1 Aug 2008, 08:16 PM
Xcalibre ![]() ![]() Posts: 18 Joined: 9th May, 2008 From: Southside Briz Car(s): ER34 Real Name: Marc Trader Rating : 0 |
howdy....gotta R34 4 door tiptronic with 4 gears and the exhaust note is soooo annoying on long trips....
wishing for a 5th gear....but that doenst seem to be helping.... so gonna throw on a new muffler/exh..... any suggestions? still want some grunt...but quiet enuff to keep the misus happy on trips to the coast..... still got the standard factory muffler in the garage....anyone want it? whats the best muff for grunt and cruising? |
1 Aug 2008, 08:38 PM
![]() Muppets ![]() ![]() ![]() ![]() ![]() Posts: 1,149 Joined: 28th June, 2004 From: Sydney Car(s): s13 pig Real Name: Nick Trader Rating : 2 |
Check out some custom exhaust shops, depending on where you are based.
Hi Tech in darlinghurst, liverpool exhaust, some other places too. You can eliminate most unwanted noise through resonators. Just try to source a system that is 2.25 inch or 2.5 inch in diameter. -------------------- Mikyel - "so just do ur time,pay the fine, and dont do it again or i wish u DEAD or being paralysed.."
Previous cars: R33 GTS25 |
1 Aug 2008, 10:34 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 295 Joined: 29th October, 2005 From: Surfers Paradise Car(s): Skyline R32 GTS Real Name: Adrian Trader Rating : 1 |
save ur cash & just crank the tunes....
sorry couldn't help myself! |
1 Aug 2008, 10:38 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 208 Joined: 3rd December, 2007 From: Western Vic Car(s): R33 GTS25 Real Name: Josh Trader Rating : 1 |
how adversly do resonators affect noise? i may be in need of one if my EPA test fails...either way i wanna kill my drone aswell
2 Aug 2008, 12:33 AM
Rank: RB20DE ![]() ![]() Posts: 17 Joined: 13th February, 2006 Trader Rating : 0 |
just get one of those exhaust butterflies installed after your cat...... my mate has one on his .... no mufflers.... and it shuts up to almost stock level.... its amazing.... they are illegal... but meh.... whos going to look..... worth a try
4 Aug 2008, 02:27 PM
![]() Rank: RB25DE ![]() Posts: 172 Joined: 22nd August, 2007 From: Victoria Car(s): R34 4 door, '83 Bluebird Real Name: MARK Trader Rating : 0 |
In my opinion - get a set of extractors, highflow cat and keep the stock rear muffler (apparently they have reasonably good flow and are fairly quiet - from memory it is claimed they have better flow than a WRX's muffler...). I have this setup in my car and I'm quite happy with it - Quiet at low revs once you reach above 4500rpm the sound is awesome, similar sounding to a BMW 6 cylinder - Automatics with loud exhausts at low revs don't sound great.
5 Aug 2008, 01:46 AM
#7
In my opinion - get a set of extractors, highflow cat and keep the stock rear muffler (apparently they have reasonably good flow and are fairly quiet - from memory it is claimed they have better flow than a WRX's muffler...). I have this setup in my car and I'm quite happy with it - Quiet at low revs once you reach above 4500rpm the sound is awesome, similar sounding to a BMW 6 cylinder - Automatics with loud exhausts at low revs don't sound great. sounds pricey...but thats exactly what im after....low revs=low noise, high revs=grunt so i should throw the original back on? kinda heavy..... |
5 Aug 2008, 09:41 AM
#8
![]() Local Loco ![]() ![]() ![]() ![]() Posts: 276 Joined: 22nd October, 2006 Car(s): R34 gt-t ke35 Corolla Real Name: Rod Trader Rating : 0 |
get a xforce varex rear muffler
5 Aug 2008, 03:51 PM
#9
sounds pricey...but thats exactly what im after....low revs=low noise, high revs=grunt so i should throw the original back on? kinda heavy..... Yeah, the genuine item is heavy, but i suppose it is the cheapest option for low noise as you already have it in your possession. The setup in my car was already in place when i bought it so I didn't spend anything. The other great thing is that the stock rear muffler will not attract any unwanted attention. |
5 Aug 2008, 04:16 PM
#10
i not sure if the stock item would flow that well.......mayb get a turbo stock muffler that may do the trick for an N/A
5 Aug 2008, 09:53 PM
#11
6 Aug 2008, 11:36 AM
#12
sorry to hijack this thread...
just got a resonator installed on my exhaust system yesterday to reduce the noise. (down to 88db now i had my doubts but after hearing it it was actually worth the money, a much cleaner note now imo, and its legal eventually id probly wanna upgrade to a completely fresh system anyway, but for now this should suffice me...just wondering about it is all. cheers -------------------- ...
8 Aug 2008, 12:37 AM
#13
im in no major rush....so i'll ask and shop around for more advice....
thanks for help fellaz....will report back on the haps.... |
8 Aug 2008, 01:17 AM
#14
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 356 Joined: 4th September, 2005 From: Melbourne Car(s): R33 GTS25 (S1) Real Name: Nick Trader Rating : 0 |
i not sure if the stock item would flow that well.......mayb get a turbo stock muffler that may do the trick for an N/A Flow and noise are directly related. If you want flow, scrap the muffler and get a straight pipe - but it'll be noisy as all buggery. A big fat muffler will kill the noise, but kill the flow too. Basically the more you have in between the engine and exhaust tip the quiter it'll be. Turbo's get away with cannons and the like because the impeller wheel up close to the engine mutes a lot of noise, but NA's don't have that, so a turbo spec muffler will make the noise problem worse. |
15 Aug 2008, 07:05 AM
#15
![]() Formerly FAT32 then FAT34 ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,520 Joined: 11th March, 2003 From: Sydney - South Car(s): S2 '00 R34 GT-V Sedan Real Name: Scott Trader Rating : 58 |
I thought they were the same stock rear muffler between the turbo and N/A...... :S They're not the same. I have a stock N/A system and a stock turbo system and they are quite different in size. I have yet to fit the turbo system but when I do I'll post up some picks and a bit of feedback. *edit* I also have a Fujitsubo Legalis R cat-back system ( on my car at the moment ) and although it was a bit "$" it sounds awesome ! At idle it purrs, on cruise it's silent and when you get up it, it sounds like a BMW M3. Might be worth considering since it sounds like exactly what you're after ( unless you're on a tight budget ). Only reason I'm fitting the stock turbo system is to experiment. Don't know what I'll do if the stock turbo system turns out to be a winner |
17 Aug 2008, 06:50 PM
#16
buzz the catback if you don't put it back on!!!
23 Aug 2008, 06:45 PM
#17
