Castrol EPX80w90. Others have used VMX80 in their diff as well. Diff capacity: RB20E non lsd: 1.0L Active LSD (you have an active LSD light on your dash): 1.6L Normal LSD: 1.3L I change my diff oil every 15,000km because my diff is made to do a lot of work Brake discs R33 GST25/GTS4 Original thickness: 26mm Mininum thickness: 24.2mm Fuel economy Non turbo skylines have relatively efficient fuel economy compared to turbos. I average 10.9L/100km - this includes a lot of thrashing. The factory quoted figure is 9.6L/100km. Fuel tank capacity is 65 litres. What petrol As Japanese cars are tuned for very high quality petrol (high octane) it is advisable to run optimax (Shell), synergy 8000 (Mobil), ultimate (BP). Personally I use synergy 8000 as this is what runs the best. I've used normal premium before and it ran fine, perhaps a bit less responsive though. Spark plugs N/A skyline spark plugs Exhaust Extractors - People have had good results with Coby extractors, order from www.partsco.com. I use these - they give the engine a much fatter midrange, making the car a lot more fun to drive. They suit both RB20 & 25. Some power gains might be had with the RB25 by using larger diameter piping for the extractors than the Coby extractors (65mm) Off the extractors 2.5" is the largest diameter piping you should use for RB25DE. Quieten the exhaust with resonators if its too droney. Air filter Benefits of a pod filter are ambiguous. I run an apexi pod and on hot days I REALLY notice the drop in power associated with the pod sucking hot air. Skyline manual recommends to change air filter every 60,000km. Weight Factory quoted figure for R33 GTS25 is 1320kg. I recently weighed mine with 1/3 tank of fuel and found it to weigh 1309kg (ABS, hicas, airbag). General specifications Had these on my computer for ages, they might be useful to someone. Turning circle: 10.4 m Length: 4640mm Width: 1720mm Height: 1340mm Interior length: 1820mm Interior width: 1415mm Interior height: 1090mm Wheelbase: 2720mm Front track: 1480mm Rear track: 1470mm Ground clearance: 145mm -------------------- R33 rear hicas rack, perfect condition (I installed a lock bar) - $50
R33 rear swaybar mounts and bushes - $20 R33 Exhaust bracket (supports exhaust at cat converter, stops it moving around) - $20 Grey carpet - matches R33 boot carpet, perfect for subwoofers etc - $20 R33 clutch and pressure plate - $50 SOLD CAR NEED TO CLEAR |
24 Jul 2004, 10:17 AM
![]() The Burninator ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 5,643 Joined: 5th June, 2002 From: Melbourne Car(s): 91 Harley & Dragon Wagon Real Name: Trogdor Trader Rating : 4 |
4 Aug 2004, 02:52 PM
leave it with me... I am no grease monkey but I know which rod goes with which cylinder....
or Facebook :) |
5 Jan 2005, 07:47 AM
Rank: RB20E ![]() Posts: 8 Joined: 2nd September, 2003 Trader Rating : 0 |
Hi I've got a Skyline with a RB20E
I use oil filters from nissan and 'Halfords', sparkplugs by Denso, Replacement panel filter by K&N I'll go get the part numbers a bit later as it is late night and cold outside!! Fitted the Tein Flex suspension, gambled by ordering the same set as for a R33 GTS and luckily they fit. Non of the parts are ever listed for this car in any catalogue, always have to buy at my risk! Just a question regarding this car...it is very difficult to find parts for it! no one even knows it exists, I bought it in error to the RB20DE...but I'm not too concerned cos i don't race it. Anyone know the stud fitment of this car? it is 4-stud instead of the GTRs 5-stud hubs. I was hoping someone has one of these cars and has been able to find alloys off a 4-stud 200SX/Silvia to fit! If so could someone let me know which model they have tried? I really need some new alloys but here in the UK they only seem to play with the GTRs... I'm also after sparkplug leads to replace the old ones that may have been there for several years! was told the GTR does not have leads, just coils?! what brands should i look for? Thanks in advance |
15 May 2005, 04:13 PM
#7
![]() "She wuz just admiring MA RIDE!!!" ![]() ![]() ![]() ![]() Posts: 394 Joined: 4th August, 2003 Car(s): R34 GTT Trader Rating : 0 |
Whats the idle timing (factory specs) for R33 RB25DE?
ta |
16 May 2005, 08:39 PM
#8
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 922 Joined: 10th February, 2004 Car(s): R33 GTS25 Trader Rating : 0 |
any how can it be changed - what effects would it make?
-------------------- FEED YOUR ADDICTION
http://www.filejunkies.net :) :headspin: HELP ME WITH RB25DE -> RB25DET CONVERSION! |
1 Nov 2006, 02:12 PM
#9
RB25DE ![]() ![]() ![]() Posts: 55 Joined: 5th October, 2006 From: Newcastle, NSW. Car(s): R32 4Dr Real Name: James Trader Rating : 1 |
Hey, could I please ask what kind of air filter an RB25DE stock air box would take?
Thanks. -------------------- |
1 Nov 2006, 02:22 PM
#10
Rank: RB30ET ![]() ![]() ![]() Posts: 5,555 Joined: 6th April, 2004 From: Brisbane, QLD Car(s): R33 GTS25 Real Name: Eugene Trader Rating : 24 |
Hey, could I please ask what kind of air filter an RB25DE stock air box would take? Thanks. i believe they are the same across r32, r33, regardless of turbo or not... there are a variety, nismo, blitz, apexi, k&n, pipercross, ryco? -------------------- SAu QLD club website // www.sauqld.com // how to join "Nothing says unprofessional job like wrinkles in duct tape" |
24 Dec 2006, 09:28 PM
#11
Rank: RB20DET ![]() ![]() ![]() Posts: 30 Joined: 7th November, 2005 From: NSW SOUTH COAST Car(s): Nissan gtr 33 Real Name: Richard Stachurski Trader Rating : 0 |
air filter's for gtr, gts,gtst, vl, etc are: a360-(ryco)
23 Jan 2007, 08:47 PM
#12
Get an apexi panel filter here - $69 delivered, can't go wrong. I just got one myself
23 Jan 2007, 10:19 PM
#13
![]() 400rwhp - 3000cc ![]() ![]() ![]() Posts: 14,782 Joined: 20th June, 2002 Car(s): R32 GTS30t Trader Rating : 10 |
Some may find this interesting...
Straight from the service manual.
Attached File(s)
22 May 2008, 09:12 PM
#14
![]() Rank: RB20DET ![]() Posts: 88 Joined: 22nd August, 2007 From: Victoria Car(s): R34 4 door, '83 Bluebird Real Name: MARK Trader Rating : 0 |
i believe they are the same across r32, r33, regardless of turbo or not... there are a variety, nismo, blitz, apexi, k&n, pipercross, ryco? You can even go down to your local Holden dealership and buy an airfilter for a Commodore VS - It will fit in your Skyline - The Holden air filter is surprisingly good and a great price about $14.00 - the later revisions of the Holden filters are oiled, have more pleats and the material seems slighty thinner |
Lo-Fi Version | Time is now: 22nd August, 2008 - 12:55 PM |
