8 Aug 2008, 08:49 AM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 157 Joined: 6th November, 2004 Trader Rating : 0 |
For a 1300kg two wheel drive car doing five lap sprints. Reason I ask is that I've never used them before and previous experience with Kuhmo's involved a fair bit of experimentation getting them right.
So any cold/hot suggestions, any tricks? Won't be able to do the proper heat cycling at the start, unless running them on the road with low pressures will do that. -------------------- Richard..............
8 Aug 2008, 09:04 AM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,189 Joined: 31st December, 2003 From: Melbourne Car(s): 180sx, VXII Clubsport Trader Rating : 5 |
Hey Richard, I run from 28-30 psi cold from memory (it's been a while) on my 180SX, and that seemed to give the best results.
-------------------- Widebody 180sx
8 Aug 2008, 09:49 AM
All About Driving ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,069 Joined: 9th June, 2005 From: Sydney Car(s): V35's Non-Identical Twin Real Name: Alan Trader Rating : 0 |
What time period will they be driven for? 5 laps on one circuit can take twice as long as on another, which means the amount of heat generated will differ.
Assuming a 1:45 lap (which is about average for most of the track times I've seen) I'd probably go for around 28-30psi cold. Its the hot pressures which matter the most, so as soon as you park the car up check your tyres. I normally aim to have my RE55S' at around 32-34psi when I come off the track. -------------------- Ngo yiu mai gee-tee ar-lo
Fast and furious is over.. stop trying to re-live it with mad meetups with promo chicks bro. ![]() The police wouldn't want to take these guys on. Its much more important to stamp out the rampant spread of pod filters. Boost: Perfect for when you just can't work out how to drive around a corner |
8 Aug 2008, 10:00 AM
![]() RB28DETT (2 X 2860-5) ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,268 Joined: 2nd August, 2002 From: Perth Car(s): BNR32 Trader Rating : 10 |
There is no "absolute" answer to this as there are many variables, even with the same car.
A tyre pyrometer is your friend here and will give you instant feedback as to what your surface contact patch looks like. I got a Longacre unit from USA for ~$100 delivered and since then I have lots of "friends" on track days -------------------- 2.8 litres of HKS stroker goodness tickled by a pair of dash 5s so responsive the starter motor brings them on boost Barbagallo: 65.7s long track, 54.4s short track Collie: 49.9s Kwinana Motorplex: 11.1s standing quarter @ 129mph Autosalon 2007 Perth: 602 rwhp on Dynodynamics (Shootout 6) AHG Driving Centre: Don't ask - too technical and shows I can't drive for sh*t!! |
8 Aug 2008, 06:39 PM
Goodoh, thanks blokes, sounds like the RE55's are fairly convential, unlike the Kuhmos which worked ~22psi.
8 Aug 2008, 07:09 PM
Rank: RB20E ![]() Posts: 3 Joined: 21st June, 2008 Trader Rating : 0 |
8 Aug 2008, 07:49 PM
#7
that's racing! ![]() ![]() ![]() ![]() Posts: 18,563 Joined: 10th May, 2002 From: Sydney Car(s): bnr32,z33,wgnc34,ungd21 Trader Rating : 18 |
I aim for 34 hot. on a low power 32 gtr doing 15 min sessions it is generally:
-8 front outside -6 front inside -6 rear outside -4 rear inside try that as a starting point, and check pressures after 2 flat out laps without a cool down. -------------------- |
8 Aug 2008, 11:10 PM
#8
![]() compulsive tinkerer ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,705 Joined: 6th April, 2003 From: Sydney Car(s): bent r32 Real Name: badhair Trader Rating : 15 |
which kumho's? I'm thinking about a set for the next track nugget but it weighs around 1050 so was considering a softer compound..
i assume 22 is cold pressure? -------------------- BHDave
If you don't like it you can bang it up your arse. |
9 Aug 2008, 08:11 AM
#9
![]() 8500rpm ![]() ![]() ![]() ![]() ![]() Posts: 1,119 Joined: 23rd January, 2003 From: Brisbane Car(s): 1994 R32 GTR N1 Vpec II Real Name: Michael Trader Rating : 0 |
i have my RE55s SR2 for 5 x hotlaps of QR at 28 cold. come off at 34.
-------------------- ![]() 1994 Skyline GTR VspecII N1 11.5 @ 122mph QR Sprint - 57.55 Street Registered, Street Driven, Track Thrashed! :) |
9 Aug 2008, 08:21 AM
#10
which kumho's? I'm thinking about a set for the next track nugget but it weighs around 1050 so was considering a softer compound.. i assume 22 is cold pressure? V70A's, they have a very stiff sidewall. Yeh ~22 cold. -------------------- Richard..............
Lo-Fi Version | Time is now: 7th September, 2008 - 02:28 AM |
