26 Apr 2008, 11:12 AM
![]() Team Clublock ![]() ![]() ![]() ![]() ![]() Posts: 670 Joined: 23rd June, 2005 Car(s): JZX81 Drift Car & R34 4dr Real Name: Brenton Trader Rating : 2 |
Hey Guys.
I got rid of the 32 4dr and got a new toy. All you adelaide Boys/ Girls will be able to see this out at Mallala Rd 3 DA. And other Practice days/ comps. ![]() Below are the specs for the thing The car is a 1992 Toyota JZX81 MarkII "Yamaha Edition" (1 of 300) The motor and all accessories were built and assembled in house at HKS Kanto, Japan It has: 1JZGTE Motor (claimed 10,000kms since HKS build) HKS stainless exhaust manifold HKS 3037S turbo 480ps rated HKS 50mm External Waste gate HKS 264 degree Cams HKS 1.6mm head gasket Custom HKS Intake Pipe Custom HKS cooler kit HKS 3 core radiator HKS oil cooler kit with remote oil filter Custom HKS catch can HPI tourque dampener HKS 540cc injectors Tomei Fuel Pump 3 ˝” straight through exhaust to a custom HKS Muffler screamer pipe from external wastegate Custom HKS front pipe HKS thermostat Autronic SM4 Stand-alone ECU (3bar map sensor) running a custom wiring loom, mounted in the stock ECU position (out of sight) with a glove-box mounted data cable. LS1 Coilpacks custom mounted with 8.5mm leads Wheels: BBS mesh 17 x 9 +20 all round R154 5 Speed Manual Gearbox OS-Giken Twin-Plate Clutch TRD 2-Way LSD Rear subframe modifications (extra weld bracing + mounted closer to chassis to maintain suspension geometry) Kei Office Coilovers (custom specs) "Tezuka Model" - Front-10kg Rear-8kg LARGUS sway bars front & rear (extremely thick) with pillow ball links Strengthening rear Tie Rod's R32 GTR Brakes (front: 4 spot alloy callipers) HKS braided brake lines HKS braided clutch lines Strengthenned front Stub Axle links Strengthenned front toe arms Modified steering knuckles (for stupid amounts of steering lock) New Wheel bearings all round All bushes replaced recently Free Dom Boot brace Free Dom Floor brace (monkey brace) Free Dom Rear Pillar brace Tanabe Sustec Front Strut brace Chassis Seam welding Dart Izumi “Destructive King” front bar Free Dom side-skirts Hippo Sleek rear bar Original "Yamaha Edition" rear lip/boot spoiler Front & rear wheel arches all custom hand flared ~20mm Free Dom single layer Carbon Fibre vented Bonnet Clear indicators w/ blue side lamps Dark tint rear passenger windows and rear windscreen. Nardi Steering Wheel Grex gear knob Blitz Boost Guage Greddy Gauges: Water Temp, Oil Temp, Oil Pressure, Exhaust Temp Blitz Electronic Boost Controller – Dual SBC-R Bride Brix Drivers Seat Bride “Super-low” drivers sliding seat rail some double din CD player About the car: The car is a special model of the JZX81 called the "MarkII Yamaha Special" one of only 300 produced from toyota. It was used as a daily driver/slider by an associate of none other than D1 driver Tsuyoshi Tezuka, who's shop Kids Heart tuned the suspension set up for drift. It has also had a small feature in a Japanese drift magazine. The Autronic has been setup with a very safe tune by a very experienced local Adelaide based tuner (before turbo rebuild/upgrade). Running BP Ultimate, the car makes 280rwkw on only 16psi (limiter set to 7500rpm) with excellent turbo response, making the 16psi @ ~3600rpm, and making 200rwkw by 4000rpm. This was on the old turbo, the rebuilt set up seems even more responsive again, making full boost at around 3000 rpm. -------------------- |
26 Apr 2008, 11:58 AM
![]() Under construction ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,856 Joined: 15th August, 2006 From: Canberra Car(s): R32 4dr GTS4 Real Name: Chris Trader Rating : 4 |
looks good, wouldn't want to tell us how much she cost?
26 Apr 2008, 12:07 PM
swapped the 32 for it. plus some cash to the previous owner.
will not disclose payment though. LOL. Great deal is all im saying -------------------- |
26 Apr 2008, 12:28 PM
thought so
26 Apr 2008, 08:54 PM
![]() CB5W, CM11V, RS13, A73 ![]() ![]() ![]() ![]() Posts: 143 Joined: 14th June, 2004 From: Adelaide Hills Car(s): 3x Lancer, Alto, S13 Real Name: Tony Trader Rating : 0 |
a good deal indeed
-------------------- '92 CC Lancer Wagon | '89 Suzuki Alto Works RS/R | '74 LA Lancer 2Dr Coupe | '92 S13 RB20DET
SKYLINE CHASSIS PLATE DECODING |
27 Apr 2008, 06:39 PM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,024 Joined: 13th November, 2005 Trader Rating : 3 |
Cejay this car was imported by Iron chef imports and has since been owned by 3 ppl, all with the intent to slide it but its only been on the track once
i look forward to seeing if brenton can A) see over the steeringwheel/dash and B) drive it to its full potential.... -------------------- My 280 rwkw RB25 R32 4 door for sale HERE
![]() * GCG * Jeff - The Speed Lab - 0434 637 357 * Adelaide Jap * All Type Crash * |
27 Apr 2008, 10:40 PM
#7
![]() Rank: Alcoholic ![]() ![]() ![]() ![]() Posts: 499 Joined: 17th April, 2008 From: Adelaide Hills Car(s): 32 4dr/Lancer Real Name: Andrew Trader Rating : 0 |
Cejay this car was imported by Iron chef imports and has since been owned by 3 ppl, all with the intent to slide it but its only been on the track once i look forward to seeing if brenton can A) see over the steeringwheel/dash I hope you have fun with it mate, I'm having fun with your 32 -------------------- |
1 May 2008, 02:20 AM
#8
Rank: RB20DET ![]() ![]() ![]() Posts: 50 Joined: 5th December, 2005 Car(s): a31, ae86, patrol Real Name: Rhett Trader Rating : 0 |
I love your car dude. I am also looking to start another project with that as a base.
22 May 2008, 09:22 PM
#9
Some recent pics from the All Japan Day in April.
![]() ![]() ![]() ![]() And also a few pics from todays private track day. Had a bloody ball in the car. Can't change a thing on it at all. But might need to get some chewy to hold the rear bar back together. ![]() ![]() ![]() Will have some footage of todays efforts up shortly. And will have some pics from Round 3 DA this weekend. Toodle pip boys and girls -------------------- |
23 May 2008, 12:11 AM
#10
Hippo Sleek rear bar - FUCKED
Good to see it made it out to the track finally, bet it was stpuid amounts of fun (bastard -------------------- |
26 May 2008, 07:31 PM
#11
hahahaha andrew you have no idea.
By the end of the day i was pretty much linking the track with no issues at all. Well except the problem with getting 7 laps out of 2 brnad new tyres -------------------- |
27 May 2008, 09:00 PM
#12
![]() Rank: RB20E ![]() Posts: 3 Joined: 27th May, 2008 From: ADL Real Name: J Trader Rating : 0 |
Im keen to see this thing slide. looks awesome, saw it for sale on ns.com and mouth dropped.
1 Jun 2008, 07:01 PM
#13
Rank: RB20DE ![]() ![]() Posts: 20 Joined: 30th June, 2007 From: victa Trader Rating : 0 |
Nice brenton!
She's a beauty. Nice swap! |
2 Jun 2008, 08:04 PM
#14
well HELLO TRISTO.
HAHAHAH hurry up and get back out on the track mate. Want to have some competition at my level. Oh and I will hopefully have footage of me up shortly. Just gotta wait to get it from the guy who was out at the private day the other week -------------------- |
2 Jun 2008, 10:24 PM
#15
when are non-elite people going to see this on the track not posing...
farken secret bullshit -------------------- '92 CC Lancer Wagon | '89 Suzuki Alto Works RS/R | '74 LA Lancer 2Dr Coupe | '92 S13 RB20DET
2 Jun 2008, 11:07 PM
#16
once I get the footage from Waza.
I thought he would of put some of it up in the Wheelworx battle Report. but im not from wheelworx so prob best he didnt -------------------- Thanks to: MORPOWA, CM BMX, |
