IPB
> Power Steering Problem - R32, Please help
GTS4-32
post 22 Jul 2008, 04:01 PM
Post #1
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
Hey Guys, recently my battery died because i left my lights on so i had to jump start it, so after ive jump started the battery ever since then ive had this problem with my power steering.
now i dont know if its got to do with the jump start or if it was just a coincidence, but my power steering is now screwed, it gets really hard at times to turn a corner.
When i turn a roundabout for example itll seize up and release, its mixed. So its not like its hard the whole way round, just split moments if im making sense. Now ive checked my reservoir and its full and doesnt seem to be leaking, and my p/s fuse seems to be fine, so any information you guys can give me would be much appreciated. wink.gif
Cheers,
Steve.
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
HI2U
post 22 Jul 2008, 04:04 PM
Post #2
Car(s): Nissan Skyline R32 GTS+T
Real Name: Kyle
Trader Rating : 10
try flushing out your powersteering fluid and fill it up again, might be some bubbles in it or something
PM for cheap JDM wheels
WORK, RAYS, SSR
BUY MY 17x9 VS-KF
http://www.skylinesaustralia.com/forums/17...kf-t229313.html
Profile CardPM
+Quote Post
GTR1993
post 22 Jul 2008, 04:20 PM
Post #3
Car(s): GTR
Real Name: Alex
Trader Rating : 4
Dont flush it, its a waste of time, its self bleeding system.
Other then that im not sure someone else will have to give you some insight. Maby the hicas computer gone to shit creek with the jump start, but i wouldn't think so.
Profile CardPM
+Quote Post
Above_BAR
post 22 Jul 2008, 06:42 PM
Post #4
Rank: RB20DE
Trader Rating : 0
the main reason for heavy steering is a leak somewhere. and considering the numerous little pieces of presumably old rubber between the diferent hard line sections scattered all over the car, including the ones back to the hicas..... ya probably leaking somwhere.
replacing old power steering lines has become a hobby of mine with my 32.... just about got them all.
Profile CardPM
+Quote Post
QWK32
post 22 Jul 2008, 09:45 PM
Post #5
Car(s): S2 Stagea RS4
Real Name: Josh
Trader Rating : 10
probably a fault with the vehical speed sensor, maybe fried it when you jump started. as i understand it, when your at idle and not going anywhere a solinoid switches the powersteering pump into a low pump mode so it doesn't bog the engine down, once you start moving it swiches the pump to full. if you speed sensor if playing up the pump wont be switching into full mode hense the heavy stearing.
try doing a ecu diagnostic and HICAS diagnostic and see if you get an error code. there is info on this in the tutorial section. or if you know someone with a consult cable get them to check for you.
Profile CardPM
+Quote Post
GTS4-32
post 23 Jul 2008, 05:51 PM
Post #6
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
Thanks guys, ill have to run a full check with leakage in the hoses and ill suss out the diagnostic checks, thanks again guys, ill report back as soon as ive completed it.
Cheers,
Steve.
Profile CardPM
+Quote Post
blind_elk
post 24 Jul 2008, 12:51 PM
Post #7
No-eyed Deer
Group Icon
Car(s): R32 GTS25t-4, R30 hatch
Trader Rating : 2
It's a voltage problem. You may well have to replace the battery.
STRESS - the confusing emotion created when the mind overrides the body's basic desire to bash the crap out of some jumped up little turkey who's been asking for a knee in the cobblers for the last six months
National Stroke Week September 15 - 21.
Act FAST - support stroke research www.strokefoundation.com.au
Profile CardPM
+Quote Post
heller44
post 24 Jul 2008, 08:06 PM
Post #8
strange how i falter
Group Icon
Car(s): r32 gts4 rb26dett
Trader Rating : 2
My pick as well.
Profile CardPM
+Quote Post
GTS4-32
post 28 Jul 2008, 11:30 AM
Post #9
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
but the voltage is fine on my battery, it runs at 14-15 volts when im driving, so whats it got to do with the pump? I dont get how its the battery?
Profile CardPM
+Quote Post
blind_elk
post 28 Jul 2008, 12:45 PM
Post #10
No-eyed Deer
Group Icon
Trader Rating : 2
The alternator is putting out too much voltage trying to re-charge the battery after starting. The HICAS ECU judges this to be a problem, and plays silly buggers with the HICAS pump.
Profile CardPM
+Quote Post
GTS4-32
post 28 Jul 2008, 02:39 PM
Post #11
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
i see, interesting. Ill have another battery put in and see what happens, thanks.
Profile CardPM
+Quote Post
THENIG
post 28 Jul 2008, 04:02 PM
Post #12
Rank: RB20DET
Group Icon
Car(s): 4-Door R32
Real Name: Rob
Trader Rating : 0
QUOTE(blind_elk @ 24 Jul 2008, 12:51 PM) *
Same thing happened to me a few weeks ago, its definitely voltage, mine turned out to be the alternator had packed it in. The HICAS solenoid was opening and closing with a lack of voltage at idle whilst driving at night with headlights and accessories on. Sounded like there was something caught around my drive shaft and slapping against the foot well but really it was the pressure building up in the lines by the pump and then and getting released sending a shock wave through the lines, it was only audible at a standstill at low revs, when i was moving it just turned into heavy-light-heavy steering as i was turning a corner. My alternator seemed to work on start-up when it was cold (14.5V i think) then stopped working after a few minutes causing rough idle, whine through the stereo and dim headlights. I ended up killing a battery a new battery in the process by dropping it below 8V for too long and it never came back even after i changed the alternator. In the process of getting a battery zapper to see if i can bring it back to life, cold winter mornings are asking alot more from the battery than usual. Its been 2 weeks with a new alternator and haven't had any steering problems which used to happen everyday.
Profile CardPM
+Quote Post
GTS4-32
post 29 Jul 2008, 02:49 PM
Post #13
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
it wasnt the battery or the alt. I went past oh performance and they seem to believe it may be the power steering pressure sensor, so im looking at changing that to see what happens, but i cant seem to find 1. Anyone know where i can find 1?
Profile CardPM
+Quote Post
heller44
post 29 Jul 2008, 10:37 PM
Post #14
Group Icon
Trader Rating : 2
I know it has been posted previously, but have you done a hicas diagnostic? What were the results?
Profile CardPM
+Quote Post
116.hks
post 29 Jul 2008, 10:55 PM
Post #15
Rank: RB20DET
Group Icon
Car(s): R32 GTST 4 DOOR
Real Name: BRAD
Trader Rating : 0
hey mate. if your alternator is overcharging for example 15volts and over it could be spiking the computer and the system is shutting down because of it saving the components in your power steering. charge rate for all vehicles should be no lower then 13.5v and 14.8v. some of these problems i've seem through my workshop are caused from an intermitted charging fault. the battery wont cause the problem as it is only a storage device, once the vehicle is running the alt runs the vehicle, not the battery. hope the helps.
Profile CardPM
+Quote Post
GTS4-32
post 1 Aug 2008, 03:34 PM
Post #16
RB20-HNR32
Group Icon
Real Name: Steve.
Trader Rating : -1
yea thanks mate, it is overcharging, because what ive realized is when i start the car the voltage sits at around 12v and the steering is perfect, as soon as i give it a rev past 3,000rpm the volts rise to about 14.5-15.0v and the steering is rough.
But another thing that happened that i found really weired is i changed my fuel pump the other day and ever since then, night time driving is great, voltage sits from 13.9-14.3 and steering is perfect but day-time driving sits at 14.5-15.0 again. Thats trippy shit.
So anyway, we've come to the conclusion that the alt needs to be changed.
Thanks for all the feedback guys.
Profile CardPM
+Quote Post
0 Members:
