18 Jul 2008, 08:07 AM
![]() RB25DET ![]() ![]() ![]() ![]() Posts: 425 Joined: 17th March, 2007 From: Redlands Car(s): R33 GTST Real Name: Chris Trader Rating : 13 |
Emanage Ultimate (was only used for about 3 months)
+ universal harness + map sensor & map sensor harness (brand new) + AFR input harness cost me $1050 sell for $700 also have innovative LM-1 wideband + RPM converter (was only used for about 3 months) cost $500 sell $400 or buy both for $1000, everything you need to tune your car yourself Brisbane |
18 Jul 2008, 09:40 AM
some pictures, why can't I edit my first post??
also have a mdf parcel shelf for 6x9's fits in the back really well $30 also have gizzmo boost controller, I accidently broke the wires off on the solenoid coil, but I found a place that will sell me a new one for $35 + gst so will sell for $200 and you get new solenoid or $250 and ill get the solenoid. |
21 Jul 2008, 05:32 PM
I have a Power FC as well $1200, I've had this for less than 12 months and actually used it for only about 4 months, hand controller is in as new condition.
As a note I had this in my car but it stopped working after I installed new injectors, so it was sent to Japan for repair under warranty however it was tested by apexi and they found it working 100% and said problem was with the car. |
23 Jul 2008, 12:01 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 803 Joined: 18th March, 2007 From: Sunny Coast Car(s): Skyline R33 Trader Rating : 4 |
interested in pfc, if installed and doesnt work will u take refund?
23 Jul 2008, 06:39 PM
if your on sunny coast you can come and plug it into your car first if you like, I've been assured its working 100 percent
23 Jul 2008, 09:47 PM
but yeah if it doesn't work ill definitely refund.
this no editing posts sucks balls. also since i didn't add its for ecr33 |
27 Jul 2008, 03:06 PM
#7
Rank: RB20E ![]() Posts: 3 Joined: 23rd April, 2007 From: brisbane Car(s): r32 skyline Real Name: andrew williams Trader Rating : 0 |
how did the e-manage go on your car?
like did it run well and stuff |
27 Jul 2008, 03:07 PM
#8
like did it run well and stuff and did you need the map sensor & map sensor harness and AFR input harness to install and run it ? |
27 Jul 2008, 04:21 PM
#9
I had highflow turbo and s15 injectors and it ran really well never had it dynoed but was probably making about 300hp atw, it took a lot of time playing around with the laptop to get it right though since I tuned it myself on the road. I wasn't using the map sensor at the time but was just about to (before I got t-boned) stock afm maxes out really early so it gives you crappy resolution for tuning. For the price its a sweet computer but a lot of stuffing around with the initial setup compared to say a pfc which is virtually plug and play
6 Aug 2008, 05:35 PM
#10
wideband and emanage sold pending payment
20 Aug 2008, 04:51 PM
#11
wideband and emanage now sold
26 Aug 2008, 06:00 AM
#12
pfc has now been tested in a car and is working 100%
23 Sep 2008, 09:23 PM
#13
pfc sold
Lo-Fi Version | Time is now: 21st November, 2008 - 07:41 PM |
