4 Oct 2007, 08:58 AM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,002 Joined: 17th May, 2005 From: Lap 1 - Turning In Car(s): R32 GTST Real Name: Stuart Trader Rating : 3 |
Some might probably remember this same car having a RB26/30 and a powerglide dummied up in it,
but after some calculations it was soon realised that this combination was going to cost tens of thousands of dollars to complete the engine alone. So the engine & transmission were sold and the project put on hold. Six months later i came across a low Km LS1 and Tremec 6 speed. For a laugh on a saturday arvo a friend and I thought we would see if it would even look like fitting, the joke soon became a reality. Factory Nissan engine mounts were used on the cross member, block to mount brackets were fabricated. The sump did not need any modification. The factory power steer rack was removed and a VL manual rack was fitted to allow for starter motor clearance. VX Commodore 1&3/4" into 3" extractors were fitted with slight mods, just had to tuck them in a bit. PWR Radiator to suit R32 was purchased and custom shroud and fan fitted. Gearbox crossmember was fabricated as well as custom tailshaft with masive F100 front Uni. Jim Berry supplied custom clutch and flywheel. Factory LS1 wiring harness will be fitted. Custom fuel cell was modified to house two Bosch 040 intank pumps and plumbed up with speedflow fittings through a Russell inline filter into turbosmart reg. I plan on running the engine aspirated at first with just a cam and valve spring change. Should make 350kw at the wheels. Hope to fit twin Disco potatoes later down the track. -------------------- If you don't have to turn it's boring! |
4 Oct 2007, 09:08 AM
![]() Aston martin beater, co-driver. ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,671 Joined: 6th February, 2004 Trader Rating : 1 |
4 Oct 2007, 09:13 AM
It took about 4 hours to mount the engine and box, about the same to mount the rack. the headers took a couple of hours to modify, fuel system took about 8 hours. still have to wire it but that shouldnt take to long. could easily do it in a week if you didnt have to wait for parts to be made, eg clutch, tailshaft, radiator etc.
4 Oct 2007, 10:08 AM
www.2RISMORACING.com ![]() ![]() Posts: 6,549 Joined: 31st July, 2002 From: Wollongong Trader Rating : 8 |
You're a very very bad man Stuart.
-------------------- Street Racing is not Drag Racing.
2RISMO RACING R33 SPECS Bezerkly Automotive - Import Performance Sliding Performance - Online performance parts to your door ProTrans Performance Transmissions - Street & Strip Automatics Refined at the Racetrack Cackling Pipes Photography - Drag Racing Photography from Around Aus Spool Imports - Forged Steel Connecting Rods for ALL RB Engines Extreme Turbo Manifolds - The fastest RBxx Exhaust Manifolds in AUS! Joe Gibbs - Driven - Racing Engine Oils |
4 Oct 2007, 10:11 AM
4 Oct 2007, 10:15 AM
why have u been telling people u are building a Rb25 when we are putting a V8 in it........
You're a very very bad man Stuart. -------------------- If you don't have to turn it's boring! |
4 Oct 2007, 10:16 AM
#7
why have u been telling people u are building a Rb25 when we are putting a V8 in it........ Why do you think I had it delivered to my house? I didn't want it to catch whatever your 32 has. -------------------- Street Racing is not Drag Racing.
4 Oct 2007, 10:23 AM
#8
its not a disease, its the natural evolution. 500kw on 10psi standard internals is not sick.
Why do you think I had it delivered to my house? I didn't want it to catch whatever your 32 has. -------------------- If you don't have to turn it's boring! |
4 Oct 2007, 10:24 AM
#9
its not a disease, its the natural evolution. 500kw on 10psi standard internals is not sick. You're right, as usual. The sickness is with the owner and not the car. -------------------- Street Racing is not Drag Racing.
4 Oct 2007, 10:35 AM
#10
thats not very nice
You're right, as usual. The sickness is with the owner and not the car. -------------------- If you don't have to turn it's boring! |
4 Oct 2007, 10:39 AM
#11
4 Oct 2007, 11:02 AM
#12
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 533 Joined: 1st April, 2004 From: Qld Car(s): R33 GTS25T Trader Rating : 0 |
man it's been done heaps, ls1's are shithouse should of got a proper v8... afterall it's a holden.... but either way nice work....
4 Oct 2007, 11:04 AM
#13
man it's been done heaps, ls1's are shithouse should of got a proper v8... afterall it's a holden.... but either way nice work.... LS1's are Chev's but I like your thinking. -------------------- Street Racing is not Drag Racing.
