IPB
> Oil Restriction, some answers for those who are wondering
ahh 33 s2
post 6 Jun 2008, 10:33 PM
Post #1
Goal: 350hp and mid 12s
Group Icon
Car(s): Nissan skyline R33
Real Name: daniel
Trader Rating : 2
hey all i have just been researching oil restiction for this build. i have taken the following info from the major thread. info was provided by gary (sydney kid) and can be found on page 153. here it is again. hope this helps some ppl
RB26 cylinder head= 2 oil feed galleries between the block and the head
We block one off, same as RB26's are standard
We use a 1.5 mm restrictor in the other
Plenty of oil flow to the camshaft bearings, not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 with VVT= 2 oil feed galleries between the block and the head
Plus 1 feed to the VVT actuator
Plus leave the VVT oil feed as per standard
Plenty of oil flow to the camshaft bearings and VVT actuator but not too much oil slopping around in the head, getting chucked into the catch can and leaving the sump in short supply.
RB25 without VVT= 2 oil feed galleries between the block and the head
We use a 2.0 mm restrictor in the other
Plus block off the VVT oil feed
and a couple of diagrams
http://www.skylinesaustralia.com/forums/in...st&id=26521
http://www.skylinesaustralia.com/forums/in...st&id=26522
the only question i still have that i have not been able to find an answer to is,
does it matter which gallery you restrict and which you block off??
dan
having no licence sucks
having a skyline makes it all better
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Sydneykid
post 10 Jun 2008, 02:38 PM
Post #2
RB31DET
Group Icon
Trader Rating : 48
QUOTE(ahh 33 s2 @ 6 Jun 2008, 10:33 PM) *
dan
I thought I was quite specific when I posted "same as RB26's are standard" ie; the front one
Gary
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
ahh 33 s2
post 10 Jun 2008, 06:28 PM
Post #3
Group Icon
Real Name: daniel
Trader Rating : 2
sorry but am not to familiar with the rb26 nor any engine atm moment. so sorry to ask pretty much the same question again, so you restrict the front gallery?? yes?
Profile CardPM
+Quote Post
Cubes
post 1 Jul 2008, 12:03 AM
Post #4
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
QUOTE(ahh 33 s2 @ 6 Jun 2008, 10:03 PM) *
I ran with a single 1.5mm up front and blocked rear as suggested in the thread.
The setup seems ok and has travelled quite a few kms but from day one I was getting a little valve train noise for a fraction of a second following start up of which was not there prior.
If I were to do it again I'd probably go with leaving the std RB30 1.8mm restrictor up front.
All though I possibly believe the valve train noise was as a result of the head bloke not knowing what he was doing with the lifters as a result they trapped a little air inside.
So as they so do it right do it yourself. I've pulled the lifters apart; meticulously cleaned, primed and reassembled.
I use and recommend
Profile CardPM
+Quote Post
xsv_32
post 5 Jul 2008, 06:08 PM
Post #5
Rank: RB20DET
Car(s): R32 Coupe, RB31/25det
Real Name: James
Trader Rating : 0
Im using th 25de (vvt). Ive been told i have two main options, one is to block the rear gallery all together but was told it can starve one end of the head during start up. Which isnt much of a trouble as it disappears once oil pressure is up but id rather go with the other option to just restrict both galleries using the tomei restrictors. Anyone else gone 4 this option?
Profile CardPM
+Quote Post
Cubes
post 5 Jul 2008, 06:45 PM
Post #6
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
The VCT head has a total of 3 feeds.
How you restrict it depends on the oil pump your going to run.
I use and recommend
Profile CardPM
+Quote Post
Sydneykid
post 9 Jul 2008, 01:05 PM
Post #7
RB31DET
Group Icon
Trader Rating : 48
QUOTE(xsv_32 @ 5 Jul 2008, 06:08 PM) *
Block the middle and use the front feed (the VCT one) and then restrict the rear feed according to the table.
Gary
Profile CardPM
+Quote Post
Keeper
post 6 Aug 2008, 04:33 PM
Post #8
I'm a pilot, yes that does mean I'm always pissed
Car(s): R32 GTR
Real Name: David
Trader Rating : 0
where are the restrictors for sale???
The banks have some sort of evil conspiracy ATM does not stand for "Auto Matic Teller" machines, it stands for "Ass To Mouth", its what they do to you with fees every time you use the bloody machines.
Profile CardPM
+Quote Post
Craved
post 6 Aug 2008, 06:32 PM
Post #9
adj : wanted intensely
Group Icon
Group Icon
Car(s): R33GTST - ZX2R
Real Name: Chris
Trader Rating : 10
tomei have the restrictors - think hi-octane in SYD have them too
though others have made their own from solid rod and a drill.
WANTED TO BUY
RB26dett cam and cam gear covers also RB26 Valley Cover- PM me
Profile CardPM
+Quote Post
r33_racer
post 7 Aug 2008, 12:47 PM
Post #10
Incase you didnt notice, I just did over a thousand!
Car(s): R33 X 2, Yammy 05' R1
Real Name: Michael
Trader Rating : 1
I posted about this before ages ago....you can use copper mig tips...just find the size that has the correct hole diameter you want and machine it down or cut it down to suit. Pretty sure most std mig tips are around a 1/4" OD.....actually i cant recall now...maybe it was about 7mm or 5/16"...either way it works tongue.gif
*6BOOST MANIFOLDS*
STEAMPIPE EXHAUST MANIFOLDS TO SUIT ALL RB ENGINES
CALL KYLE :0410 730 598
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 6th September, 2008 - 12:56 PM
