IPB
> Couple Of Rb26/30 Questions, ....yes have searched already=0
Z24O
post 26 Jul 2008, 01:11 PM
Post #1
Trader Rating : 7
collecting parts for 26/30 conversion but need a couple of answers....
1) rb30 or rb26 head gasket?
2) looking for maximum torque and 7000rpm limit,any advantage to swapping std cams out for regrinds...if so what specs?
3) anyone used a copper head gasket,any dis/advantages?
4) worth 'O' ringing the block?
5) is the std nissan head gasket better than the cometic?
6) will the std RB30 balancer be ok under 7000rpm?
8) suggested single turbo for low end torque?
cheers guys
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
VB-
post 26 Jul 2008, 02:40 PM
Post #2
Car(s): VL N/A 5 speed
Trader Rating : 0
well i've been way off on alot things lately so make sure you get a second opinion, but i'll give you a start where i can
1. cant remember, someone told me you can use either, but i get a feeling you need the twin cam one - i know that wasnt much help (told you you'd need a second opinion)
2. for a street car, use standard cams. i think Ben (racepace) put standard cams back in his race car after having larger ones in there, thats saying something?
3. copper gaskets, not much first hand experience, but in theory - good because they conduct heat well, meaning less chance of heatspots forming on the ring of the gasket, bad because they can have issues with seepage
4. probly not for lower power levels, and i *think* thats mainly for copper gaskets???? someone confirm that for me
5. cometic is better (MLS gaskets)
6. is it in good condition? see how much you can get a new one for, its cheap insurance really
7. you cant count lol
8. GT35R
Profile CardPM
+Quote Post
r33_racer
post 26 Jul 2008, 07:45 PM
Post #3
Incase you didnt notice, I just did over a thousand!
Car(s): R33 X 2, Yammy 05' R1
Real Name: Michael
Trader Rating : 1
i would change 8 to gt30r.
number 1 to twin cam headgasket fo shizzle.
*6BOOST MANIFOLDS*
STEAMPIPE EXHAUST MANIFOLDS TO SUIT ALL RB ENGINES
CALL KYLE :0410 730 598
Profile CardPM
+Quote Post
VB-
post 27 Jul 2008, 10:49 AM
Post #4
Trader Rating : 0
i had tought about mentioning GT30, i think cubes runs one? but its mixes results, some say it comes on too hard too early and just results in wheel spin, obviously it will yeild more low down torque, but its too much?
edit - just read a post of cubes saying its very linear.... and doesnt reult in wheel spin, GT30 might be an option
Profile CardPM
+Quote Post
Z24O
post 27 Jul 2008, 02:19 PM
Post #5
Trader Rating : 7
thanks fellas
i've got a spare gt3076 but it's a IWG/0.82 turbine housing which i am presuming is too small for the twin can rb30.....also my manifold is T4 flange/external wastegate,as are most aftermarket ones
Profile CardPM
+Quote Post
Adriano
post 27 Jul 2008, 07:22 PM
Post #6
Rank: RB30E
Trader Rating : 19
Im building a 30/25 neo at the moment, will be running .86 gt3076, i think it will be the ultimate street setup. No lag with over 300rwkw within easy reach
R32 gtr Rb30
Eagle rods, custom sump and plenum
Arias Pistons, Toda 272 10.2mm cams
Sard 720cc inj, MSD Cdi
Ported head, HKS T45s, HKS 50mm w/g
100mm HKS intercooler 100mm throttle body
355mm AP discs 6 piston Porsche Brembos
Nistune live mapping, hoping for 450AWKW
Profile CardPM
+Quote Post
Z24O
post 27 Jul 2008, 09:39 PM
Post #7
Trader Rating : 7
QUOTE(Adriano @ 27 Jul 2008, 05:22 PM) *
you don't reckon it will be like a like switch??
when are you expecting boost to start and be all in by rev wise?
300rwkw at what psi?
Profile CardPM
+Quote Post
Adriano
post 27 Jul 2008, 09:49 PM
Post #8
Rank: RB30E
Trader Rating : 19
QUOTE(Z24O @ 27 Jul 2008, 09:39 PM) *
The opposite of a light switch, it should be a torque monster, making meaningful boost and torque from 2500. Full boost of about 16 psi should be in by below 3500.
R32 gtr Rb30
Profile CardPM
+Quote Post
Z24O
post 28 Jul 2008, 02:05 PM
Post #9
Trader Rating : 7
QUOTE(Adriano @ 27 Jul 2008, 07:49 PM) *
even with the 0.82 turbine housing?i thought they were choked up on an rb30et let alone a twin cam 3.0l
Profile CardPM
+Quote Post
r33_racer
post 28 Jul 2008, 04:42 PM
Post #10
Real Name: Michael
Trader Rating : 1
we had a .82 gt30 on our old rb30det...think we pushed 365-370rwkws out of it with water/meth injection on shell 100 pulp. 8k redline and it was pulling all the way...didnt die out at all from memory. 256 8.5mm tomei poncams and greddy inlet, is what helped it maintain that power rise to redline...atleast thats what i think...maybe the water/meth injection too tongue.gif
*6BOOST MANIFOLDS*
Profile CardPM
+Quote Post
James_03
post 29 Jul 2008, 12:50 PM
Post #11
30 > 26
Car(s): rb30dett 4wd r32 gtr
Trader Rating : 4
QUOTE
cheers guys
1. Either way, more options available 26 way but.
2. Standard cams, go pon cams if anything.
3. Yes I have used them, prefer mls gaskets but less dicking around.
4. Only if your going copper gasket
5. No
6. Yes, ati to be safe but.
7. 35r as previously mentioned.
www.r31skylineclub.com
Profile CardPM
+Quote Post
Z24O
post 30 Jul 2008, 04:44 PM
Post #12
Trader Rating : 7
so anyone with a GT30 on their RB26/30 want to chime in as to hp/torque/psi
a few guys reckon they saw boost/rpm much the same with the GT35 as the GT30 on the 3.0l twincam....as usual can't find the thread again,think the guys name was darren and he had it in an r31??
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th August, 2008 - 07:50 AM
