6 Aug 2008, 03:35 PM
![]() Rank: RB20DET ![]() ![]() ![]() Posts: 55 Joined: 6th June, 2008 Trader Rating : 0 |
i want to go with buddy club seats, but of course they only have rails for the S chassis. what rails can i use wit h these seats?
R33 by the way. do the S14 ones bolt up? |
6 Aug 2008, 05:15 PM
![]() FYA ![]() ![]() ![]() ![]() ![]() Posts: 715 Joined: 30th January, 2006 From: Central Coast Car(s): 1996 R33 GTST Real Name: FYA Trader Rating : 1 |
Are they a full bucket or a recliner?
7 Aug 2008, 08:31 AM
8 Aug 2008, 04:53 PM
![]() Rank: RB20E ![]() Posts: 11 Joined: 11th July, 2008 Car(s): r33 gtst Real Name: nate Trader Rating : 0 |
8 Aug 2008, 06:20 PM
I don't know about the s14 ones fitting, I would of the thought the floor of a 33 would be different, but I haven't seen an s14 floor...
I used a bride seat rail, n104 from memory, Im guessing I'm not at home at the moment, then used a custom alumiunium bracket that hangs off the side of the bucket. you can get bride ones I just had some brackets that I could customise a little to make them work. the rail needs to be the flat low variety you can then bolt practically any bucket seat brackets to it... Bride rails are terrific work like factory units, great build and not that expensive at $150 each. got mine from nengun with other bits and pieces, btw they will fill the rail box up with other parts so shipping works out good if you get a few things at the same time... be sure to use the right bolts for the right holes as they are specific lenths and types for a reason, fitting perfect.. -------------------- |
9 Aug 2008, 02:43 AM
wouldnt be using aluminium to make seat brackets last thing you want snapping in a prang.
9 Aug 2008, 12:35 PM
#7
its like 15mm thick...
Lo-Fi Version | Time is now: 7th October, 2008 - 10:33 AM |
