7 Aug 2008, 09:40 AM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 574 Joined: 9th September, 2007 From: Adelaide Car(s): R32 GTR! R32 Gts-t Real Name: joel Trader Rating : 0 |
hey guys
ive done some searching but im not sure about the answers i found. im after a straight answer if possible :S i just bought my GTR and the steering is heavy above 60-70kms. the hicas light isnt always on, sometimes comes on for a second when im going around round abouts and sharp corners. do i just need to lock out the hicas? or a wheel alignment? if it helps its an 89 r32 gtr cheers for the help -------------------- |
7 Aug 2008, 09:56 AM
![]() Rank: RB20DET ![]() Posts: 54 Joined: 31st July, 2008 Car(s): Skyline R33 gts-t Real Name: Anthony Trader Rating : 0 |
hey man
i would start off with the HICAS diagnostic test (http://www.skylinesaustralia.com/forums/HICAS-Diagnostic-t22193.html) if that comes up fine..... get it checked out ....... hicas light is meant to be off .... get that checked out ye...... when my hicas was doing that in old car i reset the ecu..... dunno if that will help you but if keeps going.... take back to where you got it....... |
8 Aug 2008, 01:19 PM
![]() I am the Stig! ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,401 Joined: 5th March, 2005 From: Canberra ACT Car(s): R32 GTsT+RB25DET Real Name: Mick Trader Rating : 3 |
HICAS - My R32 had very heavy steering when the electric HICAS pump died... Remove it with a locking kit and it should fix the problem.
-------------------- ![]() Need advice on tyres? - Feel free to PM me. I use and recommend Federal Tyres -www.federaltyres.com.au |
8 Aug 2008, 01:32 PM
...let slip the dogs of war. ![]() ![]() Posts: 2,149 Joined: 10th June, 2006 From: Perth, WA Car(s): R32 GTR Real Name: Twisty Trader Rating : 3 |
i just bought my GTR and the steering is heavy above 60-70kms. the hicas light isnt always on, sometimes comes on for a second when im going around round abouts and sharp corners. How much heavier? As the steering will get a little heavier at higher speeds, by design. -------------------- "cons for the N/A motor- you dont get farken WHOOOSH !" [ssshonky] "If you do not wish to purchase this dildo styled gear knob then do not post." [dan_the_man] "Only the people who have driven these things (R32 GTR) in anger can understand its brilliance" [bnr#@] www.outerlimitz.com |
8 Aug 2008, 02:23 PM
heavy/jerking lol its not from high speeds.
going to do diagnostic tonight, spoken to mechanic about lock out bar. it will fix the problem hopefully -------------------- |
Lo-Fi Version | Time is now: 13th October, 2008 - 12:30 PM |
