6 Aug 2008, 08:10 PM
Rank: RB20DET ![]() ![]() ![]() Posts: 50 Joined: 7th January, 2008 Car(s): R32 Coupe, RB31/25det Real Name: James Trader Rating : 0 |
I got two tomei restrictors and fitted them to the block and they are a crush fit item so i was expecting some excess metal but once they were in the holes seem to be burred over a little so that they appear smaller than before i fitted them. Did i f**k it up or do they do this normally? Shoud a try deburr the holes or remove them? ANy advice would be awesome.
7 Aug 2008, 09:39 AM
![]() Incase you didnt notice, I just did over a thousand! ![]() ![]() ![]() ![]() ![]() Posts: 1,860 Joined: 17th August, 2004 From: Brisbane, Everton Park Car(s): R33 X 2, Yammy 05' R1 Real Name: Michael Trader Rating : 1 |
have you actually measured them? or is this an eye measurement your going on? Grab your verniers and check that the hole is 1.5mm.
-------------------- *6BOOST MANIFOLDS*
STEAMPIPE EXHAUST MANIFOLDS TO SUIT ALL RB ENGINES CALL KYLE :0410 730 598 |
8 Aug 2008, 06:19 PM
Umm not a measured thing, but the difference is noticeable by eye...
9 Aug 2008, 03:07 PM
![]() RB31DET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 11,109 Joined: 31st January, 2003 From: Sydney Car(s): R32GTST R33GTST Stagea Trader Rating : 49 |
You should only be using one oil flow restrictor with the other oil feed blocked off.
Cheers Gary -------------------- I don't own or work for a workshop and I don't know everything.
10 Aug 2008, 12:41 AM
![]() 400rwhp - 3000cc ![]() ![]() ![]() Posts: 14,904 Joined: 20th June, 2002 Car(s): R32 GTS30t Trader Rating : 10 |
Perfectly normal. Clean it up with a Stanley blade and SK's your uncle.
Lo-Fi Version | Time is now: 7th October, 2008 - 10:41 AM |
