14 Jun 2008, 09:54 AM
![]() Niki Lauder and Chopper Reed's Lovechild Cat ![]() Posts: 253 Joined: 11th January, 2008 From: Melbourne Car(s): R32 GTR Golf GTI Real Name: Nick Trader Rating : 4 |
I've got an R32 gtr running about 300RWKW and currently have a standard brake set up which is not really up to the job. I've got R33 GTR rims to go on the car (forged, light, sort of original, look good, as big as you want to go to preserve the original style of the car - sorry I'm old). The car is predominantly used on the street, but for Sunday blasts or a quick drive to work when I'm in the mood. Track work will be minimal.
Ultimate stopping performance is obviously important, but peddle feel and streetability are important too. I don't want to be able to tear the skin off my face pulling up at the expense of a good feel. I want to avoid squealing brakes too. I know this comes down to pad choice but thought I'd throw that in. Where to from here? What does the collective wisdom suggest? Thanks, Nick. |
14 Jun 2008, 10:16 AM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 348 Joined: 21st January, 2007 Car(s): gtr Trader Rating : 8 |
how much do you want to spend, some good fluid, pads rotor and caliper prep on the standard gtr will work btter than you expect but if you have $3000-$6000 for a set of AP/brembo/alcon etc etc etc which are excellent but another ball park as in terms of feel and performance
as you said only street driven most of the time, if i were you work on what you have eg bigger rotor, pads, fluids, seals as the price of the bigger units wont offset the street performance. having said that how nice is it having ap/brembo alcon under the wheels. just my two cents. |
14 Jun 2008, 10:59 AM
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 992 Joined: 25th May, 2005 Car(s): R32 GTR Proton GTi Trader Rating : 2 |
You dont need alcons or any other big brake kit like that to pull up a street GTR. (Or mild circuit car for that matter)
Buy a decent set of slotted rotors from the RDA group buys, use a reasonable set of pads, Id recommend TRW Lucas pads but have a read of the brake pad guide at the top and make an informed decission. Buy/have made a set of braided lines or if the budget does not stretch that far buy original rubber lines which there is nothing wrong with providing they are in good condition and not 20years old. Use a decent Dot4 fluid and flush it through well. If you wanted you could replace/overhaul the master cylinder but if it works fine then id be inclind to leave it. We have a 32 GTR with decent grunt that is doing plenty of mild track work with the exact set-up mentioned above and its never had a problem stopping time and time again. -------------------- |
14 Jun 2008, 11:30 AM
![]() Rank: RB26DE ![]() Posts: 14,128 Joined: 27th June, 2002 Trader Rating : 6 |
Grab some used R33 Brembos, nice quality rotors and some punchy pads. Fingers crossed you can sell your current gear to a Silvia owner, but you will still be looking at around 3k total
So would suggest you grab some NISMO brake ducts or similar which bolt to the castor rods, some good fluid, pads and tyres. If you are stressing that sort of brake setup then you probably shoudl be slowing down because of brake fade Try some Castrol SRF brake fluid, i am loving the Endless CCX pads i run and just do a walk around the cars current brakes. Check caliper pistons move freely and rotor condition. Binding pistons cause pad drag on the rotor which all throws heat into the brakes If you find your calipers are in need of a strip and rebuild, the rotors are shagged, then its time you look at the dollars you have to spend because you may be able to justify a slightly bigger spend for a nice 4 pot upgrade using an AP, Alcon or Brembo caliper with a 332mm rotor. So what is the budget? I love spending peoples money on brakes -------------------- Minister of RB20 propaganda RB30s are for folk who prefer roofies to romance FOR SALE : RB20 HKS CAMS, Complete R32 RB25DE, Cast Low Mount HKS Manifold and Gate + more Growing old is mandatory; growing up is optional. |
14 Jun 2008, 01:56 PM
![]() Fuel in here...Flames out there ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,912 Joined: 2nd November, 2005 From: The dark continent...again Car(s): R32 GT-R Trader Rating : 6 |
Nick, I've been in the same boat and while I save for some bigger brakes I've made the following changes which really help last time out at AHG.
Master cylinder stopper-I bought a Nismo brace with one integrated but you can fashion your own or Cusco make a bolt on one. Stops firewall flex Braided lines-GB deal worked out really well at a good price Pads- I tried some Hawk HP+...More rotor wear and noise but the R stopped really well. Probably too aggressive for the street. Fresh brake fluid -------------------- ![]() |
14 Jun 2008, 01:58 PM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 120 Joined: 3rd August, 2007 Car(s): r32gts4 evo3 Real Name: marcus Trader Rating : 0 |
buy some g4 brakes for it they are fairly cheap fpr what they are as well just jap sell them. they are a sweet looking brake disc as well can get different sizes of rotor and they work excellent
14 Jun 2008, 11:37 PM
#7
Rank: RB20DE ![]() ![]() Posts: 28 Joined: 27th June, 2004 From: croydon Trader Rating : 0 |
good brake fluid and pads will make a difference for a street car. I would stay away from rda's as i have had them crack and seen them crack on track cars but may be ok for the street.
15 Jun 2008, 11:33 AM
#8
Sorry if I'm not replying properly here, but thanks to all for your advice. Sounds like I might be best investigating some relatively low investmwent options on the current set up first. I guess brake lines and boosters etc can be carried over to new systems as and when required, so might be a good place to start. Then, caliper rebuilds / new rotors / pads etc needs to be balanced out against the cost of upgrading. You don't really want to spend twice. I guess this allows me not to make the outlay for the R33 GTR rims and tyres. I've got 2 sets of R32 with track tyres so might be best finishing them off before upgrading.
I have a feeling that I'll always be hankering after 'big' brake set up just because 'you can' and it's kinda cool. I guess I'll check out the $$$$ factor for what you get in terms of perofmance and the 'cool' factor. Thanks again to all. Nick. |
15 Jun 2008, 01:07 PM
#9
Some other thoughts, any comments advice on the following would be appreciated:
How brake upgrades integrate with the ABS system (does the 4wd system work off ABS too? Sensing wheels spin etc?) Cross drilled rotors. I hear a bit about them developing hairline cracks, but they look so cool + hi-end Euro sports cars generally have them so I guess they can be made to work? How do you establish if rotor / calipers fit certain rims? This forum? Brake bias issues. Any basic rules to observe to avoid errors Brake boosters and lines and the relationship they have with pedal feel Yours still in total ignorance...... |
16 Jun 2008, 11:17 AM
#10
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,471 Joined: 14th July, 2003 Trader Rating : 11 |
How brake upgrades integrate with the ABS system (does the 4wd system work off ABS too? Sensing wheels spin etc?) As long as the piston area of the new calipers is similar to those of your current set up the ABS will cope. The 4wd system doesn't care. Cross drilled rotors. I hear a bit about them developing hairline cracks, but they look so cool + hi-end Euro sports cars generally have them so I guess they can be made to work? If you use your car on the track (Properly) chances are you will crack the discs at some stage. Best bet is to select rotors to avoid this problem as much as possible. If you don't then there is no point spending large on brakes. How do you establish if rotor / calipers fit certain rims? This forum? Look for the thread on this very issue and get busy with the paper & scissors. Brake bias issues. Any basic rules to observe to avoid errors Ask questions of the vendor. Then you will get the usual blandishments that are completely meaningless. They all say they work beautifully but recommend all sorts of different rotor diameters & piston areas. Make of that what you will. Brake boosters and lines and the relationship they have with pedal feel The booster uses vacuum to reduce pedal effort. By lines I assume you mean braided hoses. These swell less when you brake hard than old rubber alternatives hence less pedal travel is wasted. |
16 Jun 2008, 11:55 AM
#11
![]() Team Trabant ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 5,438 Joined: 14th December, 2002 Car(s): broken Real Name: Chairman Kaga Trader Rating : 47 |
i recommend many hours of reading in this section of the forums.
you'll find out quickly which are your key knowledge members. -------------------- GTR - from the land of the rising credit card debt!
Successful traders: Maxx, BU5TER, DoughBoy, Roy, Croat, Dsturbd, Nismo32R, Boj01, TurboX, RowdyR32, JETR-32, ALL_GTR, rmahnovetsky, BATMBL, wrxkilla, CeffyNSW, meep, SydneyKid, nuR.spec, giant, Marko R1, Spoolup, cln, twisted, Tommyk, GTRgeoff, exXU1, Parker, femno, GTR090, rickhead, AlexCim, sullivan_a, CameronBNR32, gexenon, r33skyline, lang, nismo350z, tridentt150v, Scudboy, Cerbera, Hotwire, robbieraver, KLR32, jnr32r, NIZ-26T, tom_g, Simonster, MADGT4, darrrinspencer, sven, legend01 |
16 Jun 2008, 09:14 PM
#12
OK. Thank you all for your further advice. Having shopped this around a little I think given the likely usage a 'big' brake upgrade will not be what I'm after. I think I'll do some braided lines, sort the squeal out from the DS2500 pads I've got (if I can). Phase II could be Brembos from and R33 V spec. My thinking is that they should not represent a massive departure from std R32 and should therefore be relatively straightforward to retro fit, though I've read bolt pitch is 1.5, not 1.25.....I wonder what other hidden snags there may be.....
Can anyone adivse on the R33 Brembo logic. If it is the (a) right way to go, what size rotor would be required and can they be squeezed under stock R32 rims (I doubt it). I'd hope they are streetable. Further thoughts and comments? Thanks again. |
17 Jun 2008, 09:59 AM
#13
DS2500s...throw them to the shitter. Some like them, but the more i read of people running them and wanting a further drake upgrade hints to me that i am not alone in my thinking they are really a crap pad, no better then the cheaper RB74s etc etc.
For pedal feel, bite and retardation then a good pad will get you out of trouble 9 times out of 10. Used with good fluid like Castrol SRF or Motul RBF, and you will be happy with the improvement. From there i would hold off on braided lines, personally i didnt notice any real improvement going to them , which could have meant my std ones were ok in the first place, or i am not very astute at picking small improvements after mods. But main reason i would hold off on them is they wont be a factor that makes or brakes the tweaking of your current setup, and if you find the std brakes with pads and the std ducts etc installed still a little under done then the bigger calipers/rotors will need new lines anyway...so wont be fronting for two sets of lines As long as you buy the Brembo GTR calipers with the bolts its a pretty easy upgrade, you need to cut off the dust shields and that is about it. If you are anal you can re-drill the brake line mount so it fits the R32 hub position (5min job if you are not too lazy to go and grab the drill. ) As far as upgrades go it is an easy one, and about two hours per corner to perform. -------------------- Minister of RB20 propaganda RB30s are for folk who prefer roofies to romance FOR SALE : RB20 HKS CAMS, Complete R32 RB25DE, Cast Low Mount HKS Manifold and Gate + more Growing old is mandatory; growing up is optional. |
17 Jun 2008, 10:32 AM
#14
I agree with Roy on grabbing some Endless CCX pads - the ones he's using were in my car before I upgraded.
Note tht if you go to R33 Brembos (note all R33s have the same brakes, not just v-spec has brembos) you'll probably need to go to a 17" unless it's a big 16 like TEs or alike. -------------------- GTR - from the land of the rising credit card debt!
18 Jun 2008, 07:29 AM
#15
Thanks Ronin and Roy (and everyone). It's amazing how far out your first best guess can be. Think I might take my time with this. I'll try new pads and see how I go from there.
I have 2 sets of R32 GTR 16 x 8s, one set with track tyres and the other with road, both with a fair bit left. If a wheel upgrade is required (which I thought it would be) for the Brembos and the larger rotors I think I might sit tight with the current set up until the tyres run out of life. Q - with 17 x 9 R33 GTR rims or 17 x 9 V Spec R32 BBSs, what size rotor would be the max the rims and calipers could take. Any advice on where to buy rotors? OEM Nissan from RHD Japan? DBA? That being the case, my next question is how much do rotors make a difference to overall brake performance? I'm runing some unknown replacement disc for the original cross drilled numbers. Will investing in DBA 4000 / 5000 slotted rotors make a noticeable difference to pedal, bite, feel, heat disipation etc etc. Or is that potentially an expensive wast of time? Nick. |
