25 Jul 2008, 02:56 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 790 Joined: 15th November, 2005 Trader Rating : 13 |
Hi All
Did a search maybe not typed in the right things but am looking for the correct way of putting in a PS cooler, I dont have HICAS anymore and all the solonoids have been removed previously. The rear stage of the pump was blocked off with a machined out washer/piece and orig bolt bolted back up to block it off. Ive attached a diagram. Can anyone tell me is that is the correct way to fitting the cooler as in connections to right places. |
25 Jul 2008, 02:58 PM
![]() ビール男爵 ![]() ![]() ![]() ![]() Posts: 17,551 Joined: 9th May, 2003 From: West Shinjuku MOS Burger Car(s): 32GTR 34GTR S13 Truck Real Name: Richard Trader Rating : 147 |
good question. I'm not 100% on if that is ok or not, but the easiest way is just to run it in series with the factory cooler. the factory cooler/dampener is up the front near the radiator. just unplug the hose going into one end of it, plug that to your new cooler then run a hose from the new cooler outlet to the old factory ones inlet. done.
-------------------- Beer Baron's Japan Photo Diary. CLICK HERE!
Now with 2007 Nismo Festival Pics :) AND now with Tsukuba Hyper Rev Super Lap battle pics too. 28/12/07 added more pic. Some Tokyo pics and Garage Saurus pics. :) My Super Clean Nissan Atlas 200 Truck for sale, feel the awesome 4.2ltr diesel power whilst comfortably transporting your goods! http://www.skylinesaustralia.com/forums/Be...as-t227090.html Also now selling my R34 GTR!!! Very neat, standard 34 GTR, low-ish kms, KV2 Silver worth checking this one out... http://www.skylinesaustralia.com/forums/Ba...ll-t230835.html |
25 Jul 2008, 03:00 PM
![]() Axe S ![]() ![]() ![]() ![]() Posts: 374 Joined: 21st March, 2006 From: Gladstone Qld Car(s): R33 GTS-T 4dr, VY SS Trader Rating : 3 |
well if your coming of the return side of the pump it's right...
That would be the hottest part by my guess.... -------------------- Buy my GT30/35 0.5A/R compressor housing
Wanted wastegate springs to suit a Tial 44mm around 16psi R33 4door - 450RWHP/335.5RWKW - High mount GT35/40, Tial 44mm Wastegate, Sard 800cc injectors, Haltech E11v2, Turbo smart T-Reg 1200, GReddy fuel rail, Trust FMIC, GReddy style Plenum, |
31 Jul 2008, 10:15 PM
anyone know if i can use hose n clamp? or do i need a one like OEM one cos of the pressure of the pump?
31 Jul 2008, 10:51 PM
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 902 Joined: 20th May, 2003 From: Terra Firma Car(s): R32GTR, S2K Trader Rating : 1 |
why are you doing this godzl1975?
Is your power steering fluid overheating? -------------------- |
1 Aug 2008, 03:13 AM
![]() Fear teh Admins POWAH ![]() ![]() ![]() ![]() Posts: 21,405 Joined: 3rd August, 2002 From: Windsor - Vic Car(s): HR31 GTS-R Trader Rating : 6 |
^^ same thing i was wondering also.
I have never heard of it being a problem... and by adding a cooler all your doing is bringing another element/point of failure into what is already a perfect setup. -------------------- SAU-Vic President - 2008
If you have any suggestions or ideas, be sure to send them through. Wanted to Buy R33 GTR - Stock Dumps & AFMs. After a few sets. PM me |
1 Aug 2008, 10:16 AM
#7
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,432 Joined: 14th July, 2003 Trader Rating : 11 |
There is already a cooler for the PS system in the GT-R's. It is infront of the radiator, but behind the I/C on the drivers side of the bonnet latch. It is simplty a small diameter pipe with external fins.
Simply remove it & replace it with a proper sized cooler. A small 100mm by 250 ish size is more than adequate. That is what I did & it stopped the P/S fluid from getting hot, expanding & then leaking out of the top of the reservoir. And yes hoses & clamps work fine. |
3 Aug 2008, 08:19 PM
#8
![]() too much kw to handle on ps ![]() Posts: 1,383 Joined: 2nd March, 2005 From: Melbourne - Eastern Car(s): M.N.P. GTR, Daytona GTR Real Name: Mat Trader Rating : 132 |
Thats exactly what I did, except the thing is that the cooler runs off the HICAS part of the system.
So yes thats how you connect the cooler, I used hose and clamps, no issues, trackdays completed with no overflow! (yes fluid is at spec'd level) -------------------- ** In the top 15 traders for SAU! ** Stainless GTR Front Pipes FS * R32 Aircon Condensor FS Sandown: 1:28 - Rooted semi-comps Winton: 1:40 - Streetys |
Lo-Fi Version | Time is now: 7th October, 2008 - 09:54 AM |
