7 Aug 2008, 09:25 PM
Rank: RB20E ![]() Posts: 1 Joined: 8th June, 2008 Car(s): R32 RB25 Real Name: Dan Trader Rating : 0 |
just bought a r32 that has been imported with a rb25 out of an r34 in it.
It doesn't have a rev limiter cause it goes al the way to 8000rpm!! Ive put a bee r rev limiter in it, but it cant b too healthy for it cause she goes bang bang too much. I would like the stock limiter back on cause i use it for driftin. Does any one know where the stock limiter is located and how to connect it back up? |
7 Aug 2008, 10:41 PM
![]() Rank: 2JZ-GTE ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,692 Joined: 11th October, 2006 From: Melbourne Car(s): R32 GTS-4 Four Door, KE70 Real Name: Adam Trader Rating : 1 |
I always thought the standard limiter was built into the ecu. Someone probably retuned the ecu to have a higher rev limit?
A BeeR limiter will be safer on your motor than the standard one. Standard limiter cuts your fuel, your car runs lean and can damage the motor whereas the BeeR cuts the ignition, safer. With the BeeR you can choose when you want the limit to be as well which is good. Just set it to where the standard limit should be. Correct me if I'm wrong. I'd hate to be spreading wrong information I've read off others. -------------------- |
8 Aug 2008, 12:11 PM
![]() RB26DETT powered insanity!!! ![]() ![]() ![]() ![]() Posts: 256 Joined: 15th January, 2008 From: Brissy Car(s): R32 GT-R, Celica Real Name: Terry Trader Rating : 0 |
Stock limiter is safer for your turbos. Bee-R will kill them very quickly. The fuel goes in and the hot turbo ignites it, causing an explosion inside your turbine. Thats what the bang bang is. Hello new turbo. Also, if its safer to cut ignition, why doesnt any manufacturer do it?
-------------------- Battlefield 2 SAU clan member
8 Aug 2008, 12:13 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 567 Joined: 22nd November, 2006 From: Adelaide, Australia Car(s): R33 S1.5 GTS25t Real Name: Andrew Trader Rating : 4 |
Manufacturers don't expect retards to be banging the rev limiter though...
8 Aug 2008, 12:33 PM
Manufacturers don't expect retards to be banging the rev limiter though... Yes they do, thats why its there. They think we're all retarded too, and most of us are, hence why hyundai and kia are still selling cars..... -------------------- Battlefield 2 SAU clan member
8 Aug 2008, 12:43 PM
Rank: RB20DET ![]() ![]() ![]() Posts: 30 Joined: 25th June, 2007 Car(s): 4door 32 Real Name: Matty Trader Rating : 0 |
well said, Bee R apparently can also kills engines by allowing heaps of fuel into the combustion chamber at high revs, instantly vaporising, the thermal shock aint much good for the motor...... apparently.........
8 Aug 2008, 02:34 PM
#7
Yes they do, thats why its there. They think we're all retarded too, and most of us are, hence why hyundai and kia are still selling cars..... Manufacturers don't have a rev limiter there so you can bounce off it everyday. It's there so in the 'rare' even you're stupid enough to go that high it does LESS damage than what an over-rev would do.Go sit on your rev limiter for a while and see what happens then. Do you know what happens when you hit the factory limiter? The cylinder pressures go AWOL and can easily cause some serious engine damage. Engines are built to revved, sure. But rev an engine's tits off day in, day out and you'll soon be driving a less reliable car. Things will wear out much quicker and problems will start developing. I drive my car with respect, sure I pump it every now and then but never do I intentionally hit the limiter or thrash the shit out of it and that's why I haven't had a problem with it. Hyundai and Kia sell cars because their market is people who want a cheap car. Buying a crap Korean car doesn't make you retarded wtf... -------------------- ![]() |
8 Aug 2008, 09:07 PM
#8
![]() Rank: RB30E ![]() Posts: 3,392 Joined: 14th January, 2003 Trader Rating : 4 |
i think your missing reading his post.
they engineer cars and usually everything complex for that matter to be idiot proof or retarded as you may call it to some degree in the event that someone may be stupid enough to do what you just said. |
8 Aug 2008, 11:44 PM
#9
Buying a crap Korean car doesn't make you retarded wtf... At least you agree they're crap, separating you from the people that buy them.... -------------------- Battlefield 2 SAU clan member
9 Aug 2008, 09:55 PM
#10
i think your missing reading his post. they engineer cars and usually everything complex for that matter to be idiot proof or retarded as you may call it to some degree in the event that someone may be stupid enough to do what you just said. Yeah, fair enough -------------------- ![]() |
12 Aug 2008, 06:53 PM
#11
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 145 Joined: 17th July, 2006 Car(s): 92 R32 GTS-T Real Name: Tim Trader Rating : 2 |
I have a re-tune computer in my 32 and my rev limiter is at 8000rpm
I was thinking, instead of getting a Bee-R, for the $350 odd that it costs i might as well just get an after market ecu. I also heard that they can kill the factory ceramic wheel turbo pretty quickly and that steel wheel turbos are better suited? -------------------- ![]() |
13 Aug 2008, 02:02 PM
#12
![]() i heart sedans ![]() ![]() ![]() ![]() Posts: 222 Joined: 7th May, 2005 Car(s): R33 Sedan Trader Rating : 2 |
Realisictly your only guessing it doesnt have a rev limiter if you have only reved it to 8,000.
I have seen 32's rev limiters from factory set at 8,200. With an Rb25 in it it could still be after 8000. I'm not suggesting to go see if it is after 8,000 just pointing out that it might be higher. To solve your problem of wanting a lower rev limiter without a Bee-r = aftermarket ecu and set it yourself or retune stock ecu by someone like Dr Drift and get him to set it where you want. |
13 Aug 2008, 04:23 PM
#13
I also heard that they can kill the factory ceramic wheel turbo pretty quickly and that steel wheel turbos are better suited? Bee*R = dead turbo. I wouldnt even use it on a steel jobby -------------------- Battlefield 2 SAU clan member
13 Aug 2008, 08:06 PM
#14
Also, something to take into account. I've noticed that the factory tachometer needle can 'float'.
After installing my S-AFC (with digital rpm readout and peak hold) i noticed that the tacho needle would read higher than the car was actually revving. Say the tacho was reading 7500rpm the S-AFC would record a peak of say 6800rpm. So you may not be revving the car out as much as you think. -------------------- ![]() |
14 Aug 2008, 01:13 PM
#15
![]() Because it's still funneh! ![]() ![]() ![]() ![]() ![]() Posts: 1,007 Joined: 23rd August, 2005 From: SYDNEY Car(s): s2-33t commonhore Real Name: Dave Trader Rating : 0 |
for a start why are you sitting on the rev limiter? Any fool who spins wheels knows to keep the revs as low as possible... harder to do, sure, but reving the living end of the motor, recipe for longevity right there. In what instance do you need to be hitting the rev limiter? If your peak power were the last 1k-2k rpm in a race car sure... in which case your engine is built for what you expect to be a set life on that spinner anyway. On a car that spends time on the roads... swapping cogs should happen before that... 25 with stock crank and cams over 6k is just wet noise. Awsome noise the last 3rd rev range I grant you but.. not something to write home about.. 6-6.5k is a cog swap.. your 7k...(7.1krpm for s1 wanktards) is your hard limit. who waits on the rev limiter to change?
-------------------- Scathing:"You drive a car with an RB20DET willingly, and think that you're somehow superior to a Celica. You need a lot more than a new outlook on life."
PM-R33:"Shouldn't uz be touching urself to a cheap porno or something at this time of the night?" Dan: Chopped last half of line for clarity. "I'm working with labor now. i think they are implementing their promises." Scathing:"The way I see it, "character" is a zealot's euphemism for "things that a sane person with a normal car that doesn't suffer from would call shit"." |
14 Aug 2008, 09:17 PM
#16
I would like the stock limiter back on cause i use it for driftin. -------------------- ![]() |
