IPB
> Clutch Slips Brand New Clutch
iwantagtr
post 20 Jul 2008, 08:41 AM
Post #1
IWANTAGTR
Car(s): R33 GTST,R32 GTR
Trader Rating : 0
Hi I have got a s1 r33, I have just finished doing a conversion from auto to manual and my clutch has slipped from day dot.
-It is a brand new clutch and I dont believe there is any air in the system as I have bled it a numerous amount of times. (i also got a mate to bleed it for me as well)
- The flywheel has been machined
-There is freeplay at the throw out fork, although once you bleed the system up the clutch fork feel as though it is getting stuck and looses it freeplay.
-I have adjusted the master cylinder push rod to what i believe is the correct adjustment ( it has a little feeplay at the top of the pedal)
-I have cleaned both master and slave cylinders (they weren't that drty to start with)
I really do not know what is going on or why my clutch continuosly slips, if anyone could help that would be much appreciated.
Thanks in advance
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
NYTSKY
post 20 Jul 2008, 11:13 AM
Post #2
GET TO THE WIN!
Group Icon
Group Icon
Car(s): R33 S2,98 Proton
Real Name: Dave
Trader Rating : 25
Sorry to hear mate, im having the opposite problem,brand new clutch but mine wont disengage.
Ive done every thing you have done,so now ill be pulling the out next week sad.gif
MY ENGINE BUILD THREAD!!!!
RB26 & RB25 CP,EAGLE,TOMEI,ARP ENGINE REBUILD KITS UNDER 3K DELIVERED!!!!!!! <------CLICK
HID KITS $120 DELIVERED!!! PM ME TO PLACE YOUR ORDER!!!
FEDERAL TYRE GROUP BUY NOW ON!!! PM ME FOR DETAILS!!!!
Profile CardPM
+Quote Post
Cubes
post 20 Jul 2008, 01:05 PM
Post #3
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
When you say slip... Slip under full power 170rwkw? 250rwkw 300rwkw? or driving off boost?
Sounds silly but I have forgot to do it once as it was being a bastard to align up.
I use and recommend
Profile CardPM
+Quote Post
Gtrgodzilla67
post 20 Jul 2008, 04:36 PM
Post #4
Car(s): r32 gtr
Real Name: Pete
Trader Rating : 1
QUOTE(iwantagtr @ 20 Jul 2008, 08:41 AM) *
Thanks in advance
Sounds like the thrust bearing isnt going all the way back on disengage, or to much power.
did you check to make sure the new thrust bearing wasnt longer than the old? did it slide easly over the gearbox snorkel ? did you grease it ?
QUOTE(NYTSKY @ 20 Jul 2008, 11:13 AM) *
Try this one , Put a longer Rod in your slave cylinder and see what happens as some heavyduty clutches only have a small take up point. i have had to do this in the past.
Is the flywheel stepped ? or flat? did you get it machined ?
Profile CardPM
+Quote Post
tonga
post 20 Jul 2008, 05:57 PM
Post #5
Car(s): r33 97
Real Name: daz
Trader Rating : 0
had the same problem with mine, got the actuall clutch pedal adjusted, problem fixed.
Profile CardPM
+Quote Post
iwantagtr
post 21 Jul 2008, 08:19 PM
Post #6
IWANTAGTR
Trader Rating : 0
QUOTE(Gtrgodzilla67 @ 20 Jul 2008, 04:06 PM) *
Hi the thrust bearing looked exactly the same as the old one. The car is stock as a rock and it is a standard clutch, I put molybond on the input shaft but b4 i did that i cleaned it. I am glad you said to lengthen the slave cyl rod because that is what I am going to do tomorrow. The flywheel has been machined and there is no step in it.
Thanks for the advice.
Profile CardPM
+Quote Post
iwantagtr
post 21 Jul 2008, 08:22 PM
Post #7
IWANTAGTR
Trader Rating : 0
QUOTE(Cubes @ 20 Jul 2008, 12:35 PM) *
Hi,
I torqued the flywheel to the correct settings and it slips as soon as you put load on the engine
Thanks
Profile CardPM
+Quote Post
iwantagtr
post 21 Jul 2008, 08:28 PM
Post #8
IWANTAGTR
Trader Rating : 0
QUOTE(NYTSKY @ 20 Jul 2008, 10:43 AM) *
G'day mate,
have you tried taking the slave cyl off and taking the car for a drive this should illiminate the fact that it is an internal fault? (so no clutch at all you will have to start the car in gear without a clutch) If you are having problems with your clutch not disengaging why don't you try and shorten the rod. I hope I don't have to pull my box out again that is the worst box I have had to do so far.
Profile CardPM
+Quote Post
Gtrgodzilla67
post 22 Jul 2008, 06:37 PM
Post #9
Car(s): r32 gtr
Real Name: Pete
Trader Rating : 1
if u read correctly longer rod for not disengauging lol . (nytsky problem )
Profile CardPM
+Quote Post
iwantagtr
post 22 Jul 2008, 10:41 PM
Post #10
IWANTAGTR
Trader Rating : 0
[quote name='iwantagtr' date='21 Jul 2008, 07:58 PM' post='4027532']
G'day mate,
[/quote
Hi,
After replacing the slave cyl push rod with a longer one the clutch still slipped. I am pulling the box out on thursday.
Profile CardPM
+Quote Post
NYTSKY
post 23 Jul 2008, 03:02 PM
Post #11
GET TO THE WIN!
Group Icon
Group Icon
Real Name: Dave
Trader Rating : 25
Yes the flywheel was machined, im going to try and adjust the Main cylinder again this morning to see if i can get anymore free play out of it.
(Clutch fixed)
Profile CardPM
+Quote Post
BezerkR32
post 23 Jul 2008, 10:04 PM
Post #12
Car(s): R32 GTST
Real Name: Stuart
Trader Rating : 3
did you clean the protective coating off the pressure plate?
QUOTE(NYTSKY @ 23 Jul 2008, 03:02 PM) *
(Clutch fixed)
If you can turn you're going too slow!
Profile CardPM
+Quote Post
iwantagtr
post 25 Jul 2008, 02:00 PM
Post #13
IWANTAGTR
Trader Rating : 0
Hi,
Yes I cleaned the flywheel b4 I installed it. I pulled the gearbox out yesterday and found my problem. When i was installing the box I must of bumped the throw out fork . This moved the thrust bearing causing it to ride on the pressure plate springs making it slip.
thanks to everyone who helped.
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 13th October, 2008 - 12:29 PM
