18 Jul 2008, 06:27 PM
![]() The Fuel Hungry Blue Thing ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,572 Joined: 15th August, 2006 From: Canberra Car(s): R32 4dr GTS4 Real Name: Chris Trader Rating : 3 |
Ok had a search cant find anything specific, How can I tell if my universal joint is worn?
19 Jul 2008, 11:37 AM
![]() strange how i falter ![]() ![]() ![]() ![]() ![]() Posts: 616 Joined: 7th January, 2005 From: yangebup , perth Car(s): r32 gts4 rb26dett Trader Rating : 2 |
wiggle the shaft back and forward and see if there is any slop.
22 Jul 2008, 09:31 PM
that's racing! ![]() ![]() ![]() ![]() Posts: 18,561 Joined: 10th May, 2002 From: Sydney Car(s): bnr32,z33,wgnc34,ungd21 Trader Rating : 18 |
easy to tell if the uni is worn.
open the drivers door, sit in the seat, crane your head down and to the right. If the odometer reads over about 100,000klm the tailshaft uni is worn or you could try moving it back and forward like CeJay suggested but that sounds harder. You will also feel it through the drivetrain when you get on and off the power at low speeds as a clunk (although this could also be poorly adjusted diff centre, or worn gearbox mount. -------------------- |
Lo-Fi Version | Time is now: 6th September, 2008 - 12:52 PM |
