31 Jul 2008, 09:32 PM
Rank: RB20DE ![]() ![]() Posts: 23 Joined: 26th March, 2007 From: Perth Car(s): R33 S2 GTS4 (Coupe!!) Trader Rating : 0 |
hey guys, im basically looking for a list of what needs/should be done for a 100,000km service on an rb25de, as im looking to do some of the easier parts myself, while leaving the difficult stuff (such as timing belt) to a mechanic, if it makes any difference the car its in is a r33 series 2 gts-4
31 Jul 2008, 09:39 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() ![]() Posts: 393 Joined: 23rd January, 2008 From: Sydney, Bankstown Car(s): Nissan Skyline R34 25GT Real Name: Vicky (vikZ) Trader Rating : 0 |
Im bout to hit 100000 myself. Some info would be great!
MRXTCZ -------------------- Source: Pioneer AVHP5950DVD
Front: Rockford Fosgate T162S Splits Rear: Rockford Fosgate T162C Coaxials Subs: 2 x 12" MTX Thunder X Amps: Jaycar Response 2 Channel (2x150) Jaycar Response 5 Channel Full Range Wiring: Aerpro Dual Amp Kit and Stinger RCA's and Speaker Cable Future Mods: CAI, 2 1/4" Cat back & Lower front and rear. |
31 Jul 2008, 09:46 PM
![]() (,Ò ò\ N D A W G /ó Ó,) ![]() ![]() ![]() ![]() Posts: 138 Joined: 25th January, 2008 From: Brisneyland Car(s): Skyline R34 25GT 4 Door Real Name: Nathan Trader Rating : 2 |
Get the tensioner and idler pulleys and seals done at the same time. I got my 100,000km belt kit from Croydon.
Some advise doing the water pump at the same time. |
4 Aug 2008, 11:07 AM
How much was the kit and what does it consist of ?
4 Aug 2008, 11:51 AM
How much was the kit and what does it consist of ? MRXTCZ I got the Gates Timing Belt Kit for $260 + $15 freight from Croydon. That was with the standard black belt. The blue high performance belts cost more. I've seen some on ebay: http://cgi.ebay.com.au/SKYLINE-GATES-RACIN...Q2em118Q2el1247 I had actually seen one store on ebay selling them at quite varying prices due to them starting at lower prices rather than buy it now. I can't seem to find it at the moment, that and I'm at work now, but do a search you might be in luck The more expensive part in getting the belt changed is the labour |
4 Aug 2008, 12:52 PM
Haha labour's free for me
So Belt kit. Water Pump. Anything else ? MRXTCZ -------------------- Source: Pioneer AVHP5950DVD
4 Aug 2008, 02:15 PM
#7
![]() Rank: RB25DE ![]() Posts: 161 Joined: 22nd August, 2007 From: Victoria Car(s): R34 4 door, '83 Bluebird Real Name: MARK Trader Rating : 0 |
I got the Gates Timing Belt Kit for $260 + $15 freight from Croydon. That was with the standard black belt. The blue high performance belts cost more. I've seen some on ebay: http://cgi.ebay.com.au/SKYLINE-GATES-RACIN...Q2em118Q2el1247 I had actually seen one store on ebay selling them at quite varying prices due to them starting at lower prices rather than buy it now. I can't seem to find it at the moment, that and I'm at work now, but do a search you might be in luck The more expensive part in getting the belt changed is the labour $260 is quite expensive even for a Gates branded belt. If you are not going to do any mods go the genuine nissan belt for about $90 - It is available from the Nissan dealership. |
4 Aug 2008, 02:45 PM
#8
4 Aug 2008, 11:22 PM
#9
![]() Spoiler-less 4 Door Love.. ![]() ![]() ![]() ![]() ![]() Posts: 1,558 Joined: 27th January, 2007 From: Sydney/Bathurst Car(s): R32 GTS4 Real Name: Cris Trader Rating : 5 |
Oil
Oil filter Air filter / Clean pods Fuel filter Battery (If you think is getting old) Radiator Coolent Flush Brake pads / Machine Disks (If worn) Timing Belts / Fan Belts Spark Plugs Check all your tyres (Change if worn) Gear Box oil (If had not been done) Check under the car / drivetrain Water pump timing belt tension idler spark plugs fluid flush oils -------------------- |
28 Aug 2008, 05:22 PM
#10
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 194 Joined: 3rd December, 2007 From: Western Vic Car(s): R33 GTS25 Real Name: Josh Trader Rating : 1 |
just got quoted in the vicinity of $800 for my 100,000k service
-sigh- iv still got 11,000ks to play with tho until it hits 100,000 i spose. but i dunno -------------------- ...
28 Aug 2008, 06:57 PM
#11
![]() rb25det ![]() ![]() ![]() Posts: 77 Joined: 9th September, 2007 From: south west vic Car(s): r33 gtst, vt ss Real Name: jake Trader Rating : 2 |
join onboost get 10% off at wbool nissan. what they quote you for. ie timing belt, water pump etc
28 Aug 2008, 07:13 PM
#12
Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,061 Joined: 24th October, 2002 Car(s): R33 GTR V-Spec Trader Rating : 205 |
I make a few kits timing belt/water pump service kits, to suit both turbo and non turbo engines, using OE & OEM parts and they start from only $345.40. If you are interested simply follow the link below:
http://www.skylinesaustralia.com/forums/Ni...ml#entry2561805 -------------------- |
Lo-Fi Version | Time is now: 8th October, 2008 - 10:21 AM |
