IPB
8 Pages V   1 2 3 > »
> Rb30det/tt Gtr Conversion Thread, Info on how to convert the GTR to RB30
rev210
post 17 Feb 2006, 02:26 PM
Post #1
it doesn't rev to 10,000rpm actually....
Trader Rating : 2
I know we have our lovely and very huge thread on the RB30 conversion already.
However the Rb26/30 GTR conversion has a few more bits and peices to make this process work.
How about we have a thread specific to the GTR conversion that covers:
* the Rb26dett head build up to suit
* Forged piston selection Vs compression
* Sump adaption and oil pick up.
A step by step pics based guide for DIY would be great to eventually have too, for anyone thinking of doing this in the near future to consider adding to this.
Saves wading through the hundreds of posts.
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
sky30
post 17 Feb 2006, 03:35 PM
Post #2
R32 RB30det 397rwkw 640nm torque @ wheels
Trader Rating : 7
Im also interested in some info on this topic, im soon to do the conversion.
RB30DET = Power and Torque..........
397rwkw with 640nm torque @ wheels on 20psi
GT35/40.
Profile CardPM
+Quote Post
R31Nismoid
post 17 Feb 2006, 04:15 PM
Post #3
Fear teh Admins POWAH
Group Icon
Group Icon
Group Icon
Group Icon
Car(s): HR31 GTS-R
Trader Rating : 5
Once this thread gets detail, ill add to the FI guide.
SAU-Vic President - 2008
If you have any suggestions or ideas, be sure to send them through.
For Sale
Trust Extention Front Pipe
Wanted to Buy
R33 GTR - Stock Dumps. After a few sets. PM me
Profile CardPM
+Quote Post
NissanFreak
post 17 Feb 2006, 04:33 PM
Post #4
KNOWN BAD TRADER
Car(s): Nissan GTR
Real Name: Jordan Vlotis
Trader Rating : 0
Ok here are some for starters.
1) Sump/Diff Adapter: There are people offering these but they take alot of work to fit/line up. Chunks of the block on the diff side of the sump ie webbing needs to be removed to clear the studs from the sump.
2) Head fits straight on as per normail RB26/30 engines, only thing I recommend over and above the normal modifications is the additions of a oil drain back from the rear of the head to the sump.
3) Oil Pickup, im sure there are a few methods but due to the oil pickup on the RB30 being too far back this needs to be blocked and then be tapped into from the outside of the block, the pickup on my engine is boxed and mounted to the base of the sump with a line running to the turbo side of the engine/sump. this is then connected to the oil pickup tapped from the outside with an inline filter.
4) Compression ratio on mine is close to 9.0:1, by using positive RB26 CP pistons.
Hope this helps as a starter.
NissanFreak
Profile CardPM
+Quote Post
rev210
post 17 Feb 2006, 07:09 PM
Post #5
Trader Rating : 2
NissanFreak,
Good starter. Do you have any pics of the sump issue?
Profile CardPM
+Quote Post
NissanFreak
post 17 Feb 2006, 07:27 PM
Post #6
KNOWN BAD TRADER
Car(s): Nissan GTR
Trader Rating : 0
REV210 Will try and arrange some, my engine should be done late next week
Profile CardPM
+Quote Post
Turbz_13
post 17 Feb 2006, 09:45 PM
Post #7
Car(s): BNR32 GT-R
Real Name: James
Trader Rating : 2
239.8rwkw's: 3.5' cat back zorst, aftermarkert front pipes, trust pods, r34 gtr bb turbos running 14psi and a few other goodies
Profile CardPM
+Quote Post
rev210
post 18 Feb 2006, 12:55 AM
Post #8
Trader Rating : 2
QUOTE(Turbz_13 @ 17 Feb 2006, 09:45 PM)
my 2c for you is start your own thread about os giken.
Profile CardPM
+Quote Post
NissanFreak
post 18 Feb 2006, 12:59 AM
Post #9
KNOWN BAD TRADER
Car(s): Nissan GTR
Trader Rating : 0
OS Giken from what I have seen has its own issues, only benefit is a fully counterweight billet crank which you can get for $6000 no need to spend $30000
NissanFreak
Profile CardPM
+Quote Post
[WLDCRD]
post 18 Feb 2006, 09:11 AM
Post #10
Baby got back!!
Group Icon
Car(s): '92 BNR32 GT-R
Real Name: Glenn
Trader Rating : 14
i am pretty sure i read somewhere that the OS 3L uses the N1 block. They then bore it out and i think it gets sleeved although i cant be sure on that. I asume you are talking about using an RB30 bottom end to create the base hence the sump adaptors and the like. There was a shop mentioned on here ages ago that talked about creating an RB26/30 using an existing normal RB26 block, then boring it, sleeving it, and then decking it to create the extra 0.4L capacity. But i dont think they ever did it in the end.
Profile CardPM
+Quote Post
manage13
post 18 Feb 2006, 09:39 AM
Post #11
Moisture is the essence of wetness
Trader Rating : 3
With regards to the RB30 or 31 bottom ends how do you go about putting the oil squirters in?
Also, isn’t there a problem with harmonics?
Profile CardPM
+Quote Post
rev210
post 18 Feb 2006, 10:51 AM
Post #12
Trader Rating : 2
I will add a FAQ part to the first post to address the questions like ;
What about harmonics on the RB30? etc...
If we can keep to the Actual experience, images and advice of those who have built and fitted the Rb26/30 to a GTR that would be good.
Oh and specualtion about the OS-giken and other capacity enlargements can start another thread as this one concerns the RB30 conversion only.
Profile CardPM
+Quote Post
sky30
post 21 Feb 2006, 01:04 PM
Post #13
Trader Rating : 7
Anyone got any more info on the RB30-GTR/GTS4 conversion?
GT35/40.
Profile CardPM
+Quote Post
GTST
post 21 Feb 2006, 02:36 PM
Post #14
Rank: RB30E
Trader Rating : 5
I'm sure he'll see it but it might be good to point htis thread out to user "Fitzpatrick Speed Works" who makes the sump adapters.
also SK will probably have good input to this too.
I'm keen to know this aswell for my gts4
Profile CardPM
+Quote Post
Mr GTS4
post 23 Feb 2006, 11:36 AM
Post #15
Trader Rating : 3
bring on the gts-4 4 door rb30 conversion
4WD is much more fun !!
Profile CardPM
+Quote Post
FORZA-MOTORSPORT
post 23 Feb 2006, 12:07 PM
Post #16
Trader Rating : 16
Hi guys doing the 25/30 conversion to my gts4 at the moment and wondering about the sump adaptor? Does anyone on the forum sell one? How much modification is required and does it bolt straight on
cheers,
Ant
Profile CardPM
+Quote Post
Sydneykid
post 23 Feb 2006, 12:23 PM
Post #17
RB31DET
Group Icon
Trader Rating : 48
QUOTE(manage13 @ 18 Feb 2006, 10:39 AM) *
1. With regards to the RB30 or 31 bottom ends how do you go about putting the oil squirters in?
2. Also, isn’t there a problem with harmonics?
1. Block mounted oil squirters can be fitted, but it is a bustard of a job and not all RB30 blocks are suitable. For temperature control, ceramic coating the piston crowns and oil retention coating the piston skirts works very effectively and costs less.
2. Grossly overrated, same bore and stroke as a 2JZ, never hear about harmonics in them. Proper balancing goes a long way and the block strength added by the 4wd sump adaptor helps as well.
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
N I B
post 23 Feb 2006, 02:45 PM
Post #18
RB36DETTTT
Trader Rating : 0
Just make sure no one sells you RB26 pistons as RB30 twin cam pistons as many companys do.Use a piston made for the job like CP and Arias.
RB26 piston sits way down the bore and thats very dodgy.
We are building 30s now using CP pistons that are made for the job and their working very well.Ross is one piston thats sold as an RB30-26 piston that is really an RB26 piston and its a long way from the right piston for the j
