IPB
2 Pages V   1 2 >
> How To Install Speakers Into Skyline Doors...
Fhrx
post 16 Apr 2007, 08:56 PM
Post #1
Trader Rating : 0
Hey there guys. Over the last few months I’ve had scores of people asking me to do a tutorial on how to install speakers correctly into the doors of the R33 Skyline. Well we (obviously) had to wait for another R33 to come in for the treatment and that has happened this week with an R33 GTR. So without further ado, this is the procedure for doing the doors correctly.
Step one: Take one original door complete with factory moulded plastic base speaker. Take plastic off and remove residue.
Step two: Apply sound deadening to outer skin.
Step three: Add diffuser panels behind the speaker. Tie the factory speaker wires (hanging down in image) to the loom as you'll be running aftermarket ones.
Step four: Run aftermarket speaker cables through modified door plug socket. In the Skyline where the cables run through to the doors, we simply machine a single hole (diameter varies depending on gauge of cable; pictured below is Audison Connection Sonus 14 gauge). This hole should be located between the main wires and that is where the aftermarket cables run through. These holes are traditionally blank. If need be you can also remove the plug totally and run your own loom tubes.
Step five: Sound deaden inner skin and remove air bubbles. Seal spacer onto door. Leave enough clearance for door handle and lock control rods to move freely. Also leave a little deadening around the top of the speaker hole to act as a 'roof' against water when it rains.
Step six: Create the spacers. These should be drilled to match up with the doors factory holes ensuring you don't damage the car by drilling holes).
Step seven: Make sure the midrange has a gasket because there is little use in going to all this trouble and then having no seal on the door itself. Solder the trimmed speaker wires onto speaker. Don't use crimp terminals because their two best traits are falling off and creating resistance.
Step eight: Heat shrink around the terminals to protect them. Unlike electrical tape, heat shrink will not begin moving after a couple of months.
Step nine: Screw speaker onto spacer. Make sure you seal around the baffle and place a gasket between the speaker and the baffle in order to keep the bass strong.
What's a Fhrx?
www.fhrxstudios.com<<< For all your incar multimedia desires!
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
skylinegtts
post 16 Apr 2007, 09:47 PM
Post #2
Group Icon
Car(s): R32 GTS-T
Real Name: Stephen
Trader Rating : 2
very nice... thanks for that, i assume it would be pretty much the same process between all the skylines
Profile CardPM
+Quote Post
pablo101
post 16 Apr 2007, 10:12 PM
Post #3
Group Icon
Trader Rating : 148
Profile CardPM
+Quote Post
raz0r$harP.UK
post 17 Apr 2007, 12:00 AM
Post #4
razor 'dollar' sharp
Group Icon
Car(s): R33 GTR, R32 GTST
Real Name: vijay
Trader Rating : 14
Top stuff Marty. I'm going to sticky this.
Pablo R32 & R34 doors are virtually identical. The concept is the same, only thing that differs are the pictures wink.gif
BUY MY GTR! 1995 Abflug R33 GTR-V Spec, low km, T88-34D, 395kw, $27,000 neg
Profile CardPM
+Quote Post
DRD-00F
post 17 Apr 2007, 12:06 AM
Post #5
LOL DOOF LOL
Group Icon
Group Icon
Car(s): (OO\_GTS-T_/OO)
Real Name: Steven
Trader Rating : 5
do you think it makes a noticeable enough difference that i should go buy some?
Profile CardPM
+Quote Post
wolverine
post 17 Apr 2007, 11:39 PM
Post #6
R33 GTS-t & Stagea
Trader Rating : 34
if you want to get the best out of your audio hardware you need sound deadening.
if you are a DIY person then for approximately $150-200 you will hear a massive difference.
the same additional spend on more expensive components will rarely make an audible difference.
Profile CardPM
+Quote Post
Fhrx
post 18 Apr 2007, 08:54 PM
Post #7
Trader Rating : 0
Just as a side note; I added these additional images to the other thread in CAA so I thought I'd add them here too. They show the passenger side door plug from the back end and our standard R33 battery / earthing kit upgrade (including the custom alloy brackets to avoid damaging the car).
What's a Fhrx?
Profile CardPM
+Quote Post
raz0r$harP.UK
post 19 Apr 2007, 12:41 AM
Post #8
Group Icon
Real Name: vijay
Trader Rating : 14
Marty where do the negative runs all work their way to?
Like Wolverine said, sound deadening is a great investment, and will make even mediocre speakers sound decent. If you're worried about the extra weight slowing you down (like I was), Marty's reply was to 'eat less kebabs' sorcerer.gif
You can deaden just 'half' the door, still to good effect. Pics below are more of Marty's handiwork, on my old car. Note that the stock speaker mounts were retained, but a diffuser pad and new speaker wiring was still used.
Profile CardPM
+Quote Post
jUsT-dRiFt-iT
post 17 May 2007, 08:14 AM
Post #9
Rank: RB20DET
Car(s): R33 Skyline GTS25t
Real Name: Ben
Trader Rating : 0
How do u put the sound deadening on the outer skin??
Profile CardPM
+Quote Post
Fhrx
post 17 May 2007, 09:24 AM
Post #10
Trader Rating : 0
The negatives all run to the cars body. Two connections to each shock tower and the last one goes down the the diff tunnel bolt. It just makes the car body a much better earth all around. smile.gif
As for the deadening on the outer skin, you simply feed it in through the holes. smile.gif
What's a Fhrx?
Profile CardPM
+Quote Post
jUsT-dRiFt-iT
post 17 May 2007, 03:59 PM
Post #11
Rank: RB20DET
Real Name: Ben
Trader Rating : 0
Do you have any pics of how u made a "roof" above the speaker to stop it getting wet? Because i want to get a bit just to make a "roof" but i cant quite see or work out how to do it?? Much appreciated.
Profile CardPM
+Quote Post
petern
post 18 May 2007, 11:48 AM
Post #12
Rank: RB20DET
Car(s): R33 GTST, Datsun 1600
Real Name: Peter
Trader Rating : 0
Check out the 5th pic.
Instead of cutting the hole for the speaker all the way around, leave about an inch on the top section.
This is folded back in the door and will act as a "roof" for the speaker.
Profile CardPM
+Quote Post
made_guy
post 5 Jun 2007, 09:58 PM
Post #13
newbie
Car(s): R33GTST
Real Name: Dane
Trader Rating : 7
hey what size speakers are the ones installed in the factory mounts??
Profile CardPM
+Quote Post
raz0r$harP.UK
post 5 Jun 2007, 10:15 PM
Post #14
Group Icon
Real Name: vijay
Trader Rating : 14
They are the Pioneer TS-C160R ( 6.5").
Profile CardPM
+Quote Post
made_guy
post 6 Jun 2007, 07:32 AM
Post #15
newbie
Car(s): R33GTST
Real Name: Dane
Trader Rating : 7
sweet, i'm getting some alpine 6.5"s today - hope they fit as nicely!
edit: they fitted perfectly - stock mounts, stock screws. until i can be bothered getting a really good system and doing it all properly, this sounds sweet anyway smile.gif
Profile CardPM
+Quote Post
wrcboi
post 9 Jul 2007, 12:43 PM
Post #16
Car(s): integra
Real Name: marc
Trader Rating : 0
wat about rear??any installation pics on rear?
Profile CardPM
+Quote Post
d00dz
post 19 Jul 2007, 04:03 PM
Post #17
Turdy pwns you all ____________________
Group Icon
Group Icon
Car(s): 4 Wheeled Tricycle!
Real Name: Victor
Trader Rating : 23
Nice Just a question if anyone can answer:
"Step three: Add diffuser panels behind the speaker"
|| || My R35 GTR Build Blog || ||
Join SAU-NSW - Don't be cheap! JOIN! || My SAU Photo Gallery
Profile CardPM
+Quote Post
raz0r$harP.UK
post 19 Jul 2007, 04:16 PM
