22 Jul 2008, 11:40 AM
![]() Houstan....we have traction!!! ![]() ![]() ![]() ![]() Posts: 134 Joined: 23rd July, 2006 Trader Rating : 4 |
Hi Everyone,
I have doubts that my 1989 R32 GTR has the original gearbox and clutch, how can I tell for sure whether it's a push or pull type clutch? I do know it has to do with which side of the clutch fork that the slave cylinder is on, but I cannot find anywhere clarification on which is which. What type of clutch is it, if the slave cylinder is on the engine (or front of car) side of the clutch fork? If I can find this out then it obviously also answers for the opposite side. Please only post if you know for sure as I've already read enough threads on here and GTROC UK where the information is incomplete or there are conflicting opinions...I need facts! Thanks to everyone in advance Cheers! Craig -------------------- ![]() |
22 Jul 2008, 08:55 PM
that's racing! ![]() ![]() ![]() ![]() Posts: 18,947 Joined: 10th May, 2002 From: Sydney Car(s): bnr32,z33,wgnc34,ungd21 Trader Rating : 18 |
Its dead easy....look at the way the clutch slave rod points.
If it points to the front of the car it is a push clutch. If it points to the rear of the car it is a pull clutch. So yours is pull if its on the engine side and points rear. Good score in an 89 GTR. -------------------- |
22 Jul 2008, 08:59 PM
![]() Official RH9 club member ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,557 Joined: 23rd September, 2005 From: Newcastle Australia Car(s): 9sec street GTR Trader Rating : 31 |
Its dead easy....look at the way the clutch slave rod points. If it points to the front of the car it is a push clutch. If it points to the rear of the car it is a pull clutch. So yours is pull if its on the engine side and points rear. Good score in an 89 GTR. its the opposite of what is said above. -------------------- ![]() By dirtgarage Need an engine built ?...contact Red R Racing at Dgarage@bigpond.net.au Red R Racing is proud to be associated with the following companies... GODZILLA MOTORSPORT, HI OCTANE RACING, HYPERTUNE AND AWARD DIFF AND GEARBOX ![]() |
22 Jul 2008, 09:01 PM
good point....I shouldn't stand on my head when looking under the car
22 Jul 2008, 09:05 PM
good point....I shouldn't stand on my head when looking under the car cool...now R31 Gagz...if the rod out of the cylinder is pointing rearwards its a push (actual cylinder is positioned in front of the clutch fork) obviously the other way is pull. -------------------- ![]() By dirtgarage Need an engine built ?...contact Red R Racing at Dgarage@bigpond.net.au Red R Racing is proud to be associated with the following companies... GODZILLA MOTORSPORT, HI OCTANE RACING, HYPERTUNE AND AWARD DIFF AND GEARBOX ![]() |
23 Jul 2008, 09:20 AM
good point....I shouldn't stand on my head when looking under the car You had it right...in a way cool...now R31 Gagz...if the rod out of the cylinder is pointing rearwards its a push (actual cylinder is positioned in front of the clutch fork) obviously the other way is pull. Thanks DG, that's exactly what I was after Cheers! Craig PS...mods, could this thread be stickyd or the information added to an FAQ, it was very hard to find -------------------- ![]() |
23 Jul 2008, 01:12 PM
#7
![]() Godzilla ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 7,126 Joined: 13th November, 2002 From: Western Sydney Car(s): Hayabusa Real Name: Ben Trader Rating : 5 |
Why the difference, are the later pull clutch designs more efficient or better or?
-------------------- WSID: 12.348sec @ 113.56mph - 1.793 60ft (R32 GTR)
Eastern Creek Circuit: 2m:16sec (R33 GTS-t) Wakefield Circuit: 1m:21sec (R33 GTS-t) Oran Park South Circuit: 1m:07sec (R33 GTS-t) WSID Tow car driver of Australia's quickest GTR - 7.87sec @ 178mph R32 GTR Full Exhaust $450 - 2x Z32 AFM's + Plugs $390 |
24 Jul 2008, 09:07 PM
#8
Why the difference, are the later pull clutch designs more efficient or better or? Hi Ben, Yeah really not sure either, possibly it just works better? The pull type clutches cost slightly more than the pull type, so that's one con...you would hope there were some good pros for paying more Does anyone else know why they changed to a pull type clutch on post 1993 model R32 GTRs? Cheers! Craig -------------------- ![]() |
25 Jul 2008, 08:51 PM
#9
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 898 Joined: 17th January, 2007 From: Brisbane Car(s): S2 Stagea RS4 Real Name: Josh Trader Rating : 10 |
lighter on the foot and quiter engagement.
Lo-Fi Version | Time is now: 11th October, 2008 - 11:52 AM |
