IPB
2 Pages V   1 2 >
> Cam Shaft Choice For Rb30/26
PALADN
post 30 Jun 2008, 05:33 PM
Post #1
PALADN
Car(s): R32 gts-t
Real Name: Callum
Trader Rating : 0
Hey guys here are the engine specs
Arias rb30/26 conversion pistons
PAR conrods
All ARP bolts (head/mains/rods/exhaust manafold)
High energy 8.5lt oil sump
Jun oilpump
RB26 head Ported
Garret GT3582R turbo
870cc injectors
I am now about to make a choice on cams for it. I would like some advice from anyone else that has done it. Please let me know.
Im chasing a little more power but the car is used for drift so its not a drag car.
IPB Image
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
PALADN
post 3 Jul 2008, 02:57 PM
Post #2
PALADN
Car(s): R32 gts-t
Real Name: Callum
Trader Rating : 0
anyone help on this? lol
IPB Image
Profile CardPM
+Quote Post
NYTSKY
post 4 Jul 2008, 08:59 PM
Post #3
GET TO THE WIN!
Group Icon
Group Icon
Car(s): R33 S2,98 Proton
Real Name: Dave
Trader Rating : 24
Poncams will be enough,but if you want bigger you will need upgraded valve springs.
MY ENGINE BUILD THREAD!!!!
RB26 & RB25 CP,EAGLE,TOMEI,ARP ENGINE REBUILD KITS UNDER 3K DELIVERED!!!!!!! <------CLICK
HID KITS $120 DELIVERED!!! PM ME TO PLACE YOUR ORDER!!!
FEDERAL TYRE GROUP BUY NOW ON!!! PM ME FOR DETAILS!!!!
Profile CardPM
+Quote Post
2BNVS
post 5 Jul 2008, 10:39 AM
Post #4
RB26/30 T04Z
Car(s): R33 GTSt & MB ML430
Real Name: Ben
Trader Rating : 15
id just go with poncams, but if u wanted more go JUNs, i run 272 9.7 with jun springs
R33 gts-t
new dyno soon with rebuilt RB26/30 T04Z!!!!
Southern Motor Works- 42566429 (motor, driveline, suspension)
NixCars Wollongong
JD Performance
Trimside (gold coast)
Leigh@Extreme Turbo Manifolds
Tempe Tyres
Nengun
WepnX Installs (stereo)
Jetspeed
Tony's Prestige Smash- 42291094 (spray)
PJ's Performance (chroming)
"R.I.P zsmoov"
Profile CardPM
+Quote Post
Sydneykid
post 9 Jul 2008, 01:50 PM
Post #5
RB31DET
Group Icon
Trader Rating : 49
The answer on duration depends on what RPM range you are targetting, be realistic. If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go. For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go. That's a simplification, but you get the idea. As for lift, once I know the effective rpm range, I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift.
Gary
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
Cubes
post 18 Jul 2008, 08:32 PM
Post #6
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
Drift...
As much lift as possible. 10-11mm lift and 265-272duration depending. 380-390rwkw without too much trouble with the .82.
Lift is the key. Duration simply drops the peak power roughly where you want it.
I use and recommend
Profile CardPM
+Quote Post
Z24O
post 24 Jul 2008, 05:58 PM
Post #7
Trader Rating : 7
just out of interest what are the std RB26 cam specs and rev range response?
Profile CardPM
+Quote Post
Cubes
post 24 Jul 2008, 06:05 PM
Post #8
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
I've just came off the dyno with mine.. RB25 hydraulic head though.
Tighe cam regrinds 265in 263exh 9mm lift 221deg at 0.050".
200rwkw at 3500rpm and 256rwkw at 4000rpm @ 19psi boost then tails off quickly to 17psi where it makes 302rwkw at 6000rpm.
The cams have lost absolutely nothing down low its picked up power everywhere with its std centrelines inlet 110 LCA, Exhaust 115 LCA 112.5 LSA which = around 4-5degree's overlap.
Have yet to play with adj cam gears.
We had a few issues pushing more boost in.. It simply would not boost any more than 17psi over 5000rpm. Suspected a combination of the 1bar crappy Garrett actuator + 2" FMIC piping with a small 450x300 fmic.
RB26 cams from memory are around 236 duration with ~8.5mm lift.
I use and recommend
Profile CardPM
+Quote Post
TiTAN
post 25 Jul 2008, 01:55 PM
Post #9
Rank: RB30E
Car(s): S1 R33 GTST
Trader Rating : 6
Cubes, How much do the regrinds normally go for?
Profile CardPM
+Quote Post
bubba
post 25 Jul 2008, 03:01 PM
Post #10
"Deploying smoke screen"
Group Icon
Car(s): R32 GTSt w/RB30
Trader Rating : 2
Cubes, what cams were you running before the regrind?
Profile CardPM
+Quote Post
Cubes
post 25 Jul 2008, 04:00 PM
Post #11
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
standard r32 rb25de (240 7.8mm inlet - 232 7.3mm exhaust)
regrinds these days are $380.
I use and recommend
Profile CardPM
+Quote Post
TiTAN
post 25 Jul 2008, 05:14 PM
Post #12
Rank: RB30E
Car(s): S1 R33 GTST
Trader Rating : 6
noticeable in the idle?
Profile CardPM
+Quote Post
Cubes
post 25 Jul 2008, 05:45 PM
Post #13
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
As its only running 4-5degree's overlap the idle is smooth. Its deeper and overall the exhaust is deeper and more throbby sounding.
Definitely doesn't sound like a regular rb20 or 25det.
Push in 5degree's advance to the inlet and it will lope like buggery. tongue.gif
I am running 20degree's static ignition which helps smooth idle when running bigger cams.
Generally richer afr's + more ignition timing will smooth an idle.
Leaner afr's and less ignition timing and it will lope.
But with mine.. ~5degree's overlap regardless if its running retarded or lean afr's it still idles smooth.
I use and recommend
Profile CardPM
+Quote Post
discopotato03
post 25 Jul 2008, 06:38 PM
Post #14
Rank: RB30E
Trader Rating : 3
Hi Cubes , I asked in another thread about your cams but you may come here first .
From memory you used an R32 RB25DE hydraulic head so are the LCA's native to that engines cams or all RB25 cams ie 33 25DET cams ?
Very interested in these grinds - if they'll work in a 33 25DET engine .
Cheers A .
Profile CardPM
+Quote Post
Cubes
post 27 Jul 2008, 10:46 AM
Post #15
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
The r33 rb25det lca's are different due to vct.
I use and recommend
Profile CardPM
+Quote Post
SirRacer
post 27 Jul 2008, 02:32 PM
Post #16
Car(s): rb30det laufiro
Trader Rating : 0
What are the pro's and cons of a regrind compared to a whole new billet cam?
What was the max size wise you could also go Cubes? Have been pondering a regrind of the cams i have in my engine.
Profile CardPM
+Quote Post
drgnball34
