IPB
> Cams Upgrade, Need new ecu?
ginger
post 23 Jul 2008, 10:12 PM
Post #1
Red heads do it better..
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
Hey all, tax return time has come around again.
I have lined myself up some upgraded cams, just wondering do i need a new ECU to go with it.
As im fairly sure the stock ecu wont take it or wont be tunable enough to get all the power gains.
Any info would be great guys.
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
R34GTFOUR
post 24 Jul 2008, 12:25 AM
Post #2
Car(s): R34 Gt-Four, R33 Gtst
Real Name: Steve
Trader Rating : 7
what mods do you have now? the stock cams wont be giving you too much of a restricition if you just have basic mods as it is (which is probably the case if you're running stock ecu), its probably better to spend that money else where.
if you already have the basic catback and CIA setup, maybe go for some headers, or get you ecu "chipped" so it can be tuned, either of those options will give you better gains then dropping in some cams in an otherwise stock engine
also, i would also think of other areas besides just the engine to spend money on. If its a gts, try and source the gtst brakes which would give you much improved braking, or if your suspension is fairly stock get some upgraded springs/shocks or get a new adjustable coilover, or sway bars etc...
depending on how much you are willing to burn (yes burn because you wont get it back, its all fun though), cams probably isnt the best option
IS BOOST IS GOOD
Profile CardPM
+Quote Post
ginger
post 24 Jul 2008, 09:24 PM
Post #3
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
its a work in progress.
Already have extractors cia, pod.
Cams and head will be done in one go. then coil overs. thats the plan.
I just dont want to stuff around with the standard ecu. plus the computer can be transferred from car to car. so i might actually get some use out of the computer.
Profile CardPM
+Quote Post
R338OY
post 24 Jul 2008, 09:37 PM
Post #4
R33Bizzle
Car(s): R33 GTS-T
Real Name: Omar
Trader Rating : 2
Cams are really a waste unless you want 280kW+, have a laggy ass turbo or are adamant to have fat response.
To bother with buying them, fitting them, retuning = for any less power you won't see a massive gain over stock cams IMO.
But if it's part of your mod plan then go for a decent set (HKS, Tomei).
RENAISSANCE
Profile CardPM
+Quote Post
ginger
post 24 Jul 2008, 09:54 PM
Post #5
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
well considering its a NA i want to get all the power i can out of the engine before i work on coil overs.
But its good to hear peoples opinions
Profile CardPM
+Quote Post
GTS4WD
post 24 Jul 2008, 11:44 PM
Post #6
Spoiler-less 4 Door Love..
Car(s): R32 GTS4
Real Name: Cris
Trader Rating : 7
What about a port and polish before hand? Then Cams?
With a port and polish you could easily get away with using just an SAFC.
Port and poilish will require the head coming off and buying a new head gasket.. but you will see more of gain there and will give cams (if you choose to do so down the road) more of kick up the arse.. especialy with a set of adjustable cam gears too.
4Door Love..
Bragging about and relying on power is like admiting you slept with your cousin.. just proves your retarded.. but HEY!.. what do I know.. i have never slept with my cousin..
WTB: Buttload of R32 Body pannels! Stock and aftermarket!
WTB:300-330mm Steering wheel: Older Momo/Nardi/Personal Style wheel PM ME!
Profile CardPM
+Quote Post
R338OY
post 25 Jul 2008, 01:24 AM
Post #7
R33Bizzle
Car(s): R33 GTS-T
Real Name: Omar
Trader Rating : 2
QUOTE(ginger @ 24 Jul 2008, 09:54 PM) *
My apologies didn't realise it was NA. In that case cams (and yes a P&P too) and gears would be a great addition. You're going to obviously want the extra lift from bigger cams to squeeze more air/fuel in, and if you ported it that would reduce the restriction on that process and you'd get more out of the setup.
Good luck champ.
RENAISSANCE
Profile CardPM
+Quote Post
ginger
post 25 Jul 2008, 02:01 PM
Post #8
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
thanks heaps r33boy. im going for maybe a stage 2 with high lift and a shorter duration, if that makes sence
Profile CardPM
+Quote Post
GTS4WD
post 25 Jul 2008, 02:36 PM
Post #9
Car(s): R32 GTS4
Real Name: Cris
Trader Rating : 7
You can always get our cam re-grinded.. its about $200 odd oer cam.. so it saves you $200 for an adjustable cam gear. or Apexi SAFC and tune..
4Door Love..
Profile CardPM
+Quote Post
MissR34
post 26 Jul 2008, 01:35 PM
Post #10
RB25DE Just Kicked in Yo!!
Car(s): 99 R34 GT
Real Name: Cara
Trader Rating : 1
yes you will need an ECU upgrade.....unless someone has already said that didnt see anything along those lines tho blink.gif but i could be mistaken.
thats the one thing im glad i did last year....i got a Apexi Power FC.......this will now allow me to do so much to the car and know that anything i want to in the future i am already set up with the ecu.
but when i was talking to my mechanic/dyno guy he did say that a aftermarket ecu would be needed.
i cant wait till i get my cams thumbsup.gif prob wont be this year tho sad.gif but will be hopefully next year ive gone and spend my tax return on some very lovely Isotta Indiana Seats smile.gif i am happy with them lol
DZIGNFX 8351 8115
SOUTHERN HITECH DYNO 8277 4400
ADELAIDE TYREPOWER 8410 1312
EXHAUST TECHNOLOGY 8272 7500
Profile CardPM
+Quote Post
ginger
post 26 Jul 2008, 05:33 PM
Post #11
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
Im going with the better ecu just to save hassle down the track. and less stress in the future.
Profile CardPM
+Quote Post
ignuz
post 1 Aug 2008, 08:51 PM
Post #12
Muppets
Car(s): s13 pig
Real Name: Nick
Trader Rating : 2
I heard this deep sounding 33 arrive at DA a month back, looked over and it was you!
Did you free up the exhaust even more or was it always that loud?
If it were me btw, I'd go coils first. While cams and a port and polish will give a bit more grunt, a decent set of coil overs will have you out handling a few few other cars on the road.
Mikyel - "so just do ur time,pay the fine, and dont do it again or i wish u DEAD or being paralysed.."
Previous cars: R33 GTS25
Profile CardPM
+Quote Post
ginger
post 5 Aug 2008, 09:03 PM
Post #13
Car(s): R33 GTS
Real Name: david
Trader Rating : 0
Hey man.
I think she has always been that loud. Wats the DA?
Well so far im just going by the list, First was clutch-then cams and computer- then coil overs. its probly in reverse order but it works for me.
Hows your pig going?
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st November, 2008 - 10:03 PM
