IPB
2 Pages V   1 2 >
> Fuel Consumption Gettin' Wyld
steve33
post 5 Aug 2008, 03:07 PM
Post #1
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
Hey Guys,
Just wondering if anyone can give us a hand with my 33 series 2 goin' through petrol like crazy. Only getting bout 280 to the tank without driving it that hard at all.
It's running 12 psi, Front mount, Exhaust nothing too flash. Just seems a bit to rich compared to what i've heard from other guys with the same basic setup.
I've heard that changing to o2 sensor will help the situation - is this the case?
If anyone can give us a hand in trying to get my car running leaner or knows anywhere around sydney that can sort it out for me, it'd be greatly appreciated.
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
(OO)SKYLINE(OO)
post 5 Aug 2008, 03:15 PM
Post #2
Founded and Driven by Racers
Group Icon
Car(s): Nissan Skyline R32 GTR
Trader Rating : 0
The O2 Sensor's job is to make sure the car is not running to lean, too rich. If its faulty then the car might be using more fuel then it should.
If it needs replacing, change it and should help out your fuel consumption.
Also put in a can of injector cleaner and check out your spark plugs and tyre pressure.
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 03:28 PM
Post #3
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
QUOTE((OO)SKYLINE(OO) @ 5 Aug 2008, 03:15 PM) *
cheers mate, appreciate the feedback. any hints on where to get the o2 sensor from? no doubt it'd be better to get a brand new one rather than second hand
Profile CardPM
+Quote Post
EJD001
post 5 Aug 2008, 03:38 PM
Post #4
Im mick
Car(s): R34 GTT
Real Name: Mick
Trader Rating : 0
if u were to get a second hand one , u may just get the same problem again!
go to nissan and get a new one. or maybe one of the traders on here.
Needing genuine parts for these makes and models, PM me
Toyota
Lexus
VW
Alfa Romeo
Fiat
Citroen
Hyundai
MG Rover
Including TRD & Grey import lexus and toyota vehicles
Profile CardPM
+Quote Post
(OO)SKYLINE(OO)
post 5 Aug 2008, 03:52 PM
Post #5
Group Icon
Trader Rating : 0
I think the O2 sensor can cost upto $100 (approx), my mechanic changed both of mine and a few other things so I spent abour $300+. I gota check my invoices.
I would just get a new one and your mechanic should be able to sort it all out for you.
Cool!
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 03:55 PM
Post #6
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
QUOTE((OO)SKYLINE(OO) @ 5 Aug 2008, 03:52 PM) *
Cool!
yeah all sweet.... sounds good to me, the other thing is, we all know when it comes to cars it could be an abundance of things that can cause the same problem in a motor. what are some other things to keep in mind if the o2 sensor is fine? any other hints in what can make it run leaner.
Profile CardPM
+Quote Post
Sandeep
post 5 Aug 2008, 03:57 PM
Post #7
VG30DE
Group Icon
Car(s): 1990 Nissan 300ZX Z32 NA
Real Name: Sandeep
Trader Rating : 0
Yeah o2 sensor is usually the main culprit. Do you have access to Nissan Consult or Datascan? You can test the o2 sensor using the computer software or you can do it using a voltmeter on the pins.
Test it when the the car is at operating temp, usually after a 15-20min drive. While the car is stationary (no load) rev the engine to approx 2000rpm and you want to see the voltage cycling once a second. Usually if they haven't been replaced they'll be quite slow to react or may even be dead.
Other things to check are:
-coolant temp sender
-detonation sensor circuit error code
Photo by SarahB
Profile CardPM
+Quote Post
momo
post 5 Aug 2008, 03:58 PM
Post #8
Car(s): rs four s
Real Name: tim
Trader Rating : 0
O2 sensor is for closed loop function (highway driving) it doesnt opperate if your on and of the accelerator, so wont help or effect city driving. try new plugs, clean your afm, then think of other things
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 04:02 PM
Post #9
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
sweet guys thanks for the help... didn't know about the o2 sensor being only for highway driving... i mainly do city driving do this tells me that the o2 sensor may not be the problem. Am i right in assuming this? You guys reckon just give it a sweet service and change plugs and clean air flow meter and this should improve it somewhat?
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 04:04 PM
Post #10
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
i also hear off some other guys that leaks coming from BOV can cause the car to run leaner is this the case?
Profile CardPM
+Quote Post
(OO)SKYLINE(OO)
post 5 Aug 2008, 04:09 PM
Post #11
Group Icon
Trader Rating : 0
As what sandeep said, the O2 sensor is usuall the problem.
Besides changing that, as momo said, try cleaning your AFM (Air Flow Metres).
So in order to isolate the problem,
Check the O2 Sensor (Fix if faulty)
Use a can of fuel injector cleaner
Clean you AFM
Change your Fuel Filter
Check Tyre Pressure
Only other thing I can think that is making your car use more pertol is your ECU. It might be an aftermarket one or one that can be modified... BUT I don't think so in your case as I believe your car is stock with only an exhaust system and a Front mount intercooler.
BTW you are running 12 Psi of boost... Is that the stock boost pressure for a R33 GTS4?
QUOTE(steve33 @ 5 Aug 2008, 04:04 PM) *
Probley in some cases.
For example if your intercooler has a leak then it may cause the car to run lean as there is more air going in to the inlet plenum.
Profile CardPM
+Quote Post
momo
post 5 Aug 2008, 04:45 PM
Post #12
Car(s): rs four s
Real Name: tim
Trader Rating : 0
QUOTE(steve33 @ 5 Aug 2008, 04:02 PM) *
Its a quick and easy start to eliminate possible causes, if problems persist, see your doctor
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 04:46 PM
Post #13
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
sorry using my mates logins as mine weren't allow me to post with it. I have a series 2 gtst running 12 pound, with front mount, and exhaust, pod etc nothing fancy. It's put out 206 rwkw on a dyno - not a gts4 - sorry bout the mix up. i'll try these things and see how i go. that point you made about an aftermarket ecu being there makes sense also. how can i check this out to see if it is an aftermarket ecu? if it is, should i change it back to a stock one to allow the car to run at factory setting or would the factory ecu setting not comply with the aftermarket enahncements that have been done? p.s i've only owned the car for 4 days and haven't owned a turbo before hence my lack of knowledge
Profile CardPM
+Quote Post
(OO)SKYLINE(OO)
post 5 Aug 2008, 04:58 PM
Post #14
Group Icon
Trader Rating : 0
QUOTE(steve33 @ 5 Aug 2008, 04:46 PM) *
On the front passenger left side, there is a kick pannel. (Below the glove box, to the left), where you red flare sits, unscrew that pannel and the ECU is behind it.
Take a look to see if it is standard or aftermarket.
I don't thing 12 psi standard for a GTS-T..?
R33 GTS-T's came out with about 184 kW. If you are putting out 206 rear wheel kW's, I suspect there is a boost controller you are running. Which means, higher boost = need more fuel to run... And / Or modded / tuned ECU... (Speculations Only)
Profile CardPM
+Quote Post
steve33
post 5 Aug 2008, 05:23 PM
Post #15
Car(s): r33 gts-4
Real Name: stephen
Trader Rating : 2
yea its been boosted up but a few of my mates get 400kms or close to it with exactly the same mods consistantly
Profile CardPM
+Quote Post
(OO)SKYLINE(OO)
post 5 Aug 2008, 05:36 PM
Post #16
Group Icon
Trader Rating : 0
QUOTE(steve33 @ 5 Aug 2008, 05:23 PM) *
Interesting... What type of fuel you put in (should not make a diffence tho...) Is your fuel gauge playing up..?
Car had a service yet?
Best bet is to get your mechanic to check it all out.
Get your mechanic run through what we all have told you about in the this thread and see how you go.
So get them to check the O2 Sensor, (Fix if faulty)
Clean you AFM
Check Tyre Pressure
Check out your ECU
Check out for an leaks in the lines, BOV and intercooler
Check you fuel injectors (make sure no leaks)
And get him to do what sandeep said.
Thats all I can think of at the moment so take it to him and let us know how you go.
Cool!
Profile CardPM
+Quote Post
