IPB
2 Pages V   1 2 >
> Rb25/30 How Long Will It Last?
Tony1981
post 3 Jul 2008, 11:27 PM
Post #1
Rank: RB20DE
Car(s): 1
Real Name: Tony
Trader Rating : 0
Hey guys,
Was looking for some real first hand experience :-),
I am in the middle of putting together an RB30 N/A engine and R33 RB25 head, but was curious about how long this thing will last,
I have quite a few RB30 blocks lying about the place, but I also have a very decent complete RB30 engine, 155 across all cylinders, about 190,000km's on its clock and one complete RB25DE from an R33,
What I was thinking of doing is basically slapping on the RB25 head without touching the RB30 bottom end, I figure this should give me a reasonably boost friendly compression ratio of somewhere between 8.2 to 8.5:1 - looks like the head has been off at some point and replaced, so maybe someone decked the block, dont know,
I was going to run standard Nissan head gasket, standard nissan RB25 head studs,
From what I have gathered the only difference between the RB30E and RB30ET pistons is one is dished, but both are made out of the same stuff, so as long as I am not chasing big big HP, my stock RB30 N/A bottom end should hold together???
Just interested to find out if other people have gone down this route and had success, I remember speaking to the fellows at RIPS a few years back and they said they did something pretty similar, re-freshed the bottom end, used 2nd hand RB30 N/A pistons, slapped an RB25 head onto it, and put 600hp through the engine and 5yrs later it was still going strong,
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
daisu
post 4 Jul 2008, 03:22 AM
Post #2
Car(s): Cefiro
Real Name: Luke
Trader Rating : 2
I can't say specifically where I saw it, but I'm pretty sure it was in the 300 and something pages long thread (R33 RB30 conversions) where someone talked of installing an R32 RB25DE head onto an untouched RB30 bottom end.
From what I've read through this forum and others, the standard RB30 bottom end is quite reliable, providing it is in good condition. 155psi across all 6 cylinders sounds good to me, what are the factory specs for a standard RB30E?
Reliability is a bit of a fuzzy area due to the many variables that affect it, boost pressures, compressor efficiency, tuning etc.
If you do a bit more reading in the forum here you will find some first hand accounts of setups similar to this.
Personally, I have no previous experience, I'm only at the stage of collecting parts.
Do some more research and figure out what other people have done regarding factory bottom ends, and you will see what kind of power outputs they are achieving.
Profile CardPM
+Quote Post
Sydneykid
post 4 Jul 2008, 07:19 AM
Post #3
RB31DET
Group Icon
Trader Rating : 49
Cost $1200 (RB30+RB25DE) to build 9 years ago, 80,000 k's and still going strong at 475 bhp (engine dyno). Simple rules, ZERO knock, maximum 1 bar of boost, no leaner than 11.5 A/F ratios when on boost, no more than 6,750 rpm, service it regularly and use good oil (Castrol Edge 10W60).
Gary
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
VB-
post 4 Jul 2008, 08:29 PM
Post #4
Car(s): VL N/A 5 speed
Trader Rating : 0
what valve springs are you using just out of curiosity?
Profile CardPM
+Quote Post
CEF11E
post 4 Jul 2008, 08:54 PM
Post #5
my mum says chocolate isn't good for dogs...
Group Icon
Car(s): RB30DET powered R32
Real Name: Nic
Trader Rating : 24
I have built the same thing.
I used a stock rb30e out of an R31 that was rebuilt 35000 k's ago.
I just cleaned it and the top of the pistons and replaced all the gaskets and bolted on an untouched rb25de vct head. its running on all stock internal parts and makes 270rwkw and 650nm of torque. and it runs like a factory engine and has no signs of stress at all.
It has been daily driven for nearly a year and has clocked up over 20,000 k's
QUOTE
I will think of something later...
Profile CardPM
+Quote Post
xsv_32
post 5 Jul 2008, 05:45 PM
Post #6
Rank: RB20DET
Car(s): R32 Coupe, RB31/25det
Real Name: James
Trader Rating : 0
Yeah im building a 30det for my skida but ive used a fully forged internal setup with race bearings and arp bolts. Been told that thirtys are great for reliable torque and power all day every day if you keep them looked after. Have fun with your build. smile.gif
Profile CardPM
+Quote Post
Sydneykid
post 9 Jul 2008, 01:08 PM
Post #7
RB31DET
Group Icon
Trader Rating : 49
QUOTE(VB- @ 4 Jul 2008, 08:29 PM) *
Standard RB26 valve springs shimmed up for seat pressure to suite the cams. Performance Springs for mild cams up to 264 degrees and 10 mm lift, then Jun valve springs for more aggressive cams.
Gary
Profile CardPM
+Quote Post
Tony1981
post 12 Jul 2008, 09:19 PM
Post #8
Rank: RB20DE
Car(s): 1
Real Name: Tony
Trader Rating : 0
Thats for the stories guys, certainly put my mind at ease!!!
Have a few questions for you guys,
What is this engine like to live with everyday by just slapping the RB25DE head onto the RB30E engine?
Is it a pig off-boost?
Also, what turbo's are you guys running with the RB25 head slapped onto a stock RB30E N/A engine?
Guess this sorta relates to the "off-boost" question - but you use a stock RB25 turbo might come on boost at 2000rpm and "off-boost" wont really exist :-),
Just had a pretty ordinary experience in the past with slapping an EBAY T3/T4 turbo on the side of an RB30 n/a engine, did the right things, R32 GTR Injectors, re-chipped ECU, but the end result was just ordinary, doey as down low, didnt come on full-boost (14psi) until about 4200rpm, just want to avoid the same sorts of pitfalls - because they are expensive :-)!!!
Profile CardPM
+Quote Post
VB-
post 13 Jul 2008, 09:51 AM
Post #9
Trader Rating : 0
your past experience is because of the turbo, a better turbo would spool much earlier and give better results.
Profile CardPM
+Quote Post
Tony1981
post 14 Jul 2008, 11:05 AM
Post #10
Rank: RB20DE
Car(s): 1
Real Name: Tony
Trader Rating : 0
Yeah I was thinking of using a stock R33 RB25 turbo or the turbo from the VG30DET, I wont be chasing big HP, more daily drive-ability!!!
Profile CardPM
+Quote Post
bubba
post 14 Jul 2008, 11:43 AM
Post #11
"Deploying smoke screen"
Group Icon
Car(s): R32 GTSt w/RB30
Trader Rating : 2
I have an RB25 turbo on my 25DE/30 (not a standard bottom end though). It makes 12psi by 2200rpm, 183rwkw @4600rpm but chokes the engine up at about 5800rpm so badly that by the time it gets to the 6800rpm limiter it's only making 67rwkw!
It is certainly a lot of fun to drive and there isn't really such a thing as off boost. I do have a real turbo that is going on soon which should be even more fun biggrin.gif
Profile CardPM
+Quote Post
Guilt-Toy
post 14 Jul 2008, 02:00 PM
Post #12
My drinking team has a racing problem.
Group Icon
Car(s): R33 GTST
Real Name: Boost Junkie
Trader Rating : 16
my stock 30 bottom end lasted 60,000km's (but was rebuilt with new rings and bearings) and i flogged the crap outta it. I pinged the shit outta it as well (learning how to tune smile.gif and it lasted the time, the only thing that went wrong was it spun a bearing after using Nulon oil (never again)
Also most the rings were broken but it was still making some decent power. it was 265rwkw.. was in the car about 3 years (major blow by)
give it a go.. who cares if it blows up
OWNER TUNED - 11.3 second quarter @ 130.09 MPH with 374rwkw.
QUOTE(guricha @ 25 Jul 2008, 04:39 PM) *
thanks again to Anthony :))) am going to stick your picture on my rides hood:))
"There are only a few who can have high horse power and good emissions and you are one of them"
Guilt-Toy now testing E85.
Emissions Tuning my Skyline
Guilt Toy Runs a 11.3 @ 130MPH !!!
Remote Controll Power FC tuning thread
RB25DET MOTOR, $1,100 *CHEAP*
Myspace
Power FC tunes for $150 PM Me.
Profile CardPM
+Quote Post
TiTAN
post 14 Jul 2008, 02:11 PM
Post #13
Rank: RB30E
Car(s): S1 R33 GTST
Trader Rating : 6
If it blows up you just spend the the money you would have spent rebuilding it in the first place. If it doesn't thats a massive saving right there. Depends on how much power you want to make.
Profile CardPM
+Quote Post
Tony1981
post 14 Jul 2008, 10:11 PM
Post #14
Rank: RB20DE
Car(s): 1
Real Name: Tony
Trader Rating : 0
Its all in a 260z, so power actually is an issue - half shafts (good old UNIs) and stub axles (27 spline) are supposed to be quite the weak point and unless I cut out the original gearbox mounts all I can run is the skinny RB30E or RB20DET gearbox,
So realistically, unless I make some improvemets in the driveline I will be limited with what power levels I can chase - Think going for much more than 175-200rwkw would be pushing my little Datto to its limits!!!
Which I guess means I am in luck, that kinda power looks like its easily achievable with running 8-12psi, and well below 5500rpm - that should allow for the RB30/25 engine lasting forever!!!
"I have an RB25 turbo on my 25DE/30 (not a standard bottom end though). It makes 12psi by 2200rpm, 183rwkw @4600rpm but chokes the engine up at about 5800rpm so badly that by the time it gets to the 6800rpm limiter it's only making 67rwkw!"
I am probably safer with it spooling up a bit lazier than that, because quick snapping force is going to break things - just dont want it as lazy as it was before with the EBAY T3/T4 thing,
I wont be chasing big HP in this car, because even if I do fit an R230, get custom half-shafts with a set of 35 (maybe even 41) spline stub axles - how the f#ck will the car lay that kind of power :-)!!! Rwd with (if I am lucky) 235's on the rear, probably just sitting there spinning the rear wheels until the tyres burst :-)
Profile CardPM
+Quote Post
TiTAN
post 14 Jul 2008, 10:18 PM
Post #15
Rank: RB30E
Car(s): S1 R33 GTST
Trader Rating : 6
Ask cubes what happened to his RB20 box. there is just too much torque from the 30 for the little 20 box to be reliable.
Profile CardPM
+Quote Post
bubba
post 15 Jul 2008, 10:33 AM
Post #16
Group Icon
Trader Rating : 2
The power delivery of my motor is very linear because there is no lag so there's not really a quick snapping force (unless you dial in 4000rpm and drop the clutch.. then it's a quick snap into massive wheelspin.. hell even 2500rpm clutch drops result in massive wheelspin!).
To be honest mate, if you can't fit a 25 box in there I wouldn't be putting a 3L in.. those RB20 boxes really don't handle all the extra torque. Mine lasted less than 2 months of 3L goodness confused.gif
