1 Aug 2008, 07:28 PM
![]() Rank: RB20DE ![]() ![]() Posts: 27 Joined: 15th March, 2008 From: perth Car(s): R32 Real Name: jakub Trader Rating : 0 |
eyy guys any of you know what this could be ....
driving along afta i gave it a bit of stick and soon afta i loose the power steering ! then the HICAS light turns on ( dont think my hicas was working previously anyways ) but still it turned on then i also realized i lost my speedo ! so i was doing 0 kph i checked i still gots my power steering belt motor seems fine no leaks... all fluids are full! if this is any help i just put a heavy duty clutch in but i also checked speedo cable its in and to add also when i turn car off for a bit then start up n take of i get power steering back hicas light is off but no SPEEDo but give it like a minute or 2 and i loose power steerin and hicas light comes up again btw its a 1992 R32 Gts-t ANY HELP WOULD BE GREAT !? |
1 Aug 2008, 07:48 PM
eleventy billion killerwasps @ 3psi ![]() ![]() ![]() ![]() ![]() Posts: 890 Joined: 9th December, 2006 From: Melbourne Car(s): 93 HR32 Real Name: Dave Trader Rating : 13 |
hicas uses the speedo cable, so if it's not working neither will the hicas. since the hicas is joined to the power steering, you'll lose that too.
my friend had this same issue and changed the speedo. everything worked fine after. -------------------- |
1 Aug 2008, 08:24 PM
Rank: RB20DET ![]() Posts: 39 Joined: 25th July, 2008 Car(s): R32 GTST 4 DOOR Real Name: BRAD Trader Rating : 0 |
that is true wat old mate said but before you replace the speedo head check the cable isn't broken as well. i've had this happen to my r32.
1 Aug 2008, 08:55 PM
CheeRs heaps boyz i was jus in the garage had the car up on the hoist looking around frantically um is this costly to change/fix
ill have a good look at the cable where is the speedo head located im not that much a gun mechanic |
1 Aug 2008, 10:04 PM
sorry mate. the speedo head is the actual speedo.
8 Aug 2008, 07:57 AM
that's racing! ![]() ![]() ![]() ![]() Posts: 18,462 Joined: 10th May, 2002 From: Sydney Car(s): bnr32,z33,wgnc34,ungd21 Trader Rating : 18 |
most often the cable breaks internally - so the sender at the gearbox turns but the speedo end does not. check the gearbox end is conneced properly - the cable goes to the side of the gearbox towards the back of it
8 Aug 2008, 05:51 PM
#7
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 214 Joined: 13th February, 2008 From: Westside (Hoppers) Car(s): R32 gts-t, ford laser Real Name: Andrew Trader Rating : 7 |
i had the exact problem change the speedo cable dont buy second hand there 100 bucks from nissan....it was a kunt for me to install as i knew nothing...but at the end was pretty simple escpecialy if you have a haust i had a stock jack arhhhh good luck
Lo-Fi Version | Time is now: 22nd August, 2008 - 12:46 PM |
