30 Mar 2008, 10:33 AM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 327 Joined: 20th September, 2005 Car(s): S15 RB26/31 Trader Rating : 1 |
i am currently doing this conversion and am using a r32 cross member and planning to use vl engine mounts??
will this be suitable and will the stock bonnet close with the motor in??? also i will be running a rb25 box and i have bashed the tunnel out so it fits, does anybody know if the shifter will come out the standard hole??? thanks for help.. denis |
30 Mar 2008, 03:03 PM
Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,317 Joined: 12th June, 2005 From: sydney Trader Rating : 19 |
There is no way the stock bonnet will close
-------------------- R32 gtr Rb30
Eagle rods, custom sump and plenum Arias Pistons, Toda 272 10.2mm cams Sard 720cc inj, MSD Cdi Ported head, HKS T45s, HKS 50mm w/g 100mm HKS intercooler 100mm throttle body 355mm AP discs 6 piston Porsche Brembos Nistune live mapping, hoping for 450AWKW |
30 Mar 2008, 07:28 PM
are you 100 % sure??
30 Mar 2008, 08:48 PM
No, but you have to lower a 25/26 to fit them, and the rb30 is 38mm taller
31 Mar 2008, 09:47 AM
![]() RIPS RB30DET ![]() ![]() ![]() ![]() ![]() Posts: 1,710 Joined: 1st May, 2006 From: Brisbane - Southside Car(s): R33 GTS30T Real Name: Dan Trader Rating : 2 |
the bonnet will close:
31 Mar 2008, 07:37 PM
^^^ lol thanks, i was thinking the same thing
1 Apr 2008, 06:10 PM
#7
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,399 Joined: 23rd March, 2006 From: Melbourne, S.E. suburbs Car(s): VL N/A 5 speed Trader Rating : 0 |
pfft... who needs a bonnet anyway. improved cooling lol
1 Apr 2008, 10:18 PM
#8
just been confirmed... it fits...
you must use rb25 engine brackets.. then you mate them up with rb30 engine mounts |
2 Apr 2008, 07:59 PM
#9
your kidding? its fits with standard, mounts n shit? sounds a bit odd..... its a very tall motor in a very short car....
3 Apr 2008, 08:28 AM
#10
your kidding? its fits with standard, mounts n shit? sounds a bit odd..... its a very tall motor in a very short car.... +1 My 33 surely has a taller engine bay and the RB30DET Just fits in i think the cam gear cover rubs the sound deadener The workshop whi finished off my car, had an S13 in there getting some work done it had a 4L in it and required full custom engine mounts to sit the motor quite low in the car, would a S13 be simmilar size in the front? -------------------- |
3 Apr 2008, 08:53 AM
#11
we will see in 3 weeks if it fits... if not i was given another combo, r33 x member, rb20 engine brackets and rb30 engine mounts... if not i must use all this and space the x member 10mm lower for clearence for teh stock bonnett to close... s15 has a fairly decent sized engine bay... id say close to a skyline..
poeple hav fit 26's into them no worries, so we should be able to scrape 38mm somwhere |
3 Apr 2008, 10:13 AM
#12
![]() "Deploying smoke screen" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,436 Joined: 19th September, 2006 From: Action Paintball Games WA Car(s): R32 GTSt w/RB30 Trader Rating : 2 |
When I did my conversion, the RB20 and Rb30 engine mounts/brackets looked identical..
3 Apr 2008, 10:34 AM
#13
When I did my conversion, the RB20 and Rb30 engine mounts/brackets looked identical.. thats what i was going to say there are some slight changes but general fit up the brackets are the same across the board, RB26 is preety much the same as 25 height wise that extra 38mm is more than you would expect I guess its just a case of siting the motor in there and finding out for yourself but i reckon you will be doing custom brackets which is not rocket science for some one handy with a welder just out of interest what do you use the car for? -------------------- |
3 Apr 2008, 07:23 PM
#14
well for refernce, and why i think it wont fit, my mate just had his put in his 34, had to customize mounts to fit, lowered it heaps and it just fits. dont like your chances in the s15
4 Apr 2008, 10:36 AM
#15
...let slip the dogs of war. ![]() ![]() Posts: 2,149 Joined: 10th June, 2006 From: Perth, WA Car(s): R32 GTR Real Name: Twisty Trader Rating : 3 |
if it fits under the stock bonnet, I reckon the sump will be dragging along the road... or at least low enough to the ground to be of concern.
The workshop whi finished off my car, had an S13 in there getting some work done it had a 4L in it and required full custom engine mounts to sit the motor quite low in the car, would a S13 be simmilar size in the front? Was that the VH41DE? If so its good to know that it can be squeezed under stock bonnet? Every one I've seen has had a hacked/custom bonnet -------------------- "cons for the N/A motor- you dont get farken WHOOOSH !" [ssshonky] "If you do not wish to purchase this dildo styled gear knob then do not post." [dan_the_man] "Only the people who have driven these things (R32 GTR) in anger can understand its brilliance" [bnr#@] www.outerlimitz.com |
4 Apr 2008, 11:13 AM
#16
if it fits under the stock bonnet, I reckon the sump will be dragging along the road... or at least low enough to the ground to be of concern. Was that the VH41DE? If so its good to know that it can be squeezed under stock bonnet? Every one I've seen has had a hacked/custom bonnet sorry dude that was a typo i meant 3L (RB30DET)! -------------------- |
